Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
NOT boot Actually its boot..but when enter del key try to boot its automaticaly screen blackout... But pc working... PLs Help me
    President:
  • 2,351 Answers
As soon as you turn on the PC press the Pause screen. Try to allow some of the boot screen to load before pausing it. See if you loose video while in pause. If you do loose video display, than the issue is either the video card or overheating. Check CPU fan. (Clean interior of PC). Remove & re-seat the video card. On page 28 of your manual you can only use certain video cards as listed. When all else has failed clear your cmos pg. 29.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000066
To test your memory click this link. http://www.memtest.org/
Scroll down to
** Memtest86+ V2.01 (21/02/2008) **
Download - Pre-Compiled Bootable ISO (.zip) or Download - Pre-Compiled package for Floppy (DOS - Win).
Mike
Posted on Mar 26, 2008
My F2, f8, and f12 keys don't work on dell laptop
If you are trying to boot into bios you can also try f10, ESC,DEL and f11. If you are trying to boot too cd try hitting the enter key. I will usually start hit the key at 1 sec intervals from the time i turn the pc on. Some pc manufacturers will have alternate keys that you have to hit to boot into bios. Once in the bios you can set the cd drive as first boot. once that is done just keep taping the enter key until you see something different on the screen. Here are some links to try and help.
https://www.dell.com/support/article/us/en/19/SLN114872/EN
https://www.dell.com/support/article/us/en/19/SLN142679/EN
Some newer pc will have a recover partition witch you can get to by the boot selection screen. I have also seen many pc that you have to make a recovery disk first. If you don't, you won't have a easy way to recover the pc.
If you still need more help Please leave me a comment here with the model number and type of pc. I am assuming it is a dell.
Oct 17, 2015 | Dell Computers & Internet
Boot menu cant working
Press DEL to get to your bios options then disable fast boot. This will allow you to hit the appropriate key to enter the boot menu.
Mar 30, 2014 | Lenovo Computers & Internet
Blank screen after boot splash screen
Hi.
After you see the press Del and F12 message repeatedly tap the F8 key, see if that gets to the advanced boot menu, if it does select "Repair my Computer" from the list, and then follow the prompts. Have your Win 7 disk ready just in case you need it.
Let me know how you get on and good luck!!
Jan 02, 2013 | Computers & Internet
I Cannot repoot my disk by pressing F2
What are you trying to do ?
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this will set the boot order
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
If you need more help with this or if i have missunderstood the problem post a reply
Hope this helps
Nov 19, 2012 | Dell Dimension 4600 PC Desktop
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
hope this helps
others you might try
Sep 27, 2012 | Sun Blade 2500 PC Desktop
What keys change bios values on asus u46e
hope this helps
Jul 28, 2012 | ASUS U46E-BAL6 U46E-BAL7 U46E USB External...
Boot menu
You can change the boot order from the BIOS. Power on your laptop and hit the Del or Delete key to access the BIOS. if it's not the Del key then watch the screen for the key to enter the BIOS setup screen. It could be F2 or F10 since every laptop is different.
May 11, 2012 | ASUS U52F-BBL9 Laptop
How to install change first boot divice on ibm thinkcentre computer
You must enter the "BIOS" at start up (sometimes called SetUp). Press F2 or F8 or F11 or other function key that will be required by your computer. Should tell you at boot.
Enter the BIOS settings, find the boot sequence and edit it. remember to save your changes.
BE VERY CAREFUL WHAT YOU SELECT!
Thanks for your visit today.
Feb 01, 2011 | IBM ThinkCentre A50 PC Desktop
Which key is using in aspire 4736z for bios set up
it is actually written on the bottom on the screen when you boot it up..at one moment will say press....to enter set-up..but for most laptops the key is F2 ..for most desktop DEL key ..and some older models F12
try to press F2 on start but just *** soon as the display is powering up..
May 21, 2010 | Acer Aspire One PC Notebook
Key on keyboard to access bios of M24XS-NP233X
for most desktops the key to press is del ...but it has to be pressed on boot when it shows your devices ....so ...just power it up ...and keep pressing del rhythmical to be sure that you do not miss it ...anyway after a few boots you will see cause it is written on screen press del to enter setup ...if there is another key set to do the job it will specify which one...
for some laptops you have to press F 2but I dont think this is the case...
if helpful ..please dont forget to rate ... Have a nice day !
Jan 18, 2010 | Computers & Internet
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
77 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
