My thermostat has no power
.I have no power to my thermostat and after testing the out wires of the transformer i only have 19.4 volts??? Does this mean this is my problem? Also there is a flashing led light in my heat pump that is showing an error message of (secondary voltage fuse is open..)
  • 10 more comments
  • woockman1 May 03, 2010
    Yes the problem was the fuse on the circuit board... i checked the fuse on the circuit board outside the furnace(which was fine) and didn't realize there was another circuit board with another fuse inside the furnace itself(which was blown)...
    Appreciate the help both of you
  • woockman1 May 09, 2010
    there was a internal circuit board fuse blown...i replaced it...the thermostat came back on the fan kicked in...but when i switched it to auto heat nothing....then lost power again...and both internal circuit board fuse and external circuit board fuse were blown...
    I do have a multimeter but i am a novice with it..clear explanation of how to test wires would be appreciated...also currently i replaced the two blown fuses and now the LED error light is on continuously but i have no power to the thermostat..don't know if that helps
    Also not sure if it matters but i was wrong it is a natural gas furnace..
    Payne
    Model number PG9MAA036080
    I had 27 volts between common and red on thermostat
    it is a payne model number pg9maa036080...i believe natural gas furnace.
    Brand: PAYNE HEATING & COOLING
    Manufacturer: CARRIER CORPORATION
    Model Number: PG9MAA036080**
    Fuel: Natural Gas
    Input Capacity: 80,000 BTUH
    Output Capacity: 74,000 BTUH
    Efficiency: 90 % AFUE
    Energy Star Qualified: yes
    Air Flow Configuration: Horizontal and Up and Down
    Electrical Phase: Single-phase
    Combustion Type: Condensing
    http://www.docs.hvacpartners.com/idc/gro...
    This is a newer model of what i have, but they are very similar
  • woockman1 May 10, 2010
    I can try to get the schematic tonight...
    I do have a heat pump with nat gas back up as u thought...
    Could this be a bad contactor? was reading online someone with simalar problem was the contactor?
    Also drain is working and no compenents are wet..
  • woockman1 May 11, 2010
    Well upon looking closer at the condensing unit wiring, I found a yellow wire that was touching a ending metal hook up to another wire, when i pulled it back sure enough it had been worn through....VICTORY!
    I appreciate all the info you gave me...thank you for the effort...u were right from the beginning but i didn't look close enough outside...
  • Brian Niten May 11, 2010
    Is there a fuse on the circuit board? I would check for that first then concentrate on the transformer.
  • 674 Answers
It sounds like you have a short or a ground in the control circuit. Somtimes you can spot a bad component with your eyes. Look at the different relays to see if any looked burned. You might also look for a wire that has came off and is touching ground. You mentioned you put it in auto heat. This could narrow your search to components for heating. The problem could be in the coil on your reversing valve. I don't know if you have any trouble shooting experience, but if you have a multimeter you could do some resistance checks to find the problem.
Posted on May 09, 2010
  • 4 more comments
  • Brian Niten May 09, 2010
    Remove the thermostat face and check for 24vac between the R & C terminals on the thermostat.
    Good, the transformer is still working. Do you have a schematic you can send me or can you read the schematic? If you can locate the transformer and determine which part of the schematic is the low voltage side and then we can go through component by component to locate your problem.
    What kind of setup do you have? Is it a/c and natural gas heat or a heat pump with natural gas backup?
    That doesn't include the electrical schematic. Look on the door for you unit and see if it has one on it. I see from you link that you have a condensing furnace. Make sure the drain is working and also check for any electrical components that may have gotten wet. Let me know if you can find a schematic attached to your furnace.
  • Brian Niten May 10, 2010
    I'm not sure. I'm thinking your problem is in the 24v circuit which could be the coil that pulls the contactor in. You can remove the 24v wires from the contactor and use your meter to ohm the coil. Turn off the 240v first so you don't accidentally get shocked.
    Good job. Patience pays off in the long run.
    Novelist:
    Champion:
  • 246 Answers
Assuming you are talking about a transformer that puts out secondary voltage of 24V (and I think you are) - then your voltage reading at the transformer is within guidelines.
The flashing red light seems to be telling you that you have a fuse blown in your secondary voltage circuit which under normal circumstances would disable your t-stat. I would try and find a fuse in that circuit and check and see if it is good or not.
If it is bad - you need to replace it - but you also need to determine what blew the fuse.
Sometimes fuses blow on their own and the reason cannot be determined, but most of the time there is a reason that the fuse blew in the first place.
It may be that you need an experienced troubleshooter to figure out your problem but I would at least try replacing the fuse and see if the unit operates properly from that point on.
If it blows another fuse then you will need someone to trouble-shoot the problem or submit more information to this site for some additional help.
good luck!
Posted on May 03, 2010
Testimonial: "great info!"
Where is my 24v control
The thermostat works on 24 volts supplied by a transformer in the unit. Follow the red thermostat wire it will lead you to the transformer low voltage side (there will be one or two other wires to that side). the other side of the transformer has two wires, one connected to each 120 Volt line power input of the contactor so there is always power to start. (For a 110 volt system there is a black wire to power and white to neutral)
Jul 13, 2014 | Carrier Heating & Cooling
Air conditioning thermostat not functioning
ab302475-b998-41c7-9c7c-4e106b68e0be.pngGo to your thermostat and look at the FAN switch, it will be in the AUTO position typically.
Set the FAN switch to the ON setting,
by doing this if the fan motor operates you know that the High voltage & the low voltage (24 volt control power) are present.
This saves you from having to go to the breaker panel and checking / resetting the breaker as well as checking the Transformer and automotive type 3 amp control circuit fuse (generally on the circuit board).
If you do not get any fan operation by switching the fan switch to the ON setting, you then will have to determine if the breaker, transformer and aforementioned 3 amp fuse are all good.
You will need a volt meter to test further.
At the thermostat remove the cover thus exposing the thermostats sub base and assorted circuits/wiring.
RED or R
Red is the 24 volt "hot leg" of 24 volt power which originates at the transformer. Red enters the thermostat on the Red or R terminal, some thermostats will have an RC and an RH terminal, these are jumpered together on single transformer systems as they are for Red Cool and Red Heat, without a jumper wire on RC and RH, the Red "hot leg" of the 24 volt control voltage will only energize the terminal its wired to, some stats are battery powered and do not use the transformers 24 volt power (parasitically) to power the thermostat.
If the thermostat is powered by the transformers 24 volt power, there will be a "COMMON" wire on the common terminal of the thermostat, this is the other side of the 24 volt power from the transformer, the side opposite from RED the 24 volt "hot leg"
Common is called common as its the side of power that EVERY
24 volt circuit terminates, or completes its circuit, thus the COMMON designation.
During a Heat call the 24 volt hot leg is sent out via the white/heat terminal to the gas valve etc.
So between terminals Common & White , it should read 24 volts during a call for heat.
Same for Fan which is the Green or G terminal,
Same for Cool which is the Yellow or Y terminal.
If you have no power to these terminals when calling for heat or cool or fan then yes the thermostat is defective and requires replacement.
DO NOT let the RED wire touch ground or the COMMON terminal, this is a direct short and blows the fuse or transformer
if not equipped with fuse protection.
Normally you should read 24 volts between RED and COMMON
Aug 01, 2013 | Goodman CKL36AR36 Air Conditioner
I have no voltage to my thermostat
Possible transformer problem or a broken wire between the thermostat and the a/c
You will need an electric meter to check for voltage at the transformer One side should be the power feed and the opposite side should feed the 24 volts, or 12 volts depending on type of unit.
I suspect that there is a break in the thermostat wire to the unit. You can test this by getting enough wire for the thermostat and go to the board on the roof top unit where the thermostat wire connect and connect the wires that you have to the existing board i.e. red to red green to green and so on. once you have connected these wires to the proper screws then take a new thermostat and connect the wires to the new thermostat and activate this should tell you if there is a break in the wiring or possible transformer problem but as I said I think its a break in the wiring
Dave
Mar 19, 2010 | Dometic Rooftop RV Air Conditioner
I tring to change thermosat I can not remeber what color go where
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Heating & Cooling
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
I have a coleman Evcon model AH16-0 . I am
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 06, 2010 | Heating & Cooling
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
No power to thermostat
You need a serviceman. No really, you do! You are in over your head and you are replacing parts just because you can see them and they are not the likely culprit. I am betting it is the contacters in your condensing unit.
Sep 01, 2009 | Heating & Cooling
My ac unit does not have power to the thermostat. There is 200 volts going into the transformer and 24 volts going out. There is 24 volts on the back side of a terminal with thermostat wire running to the...
Please exercise due caution in checking voltages in live circuits!
24 volts sourced by the transformer, through the thermostat, then through the contactor (turns on power to compressor/fan) and returns to the transformer, If the thermostat is closed (calling for cool) you will see no voltage across it, but instead the contactor should be energized. Please note, 200 volts seems odd, you should have between 215 and 235. It sounds more like the contactor relay coil may be open. Is the contactor/transformer one piece?
May 15, 2009 | Heating & Cooling
CARRIER AIR CONDITIONER/HEAT PUMP PROBLEM WOULD NOT RESPOND TO THERMOSTAT. UNIT IS AT LAKE HOUSE WHERE WE DO HAVE BAD STORMS. IN CHECKING, INSIDE PART OF UNIT HAD BURNED UP THE TRANSFORMER BUT NOT...
what I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side.
A quick way if the primary side is burningout due to a problem with the low volt side:
1 MArk all the thermostat wires at the indoor unit
2 Disconnect them at the indoor unit.
3 Check main line voltage before proceeding (A 208 volt is not considered 220V and 240v Is not considered 208V> In these circumstances the voltage may have changed with the power company replacing a transformer and now you need to change the main power input lines at your control transformer for the correct operating voltage). If okj then proceed:
4 If you have an amp meter attach it to one of the lines going to the transformer.
5 Apply main power and listen for hum, note if smell starts again and if so problem has to be in board or main incoming voltage too high or too low. Amp draw should be less than 3 amps.
6 If your to this point and still havent found any trouble in the above as of yet, Connect the wire marked "C" together. Then just touch the thermostat wires one at a time to the places where they go on the indoor unit and watch the amp meter. If you donmt see the meter jump the circut is probably ok but leave them disconnected until you touch all of them to the correct place or wire. Here is a possible problem I ahve seen a thermostat wireing problem if the wires are stripped too far and a "whisker" of the wire sticks out and allowes one of the other wires to cross short out. In this case just cut off the excess wire or bend it over out of the way asnd continue with the test. You can always cut it off later after the tests. If you see the meter jump up and stay up and /or blowes the fuse the wire that you used and it blew is where to consentrate.
7 No wiring problem found means that you could have a relay or contactor not pulling in properly.
and this will cause the amp draw to go way over the transformers power out put or VA rating.
8 Inspect the thermostat wiring for the "whisker" I mentioned above.
9 If you have done this to the end of the thermostat wires and your main incomming voltage is correctly wired in on the transformer andf your relays and contactors are pulling in evenly and not delaying excessively your problem should be fixed.
If this helps you please rate me as high as you can and thank you for using fixya.
Apr 24, 2009 | Heating & Cooling
Heating & Cooling Logo
1,100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
