Question about Hoover Washing Machines
I clean the door seal on my hoover washing machine every time I use it but I keep getting grime marks on the clothes.I have tried powder & liquid detergents nohing makes any difference. I have done service washes at high temps bought special cleaners but nothing works.
Sounds as though your machine is plumbed incorrectly, the height of the waste hose end when fitted into stand pipe should not be lower than 4/5 inches from top of washer, this is to prevent syphoning which will leave suds grime etc and also cause blotching on whites
Posted on Nov 19, 2010
There is a permanent smell which taints the clothes. How do I get rid of it
is it a front loader? Do you keep the door to the washer closed? You may need to sanitize the door gasket as well as the drum
Sep 14, 2014 | Creda IWD12 Front Load Washer / Dryer
Gunge in door seal samsung Q1233 washing machine
It's caused by using too much soap powder or fabric conditioner,it doesn't get rinsed away properly and goes greasy & slimy,,,,,if its starting too smell change door seal,,,,,use bicarbonate of soda 1 or 2 times a month, no clothes or detergent,& on a 90 degree wash,,,that should stop it returning
Jun 19, 2013 | Washing Machines
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
We clean the filter after every wash but we still get black & white bits on the washing wa have cleaned the waste pipe, pump filter at the back is always clean .model no sw75usp can you help under...
Hi bob, have you tried cleaning the dispencer drawer that supplys the detergent to the tub? in some cases over time the detergent holder can collects small amounts of powder that can dry out and stick to the walls of the holder and when the machine is in its spinning stage can sometimes vibrate the dry powder in turn cause the powder to enter the tub also there can be a huge build up of liquid detergent like softners that can form a hard black residue in the holder in turn causing the clothes to collect black paticles. If all is ok then you could try applying a hot wash cycle without any clothes in the tub to flush the bowl from any contaminents, thumbs up if this helps thanks.
May 06, 2011 | Samsung Washing Machines
My machine is a hotpoint aquarius and after a wash the clothes come out of the machine smelley. I also have a grime on the rubber seal around the door
A couple of possibilities her:
  1. Washer not rinsing and draining properly
  2. You are doing too many low temperature washes
Solution to 1 is to check and clean pump filter.
Solution to 2 is, do more high temp washes, even if you do not put clothes in, do a 90 degree wash with powder in, this will help keep the smell from reocurring, and help keep the seal clean.
Please rate my solution.
Thanks.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
White marks on my clothes.
Are you using TOO much powder? And is the machine set to the correct rinse tempature? You mention white stuff, does it look like undissolved washing powder? Or fabric softner? Possibly try liquid detergent and see if the problem continues. And follow the recommended amounts of detergent for each wash load, and the tempature settings. And of course the water levels. All of the above are crucial to insure you get maximum preformance and utility out of your machine, with the results you expect. Let us know what you find. Kindest Regards, Slats.
Sep 26, 2009 | Washing Machines
Rubber seal got dirty
Clean thoroughly with scouring pad and liquid cleaner, you will not get all the marks off,but as long as you get the worst off, it should be o/k.
To keep it from getting any worse, do a 90oC wash with powder in, but without clothes at least once a month, this will help keep it clean.
The problem is initially caused by doing too many low temp washes, so this is why you need to do a hot boil wash periodically.
Thanks.
May 15, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Dirt and grime always building up around seal inside door
This is a very common problem with a lot of users, it is mainly down to the way you are using your washer.
The most important factor is that you are probably doing a lot of low temp washes,eg:40oC.
This does not let the wash powders and detergents to work properly at these low temps, so consequently you get a build of slime and grease and bacteria which is actively growing.
At least once a month depending on how often you wash, do a 90oC hot wash with powder in, but no clothes in.
This is called a maintenance wash, and most manufactures are recommending this now in the user instructions.
The other thing to do now before it gets any worse, is thoroughly clean the door seal and glass with a scouring pad or steel wool pan scrubber you will not hurt the door seal by doing this, and remove as much of the grease etc that you can, pull back the door seal and get inside where you normally can't see.
You will find that the seal will be stained, but as long as you get off the worst, it should be o/k.
Hope this helps solve your prob.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 23, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machine does not wash clothes
You are possibly washing at the wrong temp, or not using sufficient powder or detergent.
The m/c is not rinsing properly, check that it is pumping o/k.
If there is a build up off slime and mould on your door seal, then you are definately washing at too low temp.
At least every 4 to 6 weeks, do a high temp wash with powder in but no clothes.
This is called a maintenance wash and helps to keep the inside parts clean..
If your door seal is stained, clean as best you can with a scourer pad or similar. You will not hurt the seal.
plz rate my solution .
Thanks.
Dec 17, 2008 | Washing Machines
Mildew smell in towels
are you using liquid detergent? if so, change to powder. liquid detergent used for a long period causes a smell.
try putting on the hottest wash with no clothes in to get rid of the smell
Aug 05, 2008 | LG WM-1485FHD Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
