Have a remote but don't know what type? Found it in a drawer looking for a site with picuters on front, under protective slide "MKT904-ADO" appears in battery compartment "URC-4MXXXBJB-XXX' appears J-05 36 02 Made in China, US patents 5,959,751 5,414,425 5,552,917 5,414,761 5,913,444 I want to use the remote with a Phillips tv PNF612 CH01
The remote is a Millenium 4, made by Universal Electronics.
www.urcsupport.com
Posted on Aug 02, 2013
Sparky-UK
  • 129 Answers
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 30, 2007
Sparky-UK
  • 129 Answers
SOURCE: urc-7562
http://www.sparky-uk.com/one-for-all-6-urc-7562-6-in-1-universal-remote-control-6-p.asp
you may also find that you need to update your remote to work with your TV this can be done by visiting the one for all website www.oneforall.com
Many thanks
Mark
(www.sparky-uk.com)
Posted on Jan 03, 2008
  • 686 Answers
SOURCE: phillips universal remote codes for rca
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Posted on Feb 18, 2009
SOURCE: NEED CODE TO PROGRAM ZENITH TV TO ONE FOR ALL REMOTE
TENGO UNA TELEVICION DURABRAND ME FALTA EL CODIGO
Posted on Jul 13, 2009
SOURCE: can I use a second hand one for all URC 7040 tv remote control
Was wondering if you still have the URC 7040 one for all remote. I have been searching high and low for one as I need one to make my Blu-ray DVD player multi region and this is the only one able to do it. I would be really grateful if you could let me know if you would be prepared to sell yours - or at the very least lend me the remote for 24 hours so I can unlock my Blu-ray player. I will of course pay you for your troubles.
Regards
Atif Noon
kashifatif@msn.com
Posted on Nov 30, 2009
I have a 1976 Gaffers & Sattlers slide in range I want to replace. Any idea how to remove it? Thanks
this taken from ehow site:
Slide-in ranges and freestanding ranges use the same installation techniques, with one minor difference: the slide-in range rests on the edge of your counter top. Removing a slide-in range is not difficult but will require a friend to assist. Removing the storage drawer from the slide-in range first will give you access to the power cord and gas shut-off valve, if your unit uses gas
Instructions
    • 1 Pull the bottom storage drawer out as far as it will slide. Lift up the front of the drawer and unhook the back of the drawer from the drawer guide. Pull the drawer away from the range.
    • 2 Reach under the slide-in range and unplug the power cord from the wall outlet. Turn the gas valve to the off position on the house line coming from the wall.
  • 3 Lift the top of the slide-in range with the assistance of your helper, and pull the range forward enough that you can access the back of the range.
  • 4 Go behind the range and locate the connection between the house gas line and the range gas line. Disconnect the flexible gas line from the house gas line with a pair of channel lock pliers or a pipe wrench.
  • 5 Lift up on the rear of the slide-in range while your partner lifts the front. Slide the range out of the cabinet opening and out of the house. Lifting the unit will prevent unnecessary damage to your counter tops.
  • Read more : http://www.ehow.com/how_5959888_remove-slide-range.html
    Jan 03, 2015 | Kitchen Ranges
    Diplomat washing machine
    Try Sliding the Soap Dispenser Drawer Lock to the RIGHT and then pull straight back... It is located under the handle
    Mar 03, 2014 | Washing Machines
    The front panel power button won't work and i don't have the original remote for my mitsubishi hd 1080
    Check and replace the microswitch soldered diretly to front panel circuit board. You have to open the TV. Get more details from the below referred site, and by click open the ads by the side and bottom of each posts.
    Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
    May 26, 2012 | Mitsubishi WS-55807 TV
    My remote control doesnt work
    Check the remote control for its infrared emission. To get more details about how to check the remote control and to repair it if it found faulty, Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
    Pull up older posts there. Fault finding to remote controls and repair proceedings are given here in detail.
    May 22, 2012 | Philips Magnavox 20MS233S 20" TV
    I have a Philips TV/DVD front load player, I also have a RCA Systemlink. I don't have the original Remote Control and want to set up my RCA Universal remote with a code search to my Philips TV/DVD
    May 17, 2012 | Philips Televison & Video
    My remote works but the tv{s dont get signal
    Check the remote control for its infrared emisson. To know, how to check and repair remote controls, visit the site mentioned below. If your remote control is found OK, repalce the remote sensor component inide your TV. The site to visit is "Electro-help". Type in this site name either to Google or Yahoo search box and click search.
    don'g forget to type in 'hyphen' in between words of the site name. The site will appear as it is. Pull up older posts there.
    May 07, 2012 | Insignia NS-27RTV 27" TV
    Need to replace damaged drain hose
    ok, i figured it out: pull open the drawer about 250mm. if you look at the outer plastic skin of the drawer, you will see on each side a round plug down near the bottom of the drum about 50mm in from the front panel. these look as if you can turn them by hand but you need a pair of pliers. they need to be turned 90deg to the unlock position. do not expect them to pop loose after you have turned them; i poked my ones loose by inserting a small screwdriver in behind them from under the drawer and pushing them out. once these plugs are out, the front panel will pull down and them off. note that the plugs do an important job: as well as holding the front panel on, they pass thru the slide rail extension thus locking it and the drum in the correct relationship for the drawer to close correctly. note also the small metal clip on each slide near the back of the drum which the drawer drum moulding has to clip into fully when you put the drawer back onto the slides. hope this helps someone.
    Jan 15, 2010 | Fisher DD603B / DD603W / DD603H Dishwasher
    We have a 1988 hi lo bonvogage camper and we think we may have burned out the water heater we were told that there may be a reset switch but we can't get to the box without knowing how to remove the bottom...
    Depending on what mechanism it slides on under drawer, try sliding your finger up under drawer if guide in center, and follow guide to drawer, then push up on piece of nylon catch where your finger meets drawer, or slide a pen or something in there, and it should release to pull drawer out. If not that type, please describe what drawer rides on & we can figure it out from there.
    Jul 07, 2009 | Sport & Outdoor - Others
    Need to remove drawer from the Duet drawer pedestal, it won't come out
    I just removed the drawers, you need to remove one each 1/4" head sheet metal screw from the end closest tot he drawer front. this will allow you to slide the drawers out and clean the mess undere both the dryer and the washer. repeat steps to reinstall. Takes about 2 min to remove both doors, Hint: a 1/4 socket works better than a wrench.
    Jun 23, 2008 | Whirlpool Washing Machines
    Sd protected
    Hi,i got this as a freebie,found it&all it's components in the drawer of a desk i brought at a goodwill but no instuctions. I don't have a clue how to use it other than charging it.
    Jan 19, 2008 | Polaroid iZone 300 Digital Camera
    Televison & Video Logo
    Top Televison & Video Experts
