Question about Canon FAXPHONE L80 Laser
Help my faxes are coming out from the bottom and not the top anymore what can i do
    Scholar:
  • 141 Answers
Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=337&modelid=9986
fallow this link and download the PDF file : L80_userGuide.pdf
You'll see on page 66 that you have a selector option...
Posted on Mar 26, 2008
When I send a fax the recipient tells me it comes thru black & unreadable.
Dear
The fax machine has ADF roller on the top of scanner, foun at the bottom of the fax when you open the top cover.
Pl. do clean the whit roller with lint free cotton cloth dampen with mild soap(care to be taken not flow the liquid inside.),
If still problem persists contact service centre to replace the CIS (rare).
Thanks.
Mar 05, 2015 | Brother Personal FAX-190
Making a black line on copies top to bottom right in the middle
maybe your scanning glass have a dirt! try to open the document feeder and clean it! or it possible that the problem was coming from the cartridge.. =)
May 17, 2010 | Ricoh Aficio 1515F Plain Paper Laser Fax
I have a muratec F320 fax machine. When we photo copy or fax something it is coming through with a line on the left hand side of the pg all the way from top to bottom
Open the lid of the ADF and check the **** of glass that runs from back to front on top of the machine, most likely corrector fluid or some kind of foreign matter on the glass.
Mar 17, 2010 | Muratec F320 Plain Paper LED Fax
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Need a diagram of the belt pulleys of the air conditioner
dear friend-seeing that i have no fax no for you i will try and explain the best i can.you got 6 pulleys 2 top 2 middle and 2 bottom.the belt runs out side on top in side in middel outside at bottom.hope this will help.send fax no for diagram.
Jul 08, 2009 | Hyundai Motor 1999 Elantra
Do i lay paper with print upwards when faxing
That totally depends upon which model ur using just try to pull up the slot where u put ur paper for faxing it will open then just check where the scanner lies and ur print face shall be towards scanner you send top to bottom or bottom to top it doesn't matter.
Jun 20, 2009 | Office Equipment & Supplies
The fax streaks
Open the lower part of the number panel by pulling up 1 inch. and clean the small scanner glass.....hard to see.
Mar 02, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
HP 920 Fax Half Lines
Try making a copy of something.
If the copy comes out the same way as your faxes, then the ink cartridge is either dirty or clogged.
You can try removing the cartridge and checking the bottom of it.
You can even wipe the bottom of the cartridge with some denatured alcohol.
If this doesnt work, then purchase a new cartridge and your problem should be solved.
Good luck.
Hope this helps.
Mac =)
Apr 02, 2008 | HP 920 Plain Paper Fax
Strong high definition set top box
Binkanath:
This posting is in the area for Canon Fax JX200 issues. In order to receive a response from an expert in the area you need, I would suggest seeking out the proper equipment make, model, etc., and reposting the question. However, you will need to include the details of your equipment for us to help you. Thank you for using and rating FixYa!
Oct 04, 2007 | Canon FAX-JX200
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Canon FAXPHONE L80 Laser Logo
32 people viewed this question
old marine
old marine
