I don't show E drive on my computer - Computers & Internet
  • 149 Answers
What do you think you think the E drive should be. A+B are reserved for floppys and C is usually the Hdd D is prob your dvd/cd. therefore E is either an additional cd/dvd or an external device.
Tell us what you think it is.........
Posted on Mar 25, 2008
LG laptop usb ports not working
do you have the program needed to get what you have on your flash drive? If you don't have a photo program or pdf program or what ever to open it, it won't work. try connecting something else that uses USB port to it and see if that works, then you will know if its a program problem or your computer. if its the computer, you can replace it.
May 07, 2012 | Computers & Internet
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
I have installed a 2nd hard drive in my hp dv7-1232nr laptop and it shows up in the device manager but does not show up when I click on my computer. Why is it not showing up there?
With XP and 2000, though, use Windows' Disk Management utility. Click Start > Control Panel > Administrative Tools > Computer Management, and choose Disk Management from the tree at left. Your new drive should appear, with a black bar indicating it isn't partitioned. Right-click the bar, and choose New Partition to launch the New Partition wizard. Installed drives and their partition schemes appear in the Disk Management window's lower-right corner.
Click Next, and check that Primary Partition is selected; click Next again, to the Specify Partition Size screen (don't change the partition size in the "Partition size in MB" field); and click Next to advance to another screen, on which "Assign the following drive letter" should be selected. Click Next yet again (to the Format Partition screen), and ensure that "Format this partition with the following settings" is selected and that the "File system" drop-down reads "NTFS." Click Next a final time, hit Finish, and formatting begins.
Formatting could take an hour or more, depending on drive capacity. But don't be surprised if your formatted drive has less capacity than the package claims. A 320GB drive, for instance, formats to about 300GB. Drive manufacturers advertise preformatted size, but a portion of the drive is inaccessible.
Hope this information will help.
Your response is very much appreciated...Thank you for using Fixya...
Sep 24, 2011 | HP Pavilion DV7-1232nr Notebook
When i am using my flash drive on my own computer in my house, i can open, view, and use the files inside it. And when i am using it on other PCs, or Laptop, the device shows that it still contains its...
Please check at your own home system , that all the data in your pen drive may in hidden format and you have unabled the option to show hidden files in your computer and other pc don't have unabled the show hidden files option. Or the best way is take backup of your pen drive data and formate it and then recheck adding some file on it.
Jun 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a really old computer and I put my flash drive into the where it is supposed to go, but nothing came up. What am I supposed to do?
Some Flash Drives don't come with an "autorun" installed in it, if you have a Windows 7 Operative System, it might be installing the driver for it. If it's already installed, go to your computer menu and check if the drive shows up there (In the "removable drives/devices" area).If it doesn't show up, try plugin it in another USB port, your port might be the on not working.
May 26, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Hello, I have a NEW monitor a170e1tt monitor and I don't know why it don't turn on, don't show any signal of live. what are the most comon problem of that model?
check if the monitor is compatible with your type of pc and check what mhz your computer can handle or you can try check the motherboard monitr socket and check of some of the pins are gone.
May 18, 2011 | Computers & Internet
When i try to play the file on the camera it says " not applicable files are avaliable" and when i try to put them on my computer the files are not there.
the files are hidden on your computer, i will show you steps on how to show them, the drive might be virus infected. when you see the file make show you create a backup for it and then format the drive before using it in the camera again.
See instruction and picture below on how to show hidden files on windows 7. for other operating systems contact me back.
Steps:
  1. At the Windows 7 Taskbar, click Windows Explorer.
  2. Above the left pane, click Organize and select 'Folder and search options'.
  3. Click the 'View' tab.
  4. Scroll down, find and mark 'Show hidden files, folders, and drives'.
  5. Click 'Apply', 'OK' and then close window.
To hide files, folders and drives:
  1. Repeat steps 1-3.
  2. Scroll down, find and mark 'Don't show hidden files, folders, and drives'.
  3. Click 'Apply', 'OK' and then close window.
May 11, 2011 | Cameras
While the computer is switched on it shows the command insert any harddrive in a black colored screen sometimes and sometimes if it starts it shows a caution "Windows detected a hard disk...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 22, 2011 | Computers & Internet
My new DVDRAM GH22NS50 don`t work.
Please go to start - computer - right click - manage - disk management
If your DVD drive is visible - right click - change drive letter paths - change - choose new letter
Is your DVD visible in my computer, if it is repeat the process and change back to previous letter.
If it is not there, reboot the computer and it should show up.
Dec 10, 2010 | Computers & Internet
Toshiba (MK1031GAS) 100 GB Hard Drive - Cant be viewed in My comp
The first thing you need to do is go into the Control Panel, then double click on Administrative Tools. After that, open up Computer Management, then go to Storage, then Disk Management. This is where you will see all of your drives listed. Be extremely careful in this section because you don’t want to screw up your main hard drive.
What you are looking for in the Disk Management area is your new hard drive. If you only have one hard drive, it should show up as Disk 0. Therefore, your new drive should most likely be Disk 1. Underneath the name Disk 1 it should say Unknown, the size of the disk, and Not Initialized. Right click in this area and you should get a pop-up window. Click Initialize Disk and it should only take a couple of seconds.
Once your new hard drive is initialized, you will still have to format the drive before you can use it. To format, right-click in the column to the right of the Disk 1 label and then click New Simple Volume in the menu that pops up. From here, you can allocate how much of the drive you want for a new volume, what drive letter you want to call it, give it a name, and finally format the hard disk.
Formatting the hard drive may take a while, depending on the size. My 500 gigabyte drive took nearly an hour to format, so don’t be alarmed if your's takes a while. Once the format completes, your new hard drive will now show up in My Computer and you can start putting files on it.
Dec 24, 2009 | Toshiba (MK1031GAS) 100 GB Hard Drive
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
