Question about Thetford Porta Potti
Needing one sheet of instructions for Bravura RV toilet repair ki
I only have page 1 of thetford bravura RV toilet mechanism repair Kit part #31112. Form #31142 I have, need next one?
3 Suggested Answers
SOURCE: We have a water leak on a Thetford Style Plus
Thetford says that the vacuum breaker is usually at fault. I have the same problem. Try changing the vacuum breaker first (it is easier than the water valve).
Posted on Feb 14, 2011
  • 24 Answers
SOURCE: I have a thetford Model 31687 rv toliet. I get a
They don't have rebuilt parts kits that I am awareof, but you can get replacement parts for them at most any RV service center. They are pretty easy to repair yourself.
Tool Belt Diva
Posted on Jun 12, 2011
Bravura not recognizing an Apple TV signal
You need to connect using an hdmi cable from the appletv to the tv, and notice which hdmi socket on the tv you use (eg 1 or 2 or 3...) Then make sure the light is on green on your apple tv by using the supplied remote control to power it up. And then you need to make sure you have chosen the correct hdmi source on your tv remote control (eg hdmi1 or 2 or 3...).
Sep 16, 2014 | Televison & Video
Bowl turns on our thetford Aqua Magic Style ll rv toilet
the reason you are getting sewer gases are the wax seal under the toilet is not making proper contact with the bowl and flange....pull the toilet and replace the wax seal...buy a cant leak seal from lowes...may want to buy new bolts to reinstall...they sell plastic ones that you can cut easy after you tighten...make sure to shim the toilet if it moves...use toilet shims...also at lowes...this is why this happened to start with...it was not done right to start ...after all that caulk or grout bowl to floor...now you have a pro install...
Jun 18, 2014 | Thetford 42058 Aqua Magic Style II High...
IM NEEDING VERY DETAILED PHOTOS OF THE "NEW MOEN TOILET REPAIR KIT M5350". I NEED PICTURES & DETAILS ON HOW THE TOP OF THE VALVE UNDER NEATH THE GRAY TOP THATS IS ATTACHED TO A BLACK ALMOST LIKE A STOPPER...
Go to the following link:
http://www.moen.com/
Click on the "Support" menu near the right corner of the page.
Then click on "Parts & Instruction Sheets"
Then enter the model of your toilet in the search box.
There is also a menu selection for getting replacement parts for your toilet if you need to; just enter the part number or model number in the search box.
Good luck on your project.
Dec 02, 2013 | Home
How to fix the pedal flush on a Tetford Aqua Magic IV
I saw the other answers and what are they talking about. thetford is a rv toilet the two bottem pedals are control by cable one cable broke You just have to get pedal repair kit pull toilet out and repair I have a repair kit coming as we speak exact same problem
Apr 16, 2012 | Thetford Home
C200 toilet continues flushing
It sounds like the solenoid valve is stuck open. This is tucked away up inside the bowl
and the bowl needs to be removed to gain access. For a repair sheet email infoau@thetford.nl
Oct 19, 2011 | Thetford Porta Potti
We have a water leak on a Thetford Style Plus toilet installed in our 2 1/2 year old Fifth Wheel RV. The toilet flange bolts appear to be tight and there is no visual evidence of black water leak or...
Dec 23, 2009 | Thetford Porta Potti
Plunger on thetford c-200 cw
Go to Thetford web site, click on customer support, click on manuals,click on your model # and download the manual. It will be a PDF file. More than likely you have lost power to the toilet or you have a bad motor or the linkage has broke or become disconnected.There are many links on Fixya site to order parts or you can take your toilet to an RV dealership.
Mar 15, 2009 | Thetford Porta Potti
IS THE FLOAT ASSEMBLY (Mfg. p/n 08204) available
http://www.thetford.com/HOME/CUSTOMERSUPPORT/ProductManuals/tabid/265/Default.aspx
Follow the link above. This is where you will find the manuals to your RV toilet. You will probably find everything you need here are at least a phone number to speak to a real person. Good luck and I hope I was able to answer your question.
Mar 08, 2009 | Home
Thetford Porta Potti  Logo
151 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Mike Marcotte
Mike Marcotte
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
