Question about HP 4050: HP 4050 laserjet printer , 8MB ram, 1200x1200 dpi, 17 ppm speed, 2 paper tray 600 sheet, re...
Printer speed is erratic. Sometimes fast, sometimes very slow. How do I control?
  • 231 Answers
Check your paper type settings in the printers menu and the driver on the pc.
Some types of paper settings will slow the printer down for improve print quality.
Set thepaper type to 'plain' for best result
Posted on May 03, 2010
Cruise control trouble shooting
The cruise control depends upon input from the speed sensor to determine when to engage. The sensor may be erratic.
Jun 26, 2014 | 2005 Mercury Mountaineer
Hi my navy seal is in great shape however sometimes it runs fast sometimes slow and sometimes stops is this common? can it be repaired? or does it need a movement swap? any and all comments...
It sounds like the quartz crystal may be the problem, it must vibrate at a precise frequency which is critical in controlling the exact speed and thus translate into precision time. I would get the watch checked to if it can be fixed at a reasonable price.
Dec 23, 2010 | Navy Seal Luminox Dive Watch
I own a 2008 Honda Rebel 250. I am looking for a good manual to see why my motorcycle will not stay running. It will not idle.
Either the slow circuit of the carburetor (slow jet) is plugged or dirty. In this case you need take apart and clean your carb. Or you have changed from NO ethanol fuel to 10% ethanol fuel which will lower your idle speed and sometimes make idling erratic. In this case you can turn the idle screw in raising your idle speed or put in a larger slow jet and adjust the idle speed.
Aug 17, 2010 | Honda CMX 250 Rebel Motorcycles
Cant send or receive fax just get a fast busy signal when I try to send fax. please help
Normally a fast busy signal indicates a problem with the phone line. You need to call the phone company and have them do a "line check"
Sometimes they can fix this over the phone, sometimes a service call is required. No charge to you tho.
Mar 01, 2010 | Office Equipment & Supplies
The fan on outdoor unit sometimes starts normally, sometimes starts slowly and will get up to speed with a push or sometimes will not start at all. Loud hum when slow or stopped. Cools normally when it...
SOME MODELS HAVE A TEMPERATURE DEVICE THAT CONTROLS THE FAN WHEN REAL HOT IT WILL CONTROL THE SPEED OF THE FAN WHEN COOL OUT THE FAN WILL VERY FROM FAST TO SLOW DEPANDS ON THE HEAT BEING PUT OUT BY THE OUT SIDE UNIT IF THIS PROBLEM OCCURES DURING BOTH HOT AND COOL NIGHTS THE FAN MAY BE GOING BAD
Aug 22, 2009 | Heating & Cooling
Hard Shift 1998 Chevy 1500
Hello;
I need to know the codes so I can properly diagnois your problem. Here are a few tips though. Your electronics inside the transmission may be going out. You should start by changing the fluid and the filter. Let me know if there is a lot of metal or fiber shavings in the pan. Put new fluid in and clear your codes. See how it shifts and then let me know what is going on with it. Hope this helps.
Thanks;
Rich
RPM Northwest
Feb 12, 2009 | 1998 Chevrolet C1500
The cruise control on my 1993 Honda Accord LX, automatic 4 cylinder works sometimes and sometimes not. It worked three days ago. It wouldn't work the next day. The following day it would. Now it won't...
Sounds like possibly a safety switch associated with the brake or shifter is engaging intermittently. There is definitely one behind the brake because when you apply the brake the cruise kicks out. Try looking for this switch and check it out.
Nov 21, 2008 | 1993 Honda Accord
Fast Idle
Hello two major culprits off this is your TPS sensor wich controls the idle what you need to look at is when you start the car does the Rpm needle stay in a semi fixed position give or take a couple of lines or does it idle erratic it should be at a semi fixed if erratic it probaly is out of range you can test with a ohm meter if not autozone offers free testing on sensors The second problem wich sometimes can not be detected by a scanner and doesnt always set a hard code is your IAC motor IDLE AIR CONTROL VALVE wich is inserted internal into your throttle body on the end of this has a top shaped piece wich plugs a bore hole internaly inside if this is built up with carbon or varnish it binds internally causing higher idles, lower idles ,stalling, nostarts ,hesitation,rough idle, etc this mounts with usually to torx shaped screws also can be tested with scanner but dont rule this one out it can retract and extend register fine to the computer but bind internal with out ever setting a code goodluck please rate thanks
Jul 17, 2008 | 1995 Oldsmobile Silhouette
Erratic idle speed
Have the fuel pressure checked. Could be an erratic pump or pressure regulator.
Poppascott
Jun 27, 2008 | 1997 Buick LeSabre
104 people viewed this question
Seeker5211
Seeker5211
