Question about Intex 2500 Above Ground Swimming Pool Filter Water Pump ()
My Intex 2500 gal/min. pump sounds normal when it runs, but it doesn't pump anything. I made sure all air has been removed from the pump and filter. Anyone know what else I can do/check to see if I can get it to run properly?
  • 198 Answers
Check to see if the impeller is disconnected from the shaft of the motor
Posted on May 04, 2010
Pure Spa. where can I get an owner's manual?
Support - Intex
www.intexcorp.com/support/
The leader in Above Ground Pools, Airbeds and Inflatable Spas. ... Manual Pumps · Electric Pumps · Parts & Accessories · Electric Pumps · Floats & Toys · Pool Toys... If you don't find what you're looking for, get in touch with Customer Service.
2500 Gal Filter Pump (120v) - Intex
www.intexcorp.com/28633eg.html
Review the Trouble Shooting Guide in your Owner's Manual. Are any tools ... Can we use the pool while the filter pump is operating? Is it safe? No, due to ...
Oct 28, 2015 | Intex Pool & Spa
How to change water pump
Don't change with a like product from Intex - they are a toy.
Get a real pool pump - spend a little more $$$ and you will be so much happier with an upgrade.
Sep 14, 2013 | Intex 2500 Gal Easy Set Swimming Pool...
2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only: how to converte to larger filter...
You can simply buy a larger pool filter that is designed for pools in your size range. Look for one that is designed for smaller above ground pools. You can find lots of different pool filters at backyardcitypools.com.
May 17, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Brand new filter pump leaking
If it is brand new and leaking, it sounds like your pool filter has a connection problem. Check your connections to make sure that they are tight and sound and that you do not have any hairline cracks.
Jul 16, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Currently have a filter pump that hangs on side of pool. want to purchase a larger (1500gph)pump. these all sit on ground
I recommend upgrading to sand filter system. You can get a good one from Amazon seller for $305.00 delivered. Pump made by Waterway. (we are very pleased with ours). The intex pumps just aren't sufficient for the pools they come supplied with IMO. It's a little more pricey than upgrading an Intex pump, but so worth it.
I hope this has helped. Good luck!
Jul 09, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Water filter leak
If the water is leaking, it sounds like you have a connection problem or a hair line fracture in your pool filter. Check all of your connections for loose ones and you should be able to repair the leak.
Jun 26, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Intex filter model 633 with no instruction manual on how to set i
You can go to the website for Intex products and once you get to product section you can find and download a pdf manual
Jun 14, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
I have a 24 x 52 intex above ground swimming pool and I can't get the filter to properly work. It is taking water in but not putting water out
You must open the little valve on top to let out the air, then screw it back on when water reaches the top,  and ensure both gates are open.
Mar 23, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Intex 2500 Above Ground Swimming Pool Filter Water Pump () Logo
115 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
