Question about Jenn-Air Freezers
Jenn air downdraft cooktop. We had a new Jenn Air
Jenn air downdraft cooktop. We had a new Jenn Air installed but, when turn the knob on one burner, the igniters come on all burners and won't go off?
    President:
  • 949 Answers
This is normal, Jenn Air along with many manufactures use one ignition module for all the burners. So when you turn one knob on all the ignitors on top will spark but gas will only flow to the burner with the knob on.
Here is a copy paste from a Jenn Air Owners Manual, I do not have your model number so I cannot be sure this is the exact phrase in your book.
I hope this helps!
To Set:
1. Push in and turn knob counterclockwise to light the burner.
All surface burners will click. Only the burner that has been
turned on will produce a flame.
2. Turn knob to anywhere between HIGH and LOW. Use the
following chart as a guide when setting heat levels.
Posted on May 05, 2010
Need installation instructions and owner manual
Call the company,they will either mail you one or give you a website to download one.
Jan 27, 2013 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
We have a Jenn-Air Refrigerator/Freezer (Model #JRSD226) and the ice maker has stopped working.
Check for blockage in the water line in the freezer. If so, defrost it. Might need a new water valve. Maybe a bad ice maker too.
Another possibility is that it's not cold enough in the freezer. Should be below +10F.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 25, 2011 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn aire refrigerator not completely freezing ice cubes
Increase the inside coldness by rotating the termostat switch nob to a higher number position.
Oct 03, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Blades in my Jenn Air ice maker are not turning, ice maker no longer producing ice. Model JTB1988AE.
There may be some ice buld up blocking the lever from turning. A blow drymay be a quick fix. I can't see in there so just guessing. Please leave a good thumbs up for the effort. The Raz Shack
Mar 09, 2010 | Freezers
Just installed refrigerator. how long does it take to make ice the first time
The icemaker has a thermostat built-in that calls for water from the water valve at a certain temperature. Ideally, the freezer temperature should be around 0 to 10 degrees. Ice production, depending on temperature, should initiate around 6 to 8 hours later (assuming that the door remains closed most of the time).
Feb 19, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Our 12 yr. old jenn air refridgerator freezer ice maker has not shut off twice and ran all over our kitchen floors. What can be done?
I HAVE THE SAME PROBLEM. AN APPLIANCE REPAIRMAN SAID IT WAS A MANUFATURER DEFECT. SUPPOSED TO BE A SIMPLE FIX. I HAVE NOT HAD THE TIME TO GET IT DONE.
Dec 27, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Locked freezer
Press and hold the lock button for at least 3 seconds
Feb 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Freezers Logo
570 people viewed this question
Top Jenn-Air Freezers Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Bailey's...
Bailey's...
Are you a Jenn-Air Freezer Expert? Answer questions, earn points and help others
