Question about BenQ PB6100 Multimedia Projector
Changing sources with no controller
From video mode to computer mode
  • 616 Answers
---its probably tough to do.
Posted on May 02, 2010
I cant figure out how to put the tv on video 1
With the remote in TV mode, the input button on the remote should change the source (TV, AV1, etc. depending on the TV).
If the input button doesn't work, try a different code for your TV manufacturer. A code that controls the basic functions of the remote may not control the full set of functions of the TV. For some TVs, you can change the source from within the Menu. (It depends on the TV. I didn't notice if there was a Menu button that will open the TV menu on the RCA RCU600M.)
If none of the codes work, check if your TV has a Source or Input button on the unit. See if that button works.
If you have a different remote, please indicate the model.
I hope this helps.
Oct 13, 2011 | RCA RCU600M Remote Control
I have a Plus UP 1100 and the remote control was lost. How can I switch from video mode to computer mode manually?
hi,
you can select the RGB mode (computer mode) by the following without remote.
1. press the menu button
2. with up arrow or down arrow select source menu and press enter
3.press up arrow or down arrow to select RGB AUTO and press enter
4. press menu button to exit menu.
ok
Jan 27, 2011 | PLUS Vision Corp. UP-1100 Multimedia...
I have an RGB port on my visio, but my remote does not have any buttons to get to RGB mode, I have all the others like HDMI AV and component... How do i get to RGB mode if it is not on my remote. going to...
There is a video/input/source buuton on the side of tv. Push it and all inputs will be there use volume control to move the highlighted input when you get to the one you want push input/video/source it will change the channel
Dec 13, 2010 | Vizio Televison & Video
Volume control works in DVD mode but not in TV
Where is your TV sound coming from? Is there a volume control at the source?
May 05, 2010 | Denon AVR-485 Receiver
When I turn the tv on, it comes on in DVD mode and won't change over to the tv mode.
You have two ways to change it to TV Mode.
1 - remote control (source button) -cycle through the options.
2 - side of the unit (source button) -cycle through the options.
If the remote doesn't work, try using the button on the TV to change the source mode.
If this doesn't work, you have a problem with the TV.
Another option is to check your inputs. If you have the input for the DVD in the wrong place, that may also be causing you the inability to change from DVD mode.
Apr 28, 2010 | Akai LCT2721AD 27 in. LCD Television
My monitor is stuck on safe mode
It's possible that your computer is not booting to safe mode. Possibly the video settings are not set correctly or the driver is not properly installed in your computer. You can try to change the video settings of your computer by:
1. Click Start
2. Click Control Panel (Switch to "Classic view" if not in classic view)
3. Click on "Display"
4. Change the "Colors" to the highest
5. Drag the slider to the highest resolution
If you are not able to change the video settings, you can just update the video driver of your computer.
Dec 30, 2009 | Computers & Internet
I'm trying to hook up my Acer Aspire x1700 to a Yamaha HTR - 6130 AV Receiver using the Optical digital audio cable plug. Not getting any sound, not sure what source to set on the receiver.. talks about...
You can set the receiver to any source that uses a optical connection. Then make sure that whatever you select whether it be CD/DVD you also have the source connection set to optical too on the receiver setup menu.
That being said, after that is done you will need to set up the computer to output audio. That usually just involves changing the output mode on the computer and adjusting the levels...open the Acer audio managment application, choose the audio output mode to stereo or dolby digital and turn everything up on the computers level controls. Then, when you open whatever software you're going to use to play your discs you may also have to adjust the volume level there as well.
Apr 30, 2009 | Yamaha HTR-6130 Receiver
Cannt get tv to change chanel
Check the mode the tv is on (Use "Source" button on remote to change modes). There are several modes to choose from.
Jul 16, 2008 | Akai LCT3201AD 32 in. LCD Television
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Feb 16, 2008 | RCA G32665 32" TV
How to change from video mode to cable/Antenna Input without a Remote
Alot of Zeniths have menu for that, have you tried to press the channel up button?
May 15, 2007 | Zenith A25A11D 25" TV
BenQ PB6100 Multimedia Projector Logo
61 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
