Getting back my files =P
The undelete was a good solution,thanks. but now i am scared of overwriting them because free undelete says they are already there on drive:c. do i overwrite them to get them back?
  • 55 Answers
You can use a thumbdrive or an external HD to restore to if you have one laying around. If C:\ is your only option, then C:\ is your only option. :-/
be sure to limit what you are doing though, every time data gets written to C: there's a risk of data loss- even temporary internet files.
Posted on Mar 25, 2008
  • Anonymous Mar 25, 2008
    it *shouldn't* overwrite your files, but i can't promise that it won't. the possibility exists, or they wouldn't warn you of it.
SOURCE:
Hi there, my HtC chacha was low on memory and advised me to delete data, by mistake i deleted all media files which means photos and all sounds liek ring tomne/alarm and so on. is there anyway to retrive...
there are many free data and file recovery programs on the web
you could retreive themif you have not written or downloaded any and saved more to your hard drivehttp://majorgeeks.com/Free_File_Recovery_d6792.html
Free File Recovery is a small and easy to use application that will help you to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user errordigital cameraclip_image001.gifmemory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
http://majorgeeks.com/NTFS_Undelete_d5532.html
NTFS Undelete is free software that allows you to recover deleted files. It recovers files directly from hard drive, and it will work even if you empty Recycle Bin.
Before downloading NTFS Undelete, please consider the following:
When you delete a file, its content physically remains intact on the media, but the occupied space becomes marked as free. Next file saved to the disk may overwrite the contents of the deleted file.
It is very important to make sure that no application writes to the drive or partition where deleted file is located since every new file (even a small one) may overwrite the deleted file.
hope this helps you
Oct 17, 2011 | HTC Chacha Smartphone
Tip
Delete An "undeletable" File!
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 10, 2010 | Computers & Internet
Tip
Delete an undeletable file...
Delete an "undeletable" File.
At the command prompt type DEL <filename> where <filename> is the file you wish to delete.
Close Task Manager.
Or you can try this:
Open Notepad.exe
Click File>Save As..> locate the folder where your undeletable file is Choose 'All files' from the type box
Click once on the file you wanna delete so it's name appears in the 'filename' box.
put a "at the start and end of the filename (the filename should have the extension of the undeletable file to is will overwrite it)
click save,
It should as you to overwrite the existing file, choose yes and you can delete it as normal.
1. Start
2. Run
3. Type: command
7. Now to delete the file type in del ***.bmp, txt, jpg, avi, etc... And if the file name has spaces you would use the special 1st 6 letters followed by a ~ and a 1 rule. Example: if your file name was bad file.bmp you would type once in the specific folder thorugh command, del badfil~1.bmp and your file should be gone. Make sure to type in the correct extension.
on Feb 11, 2010 | Computers & Internet
Memory card is yours and in my Easy share kodak I seem to have erased them all. Poss to restore
What is needed is an "undelete" program. These types of programs work very well when the data has not been overwritten. If an overwrite has happened, a portion of / or the entire file that was overwritten will be lost. This is very similar to the way the "Recycle Bin" in Windows works.
Some of these programs are free, some offer a limited trial and some will not allow use at all without paying for a license. There are different scenarios that each program works best in. Here is a list of some of the programs that can undelete files (not just picture files). Review them to see which suits your needs best.
Oct 11, 2011 | Cameras
Tip
Delete an undeletable File
Open a command Prompt window and leave it open.
close all open programs.
click Start, Run and enter TASKMGR. EXE
Go to the Processes tab and End Process on Explorer. exe.
Go back to the command Prompt window and change to the
directory the AVI ( or other undeletable file) is located
in.
Go back to Task Manager. click File, New Task and enter
close Task Manager.
or you can try this
Open NOtepad.exe
click File>Save as..>
choose "All files" from the file type box
in the "filename" box
pur a " at the start and end of the filename
click save,
1. Start
2. Run
3. Type: command
5. If you cannot access the folder because it has to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces.
7. Now to delete the file type in del ***.bmp, txt,jpg,avi,etc... And if the file name has spaces ypu would use the specific folder throgh command, del badfil~1.bmp and your file should be gone. Make sure the type in the correct extension.
on Jan 31, 2010 | Computers & Internet
SOFTWARE ON THE STICK WAS DELETED HOW DO I GET IT BACK
connect the memory stick to computer, and then download professional file recovery program, recommended asoftech data recovery as it helped me before.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Mar 07, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I deleted all files on my Mp5 epower player
THere is a software called free undelete that can help you recover deleted files from literally everything. Since mp3 players show up as drives when connected to a PC you should be able to scan it with free undelete and recover all the files to their original location. You can get it from
http://www.officerecovery.com/download/freeundelete.exe
Usage is simple. Connect your player to PC. When it shows up as a drvie launch free undelete and scan you player(removable disk). When it finishes scanning, select all files, then right click on one of the files and click recover. Hopefully your player will be back to normal.
Good Luck,
Sai.
Feb 06, 2009 | Panasonic SV-MP510 MP3 Player
I have a canon powershot a300 annd I accidentaly foramted my flash card when I was trying to look at my photos how do I get them back?
Don't Panic, It is very easy to get these photos back, you need to get an 'undelete' program. The best one I have used that is free is called 'undelete plus'
*IMPORTANT* DO NOT take any more pictures if you want to revcover the lost ones. as this will OVERWRITE the ones that where deleted. ok now,
click on this link to download undelete plus, http://undelete-plus.com/files/undelete_plus.exe
or this link to go to the home page of undelete plus http://undelete-plus.com/
Once you have downloaded it and installed it, plug your memory card or camera into the computer, On the Left hand colmn of the undelete plus interface, select the drive that represents your camera (or memory card) then click start scan on the top left corner. it will scan and pick up your pictures and PRESTO there you have them!! Once it has finished scanning simple select the pictures you want undeleted and select 'Start Undelete' from the top task bar.
Sep 14, 2008 | Cameras
Computer Lost Files
So many possibilities, it's difficult to know where to start.. I would look for some recovery software.. It's easy to use and there are several free versions around. Eg File Scavenger, Ontrack easy recovery, Active Undelete enterprise etc.. etc. It's important to try to recover your files before you overwrite them.. Although most of this software can still recover it after that has been done. Quite good stuff really. Good Luck.
May 01, 2008 | Compaq Presario 5000 PC Desktop
Open Questions:
AOL MAil TelePHoNe NuMbER +-*/*-+{1^855^536^5666}#[email protected] +-*/*-+ CALIFORNIA This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 22, 2019 | AOL Computers & Internet
Computers & Internet Logo
Ekse
Marvin
Marvin
