Question about Kodak Easyshare M341 12.2MP Digital Camera with 3x Optical Zoom and 2.7-inch LCD
M341 My Camara stop to Function and the lens outside each time that press the boton to on Does noise and the screen up 1 second and inmidiat turn off
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    What is "autofocus sensor" ?
  • 3,866 Answers
Ok what you got here is ether a stuck lens motor or a bad autofocus sensor. Each will require that you take it to a shop for repair. you can try to take the batteries out then place the m back in then try it but if all else fails you need to take it to a shop sorry to be the delivery boy of bad news but that is just what it is.
For my help and information all I ask is you do give me a positve rating or feedback, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 02, 2010
Testimonial: "Im happy with the awser"
My kodak m341 won't turn on......when you press the on button, the lens comes out, then goes staight back in. The screen comes on for a split second when the lens comes out. that is all it will...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 01, 2011 | Kodak Easyshare M341 12.2MP Digital Camera...
How can I reset my Philips 37 in flat screen TV back to the factory settings?
You haven't mentioned the model no. of your TV. Nonetheless, the reset procedure for the model nos. 42PFL7409/98 / 42PFL7409S/98 goes like this:
1- Press Home,
2- Select [Setup] > [Installation] > [Factory
settings],
3- Press play to enter the [Factory settings]
menu
[Reset] is highlighted,
4- Press OK to reset to default settings.
5- Press Home to exit.
The reset procedure may differ for other model nos.
Furthermore, Press the "Menu" button to access the menu, and select "TV Settings" and then "Picture" to bring up the picture settings. Adjust the color, brightness, sharpness and other settings if the picture seems off. Select "Dynamic Contrast" to have the contrast adjust to screen changes and "Digital Noise Reduction" to cut down on outside interference and reduce noise in the signal. On the "Installation" menu, select "Reset AV Settings" to have the settings reset to their factory defaults.
I hope the above helps.
Good luck.
Jan 11, 2011 | Philips Televison & Video
Dp 1 doesn´t function when the SD-card was returned to the camera
Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
May 27, 2010 | Sigma DP1 Digital Camera
Strange noises
This camera has an auto lens. Which means it will focus automaticly evey sec. you can turn this option off:
1: Go into the menu
2: Chose option Cam Setiings
3: Swich AUTO focus to single lens and click OK.
Dec 10, 2009 | Kodak Easyshare M341 12.2MP Digital Camera...
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
Camara wont power up
I have a similar problem where the product stopped working and froze. No buttons worked, replaced batteries seveal times.
Spoke to Hp Customer service where they stated buy another camera??? It was out of warranty for about 2 months.
So I bought a Kodak camera with great customer support and will never buy another HP Product again.
My problem was solved!
Nov 05, 2007 | HP Photosmart M417 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Kodak Easyshare M341 12.2MP Digital Camera with 3x Optical Zoom and 2.7-inch LCD  Logo
351 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
