Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Water is only luke warm, have adjusted thermostat and reset but nothing happens
  • 32 Answers
It sounds like you have a problem with a motorised valve.first thing to do is find the valve(connected to pipework)and check that its getting power to it with a tester.if there is power getting to it then you will have to take a note of the make and model number and get a replacement head for it(local plumbcentre).there is no need to undo any of the pipework as changing the head is usually only a couple of screws to remove and a couple of wires which will probably go into a junction box.
hope this helps
Posted on May 02, 2010
Water is not getting hot enough
thermostat set too low.
leak in hot water line or hot water being used too fast.
defective thermostat
Dec 09, 2014 | Reliance Water Heaters
Instant hot water tap - hot steam but delay and no hot water
This unit is set way too hot. The steam is pressuring the water out of the unit.
Feb 18, 2014 | Emerson InSinkErator C1300 Chrome...
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
Hot water wont get hot
1-First check for power to water heater and remove acces panels on heater to check power at thermostats. Thermostats have a reset button on them that trip and can be pressed to reset.
2- If none of the above have changed any thing and you have power you may have elements gone bad.
If an element is gone at top you will get scalding hot water then go to cold.
If an element on the bottom is gone you will get luke warm water then will get cold.
May 17, 2010 | Water Heaters
My jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
Apr 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Extreme hot water then to consistent luke warm
Possible thermostat problem. Are you experienced enough in that area to do some testing. Have a multimeter? If not experienced, don't try it, too dangerous. Call in a service person.
Mar 07, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Whirlpool self-cleaning water heater--water is hot sometimes, sometimes lukewarm regardless of usage. Even after sitting overnight to recover it might be lukewarm. Sometimes after using it off and on all...
I dont know if this is going to post twice but I need to make sure you get it. I sent one asking if this "luke warm" effect occurs during any specific time frames as "self cleaning" water heaters flush the system from time to time. It may in fact be your thermostatic control assembly which sits on the front of the water heater. Let me know about the frequency of the "luke warm" spells and we will see if we can narrow this down.
Thx
P.S. If it is your thermostatic control do not change it yourself unless you know precisely what you are doing. If installed incorrectly they can be very dangerous and life threatening.
Aug 15, 2009 | Water Heaters
CARVER CASCADE 2
Hello .. when an electric water heater only gets warm, it is usually the thermostats. I would replace the thermostats, make notes where the wires are connected .. make sure after replacing that the back of the thermostat is flat against the metal of the tank.
Please Vote !!
Jul 05, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
Water Heater Heating Problem
i guess it is electric ,check bottom element reset button .remove bottom cover with power off look for a button on bottom thermostat or limit if find push it to reset ,,then set the thermostats , set top to desired temp and the bottom at least 10 degrees more ex. top 130 bottom 140 this might prevent problem reoccurring if this not problem bottom element could be burned out.replace ele
Nov 30, 2008 | Water Heaters
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
66 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
