Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need a drive belt diagram for a Craftsman LT 1000 917.273520
The drive belt has come off of one of the pulleys. What is the best way to get it back on and in the correct configuration. It is an Craftsman LT 1000 Automatic 917.27.3520
  • 246 Answers
SOURCE: i need a owners manuel for Craftsman LT 1000 Model# 917.272650
Hello bostont1228:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. You can Also Enter "Owners Manual" in the Search Box and it will Direct you to the Page you Require.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
GM Elec
  • 1000 Answers
SOURCE: mower stopped moving
If this is a manual transmission, check the drive belt from the engine back to the transmission. With the clutch pedal up (engaged) there should be no slack in the belt.
If it is a hydrostatic drive, check the drive belt and make sure it is tight. Check the transmission fluid level and make sure it is full. Refer to your owners manual as it will describe the fluid check proceedure.
Good luck, let me know.
Regards,
Posted on Jul 14, 2009
SOURCE: craftsman LT 1000 deck belt diagram
my clutch belt will not stay on the pulleys Craftsman 42 in. LT 1000
Posted on Aug 20, 2009
  • 138 Answers
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Posted on Aug 25, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
How to install drive belt for craftsmen lt 1000
Remove deck belt from engine pulley, then remove the idler pulley for the drive belt, remove drive belt and reinstall.
Jul 11, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Drive belt diagram model 917-276051
the closest thing to a "drive" belt diagram would be in the owners manual http://www.manualslib.com/manual/487688/Craftsman-917-276051.html?page=38#manual
the horizontal (front) end would be to the pulley at the engine that the deck belt(s) are not attached to. There is a set of mid pulleys where the direction is changed from horizontal to vertical for attachment to the transaxle.
Jul 01, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Drive belt routing
Parts and Diagrams for Husqvarna LT 18542 954571748 2003 11
OH BOY, lots of information. one belt runs the DRIVE LINE. one belt will run the CUTTING DECK. check out the link.Hope this helps :)
Apr 12, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need a belt routing diagram for a 15.5hp craftsman kohler command model #917259542
With the model number you have you can search for craftsman parts and go to sears and enter the model number and select the deck and find the replacement belt routing sticker for your deck. It goes on the top, left, front.
The belt comes from the motor pulley in between the pulleys in the middle and around the back of them, then out to the front side of blade pulleys, around the outside and straight across the back from blade pulley to blade pulley. Not a hard routing. If looking down on the deck from the seat it will look like an inverted T. Watch out for the belt keepers that help keep the belt aligned in the pulleys, may need to gently retract them to get belt in the pulley.
Jul 07, 2011 | Craftsman Garden
I posted the below problem last night with the request for additional information reply sent 2 hours ago. I need to use this mower today. I need to have an answer. THanks Problem with the...
Thought I posted a solution earlier on this, but it was my first post and I don't see it here so I'll try again.
Google search on your model shows the drive belt diagram on page 27 of the manual.
link below:
http://www.mytractorforum.com/images/reference/dgs6500.pdf
Looks like mine.
basically need to remove front pulley by loosening center bottom bolt while holding the center nut on top of motor.
Slip belt over the rear pulley first and then straight toward the front, slip belt on front pulley and then slide pulley back onto shaft.
Then wind through the rest of the pulleys etc..as seen in the diagram.
Jun 08, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Could you send me a diagram how the drive belt goes around the pullys thanks its a craftsman lt 1000 not sure of the year model
Hi and welcome to FixYa, I am Kelly.
Here is the diagram:
http://www.brandywineits.com/graphics/LT1000/PulleyConfig.jpg
One of the major problems on the LT 1000 is that the belt gets installed wrong side out. Just make sure the V of the belt rests in all of the mandrel and drive pulleys correctly.
Thanks for choosing FixYa,
Kelly
May 04, 2011 | Garden
Need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
Jul 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT 1000 deck belt diagram
Jul 11, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman LT1000 mower
In the Google search box type belt and pulley diagram craftsman lt 1000.....then Search images. The first 4 images feature "springs" however, you can clearly see the motion belt diagram. Hope this information is helpful.
Rox.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
390 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
