Question about GoVideo Go Video DVD/VCR Combo
Can we record from our direct tv box to our Go Video2140
  • 74 Answers
Hi
yes this should be possible , if the correct connection are made beween the digal box and the recorder and the a/v input is selected on the recorder.
regards windyhouse
Posted on May 02, 2010
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to connect the toshiba to a rca tv with direct tv
do you have dvd in jacks on your rca...direct tv out to dvd in.....(this setup u need to scan for channels on the dvd)..note some premium channels will not record on dvd (will and still record on vhs)
May 29, 2010 | Toshiba DR410 DVD Recorder
I cant seem to record on to my VCR but have no trouble playing old videos,is this because the VCR is old and therefore not digital? Retuning the TV with a box was no problem.
In order to record from the tv onto vhs, it is required that you have a tv signal coming straight to the vcr. If your converter box is plugged into the tv alone then the vcr won't record. To fix this, try plugging your converter box directly into the vcr, instead, and then plug the vcr into the tv. You may have to retune the channels. Good luck!
Apr 07, 2010 | Panasonic Televison & Video
Unable to down load TV programs from my L19W861 Envision Series T
The best way to record is to connect the recorder directly to the source (cable or satellite box) and then connect the recorder output to the TV.
Feb 25, 2009 | Televison & Video
Recording cable channels while warching other channels
To be able to watch one, record another, you have to split the cable when it comes into the house. Have one input go directly into the TV and the other into the Cable Box. Then hook the cable box to the DVD, then to the 2nd input of the TV. You will have to switch back & forth from your TV video inputs, rather than switching at either the DVD or Cable Box.
Jan 31, 2009 | Sony RDR-VX521 DVD Recorder/VCR
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Stupid question recording on a vcr
If you have a cable box:: the RF cable from the outside to BOX, the BOX to the INPUT of vhs video, the OUTPUT of video (VHS) to the back of TV.
Keep the channel for the reception of tv through CABLE BOX according to cable box directions.
Put the ch. on the cable box to ch. u want to record...place blank vhs tape ( with the TAB in back NOT broken off ) press [record] usually red button.
Oct 27, 2008 | Televison & Video
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
GoVideo Go Video DVD/VCR Combo Logo
43 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
