Question about Orange SPV M500 Smartphone
The phone turns off each time i attempt to put it on. It only boots on when connected directly to power mains.
Posted on May 18, 2010
My gateway laptop N214 will not turn on. The orange light at the bottom of the screen flashes but it will not turn on.
Unplug the power cord. Remove the battery and hold the power button for 30 to 60 seconds. Re-connect the power and attempt a boot. Shut down, put the battery back in and you're good to go. This advice was on another site, but helped me with a computer startup issue once
Nov 16, 2013 | Gateway Computers & Internet
My notebook will not boot properly, and date and time resets.
please use this small secret. Disconnect the power adapter from computer 2) DISconnect the battery from laptop.
3) Press the main button power for 60 seconds exactly. This method discharge any ESD. keeping in the system. and try again, will be work.
However if the problem persist see the flow charts. attached.
Mar 06, 2013 | Computers & Internet
SONY VAIO Pcg-71511m - Intermittently powers on after Screen Replacement
It seems your DC socket is suspect, as sometimes it connects and powers on and at times it doesn't. replacing the DC socket on the motherboard should cure it.
Jan 15, 2018 | Sony Computers & Internet
When i press start on the main menu it says (Loading settings "settings" from hard drive. Please do not turn off your xbox 360 console...) and it freezes, how can i fix this?
Ok I have seen this issue many times before , first unplug the console . Disconnect the power cable , a/v cable , controllers , any usb devices , & finally disconnect your hard drive . Now let the system sit for a few minutes , then plug in just the power , a/v cable , & a controller . You should be able to boot your Xbox 360 successfully now . At this point you can either connect your hard drive while the system is running or you can turn it off & connect it . This should fix the issue , if not you can attempt to clear the system cache in the Settings Menu or worst case download the latest update from Microsoft on your Computer , then follow the instructions & place it on a freshly formatted USB Memory Stick . Then place the USB Memory Stick in the 1st USB Port on the Xbox 360 & boot the console .
Apr 15, 2011 | Microsoft Xbox 360 Console
HP NC6000 boot failure.Fan starts but quits after 10 secs or so.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 22, 2009 | HP Compaq nc6000 Notebook
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.Some time it boot up and run but then it won't do it nextime after it been power off. Battery for BIOS is good, Main...
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | IBM ThinkPad T30 2366 Notebook
Replaced dead power supply computer still dead
hi
most power supplys are protected against faults when they are connected to damaged equipment
so it possibly just protecting its self
disconnect everything from the PSU except your MB
try to turn on
if your pc boots ok
re connect everythng else one thing at a time attempting to boot each time
when it wont boot you have found your fault
Feb 07, 2009 | E-Machines D2046 PC Desktop
Lg EnV VX9900 CLR Button Resets phone.
When you hit the clr button it will go back to the screen you where prior. When your booting up, it will show the Vcast screen. Maybe check your backlight setting.
Jan 17, 2009 | LG enV VX9900 Cellular Phone
Canon mp730
no no not to do any thing related to computer.remove all the connections connected to the printer from computer.just connect the printer to the main power outlet and then ON the printer and then when the head moves just at that time remove the power cord quickly from the outlet in the ON position directly.and then pull that black band it will come out slowly slowly as you pull.do not apply force on that band do it very slowly.
Sep 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Orange SPV M500 Smartphone Logo
73 people viewed this question
Top Orange Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Andrew Taylor
Andrew Taylor
Are you an Orange Computer and Internet Expert? Answer questions, earn points and help others
