Question about Garden
I have an atco commadore B20 that cuts out when I
I have an atco commadore B20 that cuts out when I pull the lever to engage the cutter deck. It restarts ok but each time I pull the lever to engage the clutch for drivng the cutters it cuts out. It is not a ride on.
This seems top happen after it has cut for 10 mins or so. It runs ok for about this time then starts to cut out.
    President:
  • 2,702 Answers
It could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
Posted on May 02, 2010
JD L110 cutting out when reverse peddle is depressed. Cutter deck is not engaged
Sounds like the safety switch, at the cutter deck lever, failed
Dec 23, 2017 | Garden
Fuse keeps on blowing when I engage the cutter deck
Check that a wire has not been cut. Check the PTO clutch wires as well.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Sep 28, 2015 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
John deere
Is there a safety switch anywhere you overlooked?
Sep 01, 2014 | Garden
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 10, 2013 | Garden
Bogs when blade is engaged
for this to happen you must have a bearing problem either in the gear box or cutter deck that has seized from rust or failed bearings. disconnect the cutter belts and see it t moves forward freely If so then turn each cutter spindle by hand and find which one won't turn or is rough in the movement.
Jun 09, 2013 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
The blades will not engage when the knob is pulled....toro 50
.... burning rubber smell? Sound like you have done a cutter belt.
May 27, 2012 | Toro Garden
I have an atco commadore b20 that cuts out.
sounds like it may be a safety switch prob check the seat switch
Jul 29, 2009 | Garden
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
May 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
379 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
