Question about Linksys Wireless-G WRT54G Router
Wireless-g tried to connect my wireless g wrt54g. i gave it the wrong password to my internet axis. now it can not connect to the internet through the wireless g. i can not figure out how to enter the correct password to the internet when connected to the wireless g. i can connect when not hooked up to the wireless g. i tried to follow directions but it just is not working
    Scholar:
  • 89 Answers
Hello, You can reset the router to default. On the back of router push in the reset button/hole for 10-15 seconds. The defaults will be: IP address 192.168.1.1 User name admin. You shouldn't need a password. From there you can change username, password, SSID and enable WEP or WPA security. Hope this helps.
Posted on Mar 26, 2008
  • Robert Klippel
    Robert Klippel Mar 26, 2008
    Well I made a little mistake. The Use name is left blank and the password is "admin". D-Link router are opposite. Good Luck.
Trying to connect my kindle to wifi and it keeps asking for password. Don't know the password.
when you attach/setup this router
if this has a built in modem the one that you connect directly to the net the password will be the one you gave your ISP internet service supplier you might have to ring your ISP and get them to check your connection online
hope this helps
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
I CANT REMEMBER MY PASSWORD for my internet access, have got a new laptop and cannot connect
TO GET THE WIRELESS PASSWORD
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer
Step 3 : Default password is admin
Step 4 : Click wireless
Step 5 : Choose wireless security
Step 6 : Here you can find the Password
Step 7 : Try to connect with this password
let me know if this works
Regards
TOM
Dec 26, 2010 | Linksys Wireless-G WRT54G Router
My linksys wrt54g can not hook up to the internet via my at&t modem do i need to change any settings whithin mu computer
Hi.
Are you Using a username and password for your AT&T internet connection? if yes, then try this
press and hold down the reset button on the back of the router until the power light starts blinking. power down the router for 1min.
wire your computer to the #1 port ( modem is not connected to the router )
open internet browser, type 192.168.1.1 on the address bar. type "admin" on the password field.
then you will be able to see the routers' configuration page.
under Internet Connection Type, set it to PPPoE and type your Username and Password that AT&T gave you. scroll down, look for "LAN ip ( usually is in 4 boxes that has 192.168.1.1 ) ". changed the number to 192.168.5.1. then save the settings
just connect your modem to the router, you should be good by then.
if you're not using a UN & PW from AT&T, just changing the ip to 192.168.5.1 will work.
please rate me.. :-)
Sep 14, 2010 | Linksys Wireless-G WRT54G Router
I can connect to the internet with my lap top trough my Linksys Router WRT54G because every time i try to connect is asking fo a security code number
Hi
On your wired computer, opened internet explorer and type 192.168.1.1 or 192.168.0.1 then press enter.
It will ask you for a Username and password, type admin on the username and type your Administrator password on the password field (default password is admin).
Then you will be directed to a setup page, go to the wireless teb then click on the wireless security tab. You will see your password there .
Hope I was able to help.
Sep 12, 2010 | Linksys Wireless-G WRT54G Router
I HAVE A WRT54G. I AM DROPPING MY WILDBLUE SATELLITE INTERNET SERVICE BECAUSE MY DIAUP IS FASTER AND MUCH CHEAPER. I WANT TO RUN THE NEW PHONE LINE TO A PC WHICH HAS A PHONE MODEM AND AN ETHERNET PORT. CAN...
The answer that he gave you is not accurate. In fact you can use your wireless over dial-up. This however takes a little work. You will need to setup internet connection sharing on your desktop with the modem. If you can get the sharing working, then you can use your ethernet card on your PC to transfer the internet back to your wireless router.
This will work, it has been a few years since I have done it, but I used it this way for several years.
Feb 01, 2010 | Linksys Wireless-G WRT54G Router
I have connected my wireless to the computer and modem and not getting an internet connection what am I doing wrong?
you need to login to the web page using the routers ip address and the usernamd and password which if its left to default will be username - admin and ignore the password field or visa versa ( ignore username field and password is admin ) click on ok and configure the settings into the router with regards to what settings your ISP gave you if you have a static ip address or a dhcp assigned one and any other relevant settings if required ( contact your ISP ( Internet Service Provider ) and they should be able to advise you further.
Apr 23, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection is showing unsecured wrt54g
type 192.168.1.1 in search bar
Pass: admin
Wireless > Wireless Security
Security Mode =WEP
Enter name in paraphase
It geneates codes
If your using a laptop with wireless copy all the codes down
I don't remember which one is right but when you try to connect on the laptop enter all separately and the one that works is the code that is required if someone trys to gain access to your internet..
Nov 28, 2008 | Linksys Wireless-G WRT54G Router
Can't load updates to my wii
you have it connected via wireless? try with cable.
Jul 16, 2008 | Linksys Wireless-G WRT54G Router
Computer
go to start--> settings--> network connections. right click on your wireless connection and go tp properties. Go to the wireless networks tab and you can change the password from there.
Mar 25, 2008 | Computers & Internet
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
75 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
