Question about Texas Instruments TI-30XA Calculator
How do i enter log (base 3) 3.3 on my calculator to approxiamate to the nearest thousandth?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Calculate it as log(3.3) / log(3) or ln(3.3) / ln(3.3).
Posted on May 03, 2010
7.2468901 rounding nearest thousand
I assume you want to round it to the nearest thousandth.
Step 1 - identify the thousandths column - going to the right of the decimal are tenths, than hundredths, than thousandths
Step 2 - check the number immediately to the right of this column
Step 3 - if this number is 5 or greater, add 1 to the thousandths column
Step 4 - if this number is 4 or less - no nothing
Step 5 - delete all numbers to the right of the thousandths column
In this case the 8 is greater than or equal to 5, so we add 1 to the 6 to get 7 and then delete all the numbers to the right.
I get 7.247.
Good luck.
Paul
Oct 27, 2015 | Office Equipment & Supplies
How to round 0.1875 to the nearest thousandth.
Step 2 - identify the number immediately to the right of this column
Step 3 - if this number is 5 or more, add one to the thousandths column. If this number is 4 or less, leave the number in the thousandths column
Step 4 - set all number to the right of the thousandths column to zero.
I get 0.1880, which we normally write as 0.188.
Good luck.
Paul
May 29, 2015 | Office Equipment & Supplies
Log 3 base 10
Press LOG 3 ENTER.
The LOG key on the keyboard gives you base-10 (common) logs while the LN key gives you base-e (natural) logs. If you want the log to another base you can use the logBASE function found in the catalog.
Apr 07, 2014 | Texas Instruments TI-84 Plus Calculator
Round to nearest thousand
Step 1 - identify the thousandths column - going to the right of the decimal point, we have the tenths column, the hundredths column, and the thousandths column
Step 3 - if this number is 5 or more, add 1 to the thousandths column - if this number is 4 or less, don't add 1 to the thousandths column (leave it alone)
Step 4 - erase all the numbers to the right of the thousandths column.
In this case, the number in the thousandths column is 4. The number immediately to the right of it is a 0. Since the 0 is 4 or less, we don't add 1 to the thousandths column. Now we erase all numbers to the right of the thousandths column. I get 22.524.
Good luck.
Paul
Oct 17, 2013 | Office Equipment & Supplies
How do i use log functions on the HP 39g+. For instance i want to use log10 1000 which should equal 3 or 3^5=243 so log3 243 should equal 5. If i press log the calculator shows: log( If i...
To calculate the common log ( LOG base 10) of a positive number, just press the LOG key, the one above the blue Division key, then enter the number and close the right parenthesis. Press the ENTER key to get the result.
If you want to calculate the log in a base other than e (natural) or 10 (decimal) logarithms, you need to make use of one of the equivalent formulas below
log in base a of a number b
log_a(b)=log_10(b) / [ log_10(a)] or
log_a(b)= ln(b)/ln(a)
Apr 19, 2011 | HP 39g Calculator
I want to know how to enter basic logs into the calculator: Example. Log3^9=2 How can you enter this into the calculator?
The 30XA only has logarithm functions for base e and base 10. However, you can calculate the logarithm to any base by using the relationship logb x = log x / log b = ln x / ln b
To calculate log3 of 9, press
9 LOG / 3 LOG =
or
9 LN / 3 LN =
Apr 03, 2011 | Texas Instruments TI-30XA Calculator
If i needed to enter log 5 to the base 3 into my calculator what buttons would i push?
You can calculate the log of x to any base b by calculating log(x)/log(b) or ln(x)/ln(b). So, to calculate log 5 to the base 3, press
LOG 5 ) / LOG 3 ENTER
or
LN 5 ) / LN 3 ENTER
Jan 25, 2011 | Texas Instruments TI-83 Plus Calculator
5^log(subscript 5) 3
The calculator does logarithms only to base 10 (common) and base e (natural). You can calculate the logarithm to any base by using the relationship logb(x) = log(x)/log(b) = ln(x)/ln(b) .
So, one way to calculate this is as follow:
5 ^ ( LN 3 ) / LN 5 ENTER
Note that the calculator automatically opens the parenthesis when you press LN, and you don't need to close them all before pressing ENTER.
Apr 20, 2010 | Texas Instruments TI-84 Plus Calculator
How can I use the Log function on my calculator?
Hi ;
for log base 10 use the the "log" key
example :
log(2) + log(3) = log(6)
enter 2 press the log key you will get 0.30102999 press the '+" key than 3 log you should get 0.47712125 for it Press the "=" or enter and you should get 0.778151250 for a answer than press inv or 2nd log and you should get 6 for a answer
and that all there is to it
Oct 07, 2009 | Texas Instruments BA-II Plus Calculator
Texas Instruments TI-30XA Calculator Logo
821 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
