Question about Coby TFTV2214 22 in. LCD TV
The audio one my cody tv stopped working as soon as i installed cable to it
  • Coby Master
  • 8,457 Answers
Unplug,replug the tv about an hour later let the reset itself.Go to the tv menu,go to AUDIO go down,than reset the tv audio.The audio now should return,not than the Tuner board is dead,must replaced the Tuner board to solved audio problems.
Posted on May 02, 2010
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
Bush 4.1 sound bar cuts out, connected via optical sound cuts out it is intermittent, happens on tv, dvd/blue ray and media player setting. Any ideas how to stop this happening. Have tried rca cables etc
I get a similar issue from my Bush sound bar. The sound drops out when the tv programme/movie etc has a period of silence in the audio track or just very low background music (no speech). As soon as someone begins to speak it starts up, but usually it misses the first couple of words. Bar is connected directly to a Samsung tv via the optical cable. Any ideas?
Aug 12, 2013 | Audio Players & Recorders
Audio somehow stopped working on my Sansui TV . I've tried resetting the tv, using both the cable and regular remote and I've went to the audio settings and tried changing things . I'm not sure what's
had a jensen that did the same so i bought a surround sound and hooked up through sat box hope this helps you save some money and get better sound
Jan 22, 2013 | Televison & Video
I have a SAA7130 Analog TV Card. I split the signal from a cable TV line to a Tv, where it works, to the cable connector on the card, which is in a PCI slot on my new COMPAQ Presario Model AY030AA#ABA...
Hi you should make sure the TV card is fitted properly into the slot and then reinstall the drivers for the TV card.
Please let me know if you any questions Thanks for asking
Jul 23, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
M-CODY M20 not reconised by my computer?
I've had similiar problem on my M-25 MP3 player. You just have to try unplugging and plugging it again till the computer recognizes it.
Feb 21, 2010 | Median m-Cody MX-300 MP3 Player
Why does the s video output on my dell latitude d600 not work?
You must have the correct drivers installed, and you must enable the output as a second monitor but to do that you must connect to the TV IN first. Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Feb 17, 2010 | Dell Latitude D600 Notebook
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Nov 22, 2008 | Sony Grand WEGA KF-50WE620 Television
Hdmi audio problem from tivo hd
Your tv is new? if it is then it has a remote link, Panasonic call it Viera link, Sony call it Bravia link. Check your tv if it has that, if it does turn it off.
problem should be solved.
Nov 12, 2007 | Onkyo TX-SR605 Receiver
Coby TFTV2214 22 in. LCD TV Logo
149 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
