Question about McCulloch Garden
Stihl hs45 blades not working .Spigot that turns to operate blades doesnt appear to be engaging the engine
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
  • 127 Answers
SOURCE: release brake engine dies engage blades engine dies
there is a saftey switch on the deck that has shorted out need to replace
Posted on Jun 30, 2009
SOURCE: stihl fs 45 trouble getting the cutting head to engage
repair shop shortened shaft just a touch to take up slack in drive cable
Posted on Aug 14, 2009
  • 138 Answers
SOURCE: engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Posted on Aug 24, 2009
  • 19 Answers
SOURCE: Looking for service manual for
This manual should have the information you need for common service jobs. Anything further and you'll need to take it to a Stihl service department.
Posted on Dec 14, 2010
My HS 45 seems to drip oil while cutting, I think it is damaging plants. Is it because there is too much oil in the fuel mix?
Fuel mixture for that model is 50 to 1. Stihl also sell their own premixed fuel and oil which is Ethanol free and non aromatic.
I wondered if it has a blade oiler, but it doesn't. I does however have a gearbox with oil in it. I wonder if it is leaking. Do you know where the excess oil is coming from?
You model is listed here and the Manual and details of the fuel are on his page.
STIHL HS 45 HomeScaper Series Hedge Trimmer
Oct 04, 2016 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
Hi there, Im looking for a repair/workshop manual for a Stihl HS80 hedge trimmer. Any assistance would be greatly appreciated. Cheers Gavin
Stihl don't publish manuals as such, they want to preserve their dealers. An HS80 is not complex and if you go to Barretts Small Engines online they have exploded parts pictures which should be all you need to strip it. Stihl do owners manuals online.
Sep 27, 2016 | Echo Stihl Primer Fits Hs80 Hs80 Hs45 Hl45...
Why is compression low and blades will not engage?
Low compression equals bad rings...
If the unit is fairly new, that shouldn't be a problem. If what you mean 8s that when u engage the throttle and it's not getting more power, check your carburetor setting. Look for the "H" . When you adjust this needle , hold the throttle in as you do it.
Aug 30, 2015 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
Blades do not move when engine running on hs45 sthil
Look for grease Zerk
xxxxxxxxxxxxxxxxxxxxx
May 20, 2014 | Stihl Garden
Stihl hs45 will not start but it will run after i use auto start
Check fuel lines, filter and carb... Sounds like a poor fueling issue. clean and replace carb diaphrams. Check gaskets between cylinder and carb.
Feb 23, 2014 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
Stihl HS45 hedge trimmer runs fine, blades move well, does not appear to cut hedge - what could be the problem ?
Dull blades! Lol, or they're not meeting eachother on each reciprocating stroke so there is no shearing action, much like a pair of scissors. Check to see if the blade bolts are too loose or is the blades are warped or if the cutting edges are simply too dull
Sep 24, 2013 | American Gardener Rh25 18" Readyhedger...
Hs45 backfires spits
Sounds like an over fueling issue, Try resetting the carb to its standard settings, screw both tuning screws right in ant then turn anticlockwise to the following settings H 3/4 of a turn. L 1 full turn. This should set it back to standard. If this doesn't help then it could be a carb diaphram or sticking needle.
Jul 15, 2013 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
Excessive fuel consumption
carb needs to be tuned. check your local repair shop.
Oct 24, 2012 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
Hs45 goes dead when I throttle up
Most likely a fuel starvation problem, check and clean carb,check fuel lines for air leaks
May 29, 2012 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
Garden Logo
152 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
