Question about Desa International CBN30T Central Heating System Heater
I have a fault with my halstead platinum boiler no Hw/CH
I have got a fault on my halstead platinum boiler when i switch it on there is no red fault light and the boiler sounds like there is alot happening however no hot water or central heating.
however i have noticed that the fan runs some times for a short time then seems to slow down as if there is a slow loss in power.
I have removed the fan cleaned it up and it is very free to turn.
i have tested the Differental switch operation as i thought that if it was that the fan was not creating the vacume.
i am at the moment assuming that it is a fault on the pcb with a bad contact on the relays.
Can anyone help please?
  • 139 Answers
SOURCE: My vent free Desa natural log will run for a short
it is likely you have dirty O2sensor, it is incorporated into pilot assembly.turn unit off,use compressed air in a can and blow into spot where pilot flames comes from.this will fix it in most a small % of time entire pilot assembly needs to be taken apart and cleaned
Posted on Jun 25, 2009
  • 33 Answers
SOURCE: no heating but still get hot water
Sounds like 3 port valve fault
Posted on Jan 17, 2010
  • 3182 Answers
SOURCE: Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Posted on Feb 01, 2010
Testimonial: "Thanks for your advice. I'll look into the Worcester, but I think it might be more than we can afford!! "
  • 3182 Answers
SOURCE: My new heating system is
okay could be a slight blockage in the pipe did he do a hot and cold flush on the system ? pump speed could be too high or low or they could be air lock in the system ,
Posted on Sep 04, 2010
  • 3182 Answers
SOURCE: my Worcester 24I combi boiler not working - I have
look on the worcester wed site you can down load amanual for this with a fault chart in it , look for a button red?? could be the res et poped out 2bar is too high should be 1.5bar hope this helps
Posted on Sep 26, 2010
Halstead 102 combi boiler dhw/ch run for 1second then goes off
You might try cleaning the flame detector. It sits in the combustion chamber and looks like a small bent nail fixed to the burmer [usually at the rear]. Use a medium emery cloth and make sure that the gas holes around it are clean and clear of debris
Apr 18, 2014 | Water Heaters
Correct signal does not seem to be sent from the controler to the boiler,either CH comes on or HW but not necessarily when they are supposed to. Boiler engineers have been out twice and both times advise...
we had one of these and found out the battery inside had failed. the battery is none replaceable. did try to replace it but it lost its memory and was only good as a switch. think when the battery fails it loses it memory and things start going wrong. so would say change it. now thinking on it should of changed the battery why having the old one on and taken the old one off after installing the new one.
Mar 03, 2014 | Honeywell Programmable Thermostat Heater
My lynx boiler is good on HW but no CH, what can I check for
Check pump is working , is diverter valve moving over to ch , is stat turned up is clock set on ch, is there air in the rads , is header tank full in loft if fitted , is boiler presssure right if a combi .
Sep 11, 2011 | Heating & Cooling
I'm trying to get hold of a Halstead CBX boiler 'user guide' and a Halstead RFTH1 room stat 'user guide'. Where can i get these docs?
Here is a site that seems to have everything in that line...
May cost you a few $$ but it will be worth it...
Halstead Boilers Ltd
Oct 02, 2010 | Heating & Cooling
Worcester Bosch 35CDi II banging & wild pressure (CH only)
Hi try bleeding the pump it sounds like air in the pump , but worcester do have a free tech help line look for there wed page on line hope this helps
Feb 16, 2010 | Heating & Cooling
Halstead ace high boiler making a whining noise when central heating is turned on also pressure reduces after about 4 hours, need to top up verey day.
Whining = pump bearings
Pressure reduction = pressure relief valve diaphragm either perished of gunged up - look for water coming out of the overflow pipe from the valve
leak in ch system look at all joints
Nov 30, 2009 | Water Heaters
How to check if pressure switch on halstead boiler 82 combi
Hi I am thinking what your tryig to say is the air pressure switch?
you can check this switch to see if the boiler works by removing one of the sensing tubes from it & by sucking on or blowing as this willactivate the switch you dont have to do it very hard, just gently as you will hear the switch clicking, if the boiler does fire when you click, in order for it to continue to ignite you may have to fold over the tube, when you release it the boiler should stop.if it does work then you will have to change the air pressure switch, but remember this can only be done by a Corgi Engineer
Dec 17, 2008 | Water Heaters
Desa International CBN30T Central Heating System Heater Logo
136 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
