Question about Refrigerators
I have an Kenmore Elite Side by Side Refrigerator...The freezer defrosted during the night but the refrigerator is working. The light is on in the freezer and the inside walls are cool to touch but nothing is freezing. What could be the problem?
  • lensuekids May 02, 2010
    I lower the freezer temp to a 4 and the refrig to 33; the freezer had been set on 5 the highest
    number; should I lower the freezer to a 3?
    Sue
    I have a Kenmore Elite side by side refrigerator. During the night the freezer defrosted; the light is on and the walls of the freezer are cool. The refrigerator side appears to be working find. What can I do?
  • 1,284 Answers
Hi, if the freezer actually defrost itself without your permission, then you need to replace the thermostat . When the thermostat temperature is reached , it will cycle the compressor off . When time to come back on , it will not start . Instead of turning the thermostat off , try tapping on the thermostat knob . If the unit starts , this will confirm that the thermostat needs replaced .
Take care
Posted on May 02, 2010
  • 11,800 Answers
Check the setting of the thermostat, the temperature is set too high. If it's correctly set and the compressor is constantly on then there has been a leak in the circuit during the defrost and that needs to be fixed by a professional and the circuit refilled.
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
I have the Kenmore Elite Model # 795.79773.901 and I keep getting Er 1F. What does that mean and what do I do to fix it?
Hi and welcome to FixYa, I am Kelly
I hate to just paste a link to the answer but this answer is quite thorough:
http://www.managemylife.com/mmh/questions/116713-getting-er-lf-fault-code-kenmore-elite-refrigerator
If you have frost build up in the freezer compartment it can impede operation of the fan. Frost build up is usually a secondary symptom of an automatic defrost system problem. i.e it is not defrosting... due to a failure of one of the following:
-defrost heater
-defrost thermostat
-defrost control
Hold the door light switch depressed and see if the light goes out and that the fan is running.
If the fan has failed the part number is around $60.00 usually. There are AC and DC fans in this unit.
Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-79579773901/0583/0161000/F1104078/00002?blt=06&prst=0&shdMod=79579773901
Thanks for choosing FixYa,
Kelly
Jul 21, 2011 | Kenmore Side by Side Refrigerator
My kenmore elite freezer works but the refrigerator is not cooling
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Kenmore 53642 / 53644 Side by Side...
Freezer side is working normal. Refrig. is not cooling .temp set is on more cool side. I cleaned condenser. Light bulb off during closing.
heatman101
Sep 08, 2010 | Kenmore Refrigerators
Refrigerator is somewhat cold as is the freezer side but the freezer side is not generating freezing temperatures. Same temperature btw the refrigerator & freezer. Model 596.50392001. Any suggestions?
Your refrigerator has a defrost timer located near the floor and behind the kick plate. Remove the kick plate grill and turn the timer slowly clockwise until refrigerator compressor stops running. Leave it there for about 30 minutes or until refrigerator restarts. During this time the refrigerator should be in the defrost cycle. Open the freezer and you will possibly hear a crackling noise or the noise of water sizzling as it drips from the evaporator to the defrost heater. If your refrigerator does not restart after this time then turn the timer again slowly until the compressor restarts. If you do this then the timer will need replaced If no defrost takes place during this time then we need to move to the rear of the freezer and unplug the refrigerator and do some test on the defrost heater. Let me know how this worked out for you. The part number for your defrost timer is 10530703
Thanks, Sea Breeze
Jun 24, 2009 | Kenmore 53642 / 53644 Side by Side...
The Freezer and Refrigerator has stopped working completely
first check to see if the compressor and fan on the lower back of frig is working,if it is then check the freezer to see if the freezer fan is working,if it is then find the defrost timer(most of the time behind the front grill or inside frig. or on lower back)turn it til it clicks,wait 30 minutes and see if it comes out of defrost(you k=will know this if the freezer fan comes back on,let me know what you find-mike
Apr 16, 2009 | Refrigerators
Side by Side Kenmore Elite
hi thanks for the question well you have a no defrost problem with no power go to the cooling nit you will see a small disc with 2 wires going to it buy one first its called a defrost termination switch replace the switch thanks the appliance doc
Sep 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
