Question about LG LA185HV Split System Air Conditioner
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
LG Ductless Mini Split System LAN125hv : display on wall unit reads "CA". Nothing in the owners manual talks about this code. Unit fan works, but doesn't heat or cool. Remote control communicates with wall unit. Heat pump doesn't run.
  • 2 more comments
  • gayla mettler adkins May 03, 2010
    no.
  • Brian Niten May 11, 2010
    Does the outside unit run?
  • Kay Nisbet Jul 08, 2013
    Yes, the outside unit runs and has plenty of coolant.
  • Anonymous Mar 28, 2014
    error code ch07
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
  • 674 Answers
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
Posted on May 03, 2010
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
No power at interior unit. power everywhere else
If this is a mini split ductless there is a control wire with 3-4 wires inside (normally red, white, blue and green) that is connected from the outdoor unit to the indoor unit. This wire feeds voltage from the o.d. unit to the I.d. unit. If all connections at the o.d. unit are good, then check for voltage at these connections at the o.d. unit. If no power at these connections then a circuit board has faulted. Call a tech. and have a tech support number ready (1-800#) in case your service tech don't have it.
May 12, 2015 | Sanyo KHS0971 9,000 BTU Ductless...
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
I just installed a ductless mini split 12000. when I put power to it the outside unit compresser runs no fan the led read out just blinks very fast the remote does't do any thing
One thing you need to check is Polarity. the 2 wires red and white, need to be on the same terminals inside as they do outside. this is very important.
Oct 28, 2009 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
LG LA185HV Split System Air Conditioner Logo
2,224 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
