Question about Garden
New battery and mower will not start.
Having difficulty starting mower and battery would not hold a chg. I bought a new battery. We believe the problem might be the solenoid but do not have a manual to show where the solenoid is and how one gets to it. There is a panel screwed on below the steering wheel. Is that where the solenoid might be?
    Problem Solver:
  • 16 Answers
That is usually where the solenoid is located. Just follow the red wire coming from the starter (this will lead you right to it).
Posted on May 07, 2010
97 jeep wrangler whine at start up. put in mopar new starter and new starter and difficulty starting still
When you say you're having a hard time starting it does that mean it cranks over fine but it just takes a while to start or does that mean the starter is dragging when you try to start it
Mar 05, 2016 | Jeep Wrangler Cars & Trucks
Motor will not rotate fast enough to start mower
clean the carb,you sucked in the bad gas from before
Apr 16, 2015 | Garden
Installed new battery and I don't get a click or anything it will not start
Try boosting it with your car battery and if that works then check the battery cables not being connected properly. Either loose or dirty or corroded. That will do it as well. Make sure new battery is charged as well. Sometimes a new battery does not work or hold its charge. In that case take it back where you bought it. If it won't boost could be a bad starter.
Mar 14, 2015 | Garden
92 Camry, have to start several times before engine turns on, onl
weak fuel pump, clogged injectors, air or coolant temp sensors out of specs. Timing belt was put on wrong. Timing is off. Map sensor out of specs. You do have a light on. Fixing why the light is on may fix your problem.
Aug 06, 2009 | 1993 Toyota Camry V6
Craftsman Won't Start
i think i'd look for a new repairman - did you check the oil? maybe he didn't put any oil back in it! or maybe the carb float stuck and the crankcase is full of gas. lift the hood and look for burnt wires or at the deck for a burnt belt - try to turn the engine over by hand [the round center with the perforations]. does it click when you try the key? if, not, check the fuse. without knowing the area that the smoke came from it's hard to single out a cause
Jun 11, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Replacing governor on Cub Cadet 1225
I have a cub cadet 1864 and the governor is out of control, the engine will race a high speeds. When i pull back the governor arm and hold it it run normal. Can some one help
Apr 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
1996 Maxima Starting Issue
My car was having the problem I had my ingnition switch change, stater and a new battery and now it's fine.
Oct 25, 2008 | 1996 Nissan Maxima
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
