Question about E-Machines eMachines Desktop PC
I'm really not sure that it is the mother board my machine will come on but it just shows the big e and that is as far as it goes
  • grantmary60 May 03, 2010
    it does not have a error message it just shows the e like it always did when i turn it on but it won't go no futher than the e it is a e-machine T3410 someone told me it was the mother board but i'm not so sure it is
  • Mihajlo Jerkovic May 11, 2010
    Have you tried to boot to safe mode to see does it load the os. On reboot just keep on pressing F8 and choose safe mode. If it does it means some kinda driver is causing this If not it might be hard drive. Does it have any kinda error message when E shows up.
  • 345 Answers
Have you tried safe mode as i posted on my previous post?
Posted on May 04, 2010
Get my D49W20 to power up it goes off, immediately after starting?
Christina typically there is a voltage regulator/modulator that handles the big spike at start up and then adjusts to 120 volts. Sounds like that part is defective and the fact is that if it is your "mother board" (yes these rear projection tv's have a mother board) then no repair is necessary because your cost far outweighs the benefit of this type of television
Jan 11, 2015 | Televison & Video
Mainboard/mother board repair for husqvarna viking #1
look in the yellow pages of the phone book
when you find a sewing machine shop ask them if they work on your model of sewing machine.
if they do, when you get your machine back make sure to sew on the machine that very day so you know it works correctly, if it doesn't let them know about it, make sure you get a reciept showing what was done to the machine, the price you paid to have it fixed is on the reciept.
Mar 05, 2012 | Husqvarna Sewing Machines
How do I change the inverter board on a ge monogram 36" built in, side by side refridgerator ZISB360DX
it's pretty easy,pull off the old board and put the new board on the same way the old board came off,wires go the same place.are you sure that's your problem,GE has had bad mother board problems and everything that runs on that goes through the board,i've changed over 50 mother boards and have never seen a bad inverter board only bad mother boards but i'm not there to see why you say the inverter board is bad.good luck with your machine and changing the inverter board is easy but it's around 300 dollars,unplug the machine and open the cover and check the mother board it's also on the back,back wall with a few screws holding the cover on and check to see if there's any short marks on the board or the metal frame where the board is mounted,i would say that's your problem but like i say you must of checked it with your meter to know it's the inverter board.good luck
Apr 22, 2011 | GE Refrigerators
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
My mother board not show any signal that like sound and light how can i do to solve that problem
check cable connectors,
then check m/b battery.
if nothings goes right just remove ram chips and turn on system..........
then m/board shows u no signal,baby u lost ur main board.it's gone.better check new one.
Oct 02, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
T3624 E MACHINE MOTHER BOARD DIAGRAM
my motherboard can't support of any operating system plz give me
the solution of this prob... (navedaf@hotmail.com)
Oct 07, 2009 | Dell (E210882) Motherboard
If my idle air control system is bad what kind of problems could this cause? What would be the effects?
A bad IAC unit will cause poor driveablility and poor/high idle, and also stalling and starting issues. There is really no harm by being bad but during rapid deceleration if the IAC does not catch the RPM's the engine could stall out; not a good thing if you were going 60 mph. Remove the IAC motor and clean the valve and also the chamber that it goes into with a good throttle body cleaner and that should really help. Carbon buildup is a big factor in IAC failure. Most CEL will not show a malfunction code with a bad IAC motor.
Aug 29, 2009 | 2006 Chevrolet Trailblazer
ASUS P4S533 mother board not supporting full 160 gb
This is happing becuase of your motherboards BIOS !
Really, this happened to me too. You see, our motherboards which are very old cant support above 80 and so on. This is beacuse of the BIOS. You will need to update your BIOS inorder to give new features.
Try go to the Asus home page and download the latest driver for your motherboard. Then install it in your motherboard's BIOS. There is intructions for this in the Asus's home page.
Mar 08, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Motherboard
Well you really need to get a manual for that. Check the website and download the manual with that model, for sure there is one.
I guess you have connected all the connectors there incorrectly so better look for a manual.
Dec 09, 2007 | EliteGroup ECS 755-A2 Motherboard
E-Machines eMachines Desktop PC Logo
42 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
