Question about Motorola Mobility V360 Cellular Phone
My name is Lungile Maduna. i have a problem on my phone does 't want to download mxt,my phone is vodacom so and am using mtn.The model of the is 2700 classic
Hi i am an mtn client would like to change to vodacom n keep my mtn number
need to check with vodacom about their policy for carrying over your phone number
Nov 23, 2016 | Cell Phones
My Mobile Network reads SOS
switch off your blackberry, remove the back cover and battery, and remove the sim card. Replace it after about one minute and it should not read SOS anymore.
If it still reads SOS, insert your sim card into another cellphone to see if it also reads SOS in a different phone. If it does, you need to call the company you bought the sim card from.
Eg; if it's an MTN sim card, call MTN; if it's Vodacom, call Vodacom etc.
Mar 21, 2013 | Blackberry Curve 8350i
How can i brose on my nokia 2700c phone using mtn
SIMPLE. GO INTO THE BROWSER AND CHOOSE MTN TO USE OR MTN DIRECTLY IN PHONE TO USE. THANK YOU HAPPY NEW YEAR
Dec 31, 2010 | Nokia Classic 2700 Cell Phone
Hello, i want to unlock my sim/phone so that i can use a vodacom sim at the moment it only accepts mtn.
Your set is locked by MTN. Your need to unlock your phone you can find a lot of website on internet who provides you a code.
You can also contact these people they will sure help you .
http://blackberryimeiunlockcodes.com/
Jul 06, 2010 | Samsung D900i Cell Phone
I have a problem donloading mxit on my v360v, it downloads it but doesnt work the fone write error code (407)
My name is Lungile Maduna. i have a problem on my phone does 't want to download mxt,my phone is vodacom so and am using mtn.I need a help
Apr 24, 2010 | Motorola Mobility V360 Cellular Phone
Mxit v 5.6
PHONE SUPPORT
Some phones are not compatible with the MXit application. Don't stress, yours is most probably supported. If you want to double check however, simply click on the relevant link to the left:
(Do not know your mobile make? Have a look its battery, it's usually written there!)
We are constantly expanding our service; if you could not find your phone on this list, don't worry, it is likely to be added soon...
DOWNLOAD
Downloading MXit from our WAP-site:
Jargon buster: A WAP-site is an internet website customized to be viewed on your phone.
  1. On your mobile, go to 'services' (globe icon).
  2. Create a new bookmark (www.mxit.com/wap) and save it.
  3. Select this bookmark, then select then 'go to'.
  4. You should be welcomed to the MXit WAP portal at this stage.
  5. Check that your mobile manufacturer and model has been detected correctly.
  6. Open, accept and download!
  7. Start chatting
CONNECTIVITY
Setting up GPRS/3G
Get connected via your service provider's service menu; just follow the simple instructions below:
(It helps to know your mobile's manufacturer and model. Oh and remember, you only have 2 minutes to complete these steps, don't ask us why!)
Vodacom:
  1. On your mobile, dial *111#
  2. Select option 5 (phone settings) from the menu that follows. (Answer -> 5 -> send)
  3. Select option 1 to choose your mobile make and model from a list, or options 2 to have Vodacom identify the phone for you.
  4. In both cases, simply follow the steps provided to get the WAP settings sent to your phone.
  5. Connection settings will be sent to your phone; save these settings.
  6. If any of the above mentioned steps fail, simply retry.
  7. Still having trouble? Call Vodacom's call centre on 111 from your Vodacom cellphone or 082 111 from another phone. Alternatively visit a Vodacom outlet near you.
(GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
Cell C
  1. On your mobile, dial *147#
  2. Connection settings will be sent to your phone; save these settings. If a password is requested enter 0000
  3. If any of the above mentioned steps fail, simply retry.
Still having trouble? Call Cell C's call centre on 140 or visit a Cell C outlet near you. (GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
MTN
  1. On your mobile, dial *123#
  2. Select option 1 (phone setup) from the menu that follows. (Answer -> 1 -> send)
  3. Select option 3 (WAP).
  4. Connection settings will be sent to your phone; save these settings.
  5. If any of the above mentioned steps fail, simply retry.
Still having trouble? Call MTN's call centre; dial 808 (contract) or 173 (pay as you go) from your mobile phone. Alternatively, visit an MTN outlet near you. (GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
Virgin Mobile
  1. When you first insert your Virgin Mobile SIM into your mobile you'll receive an SMS asking you if you would like to accept Virgin Settings.
  2. If you reply YES, your settings for MMS and WAP can be automatically downloaded and installed on your mobile.
  3. Do the following to manually request MMS and WAP settings:
  4. Go to the 'Virgin Mobile' menu which you will find on either the main menu or applications menu of your mobile.
  5. Select 'Virgin Settings' and reply YES when asked if you'd like to download them.
Still having trouble? Call Virgin Mobile's call centre on 123 or visit a Virgin Mobile outlet near you. (GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
Apr 04, 2008 | Samsung SGH-E370 Cellular Phone
Wat to change network
hi what i found was that wen i put the other SIM card in (Vodacom, Mtn) and then went to menu, settings, network, network setup and then said available networks it would come up with three choices Cell C Vodacom MTN. Depending on the SIM card you put in choose the correct network (Vodacom SIM card would choose Vodacom) That fixed my problem hope it fixes yours bye!
Jan 14, 2008 | Motorola Mobility V360 Cellular Phone
Motorola Mobility V360 Cellular Phone Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
