Question about Microwave Ovens
Very dim light on tempature side of range kenmore model 95012102
  • 3 more comments
  • norman1941 May 02, 2010
    can you give a how to replace board directions and apx costof board
    this is not a microwave it is a range
    you gave me no help I knew it was a display board , thanks for taking my money you are still looking at a microwave oven I told you it was a range
    no help from previous post can you assist he gave me a generic answer
    will try it
  • 713 Answers
Hi,the problem is from loose or disconnected neutral wire at breaker box or in the range. Depending on what is on when and if two or more motors are running at the same time. This can as well have the oppisite effect too, lights too bright,run a check on the wiring at the breaker box or in the range.
Thanks and take care
Posted on May 02, 2010
  • 1,284 Answers
Hi, the only way to fix it is to replace display board. This is a separate board, but often is part of the range control board.
Take care
  • Shehu Pro
    Shehu Pro May 02, 2010
    Hi, concerning the cost of the board, you have to contact Kenmore to ask for the price and make a direct request of the part from them to be sent to you. Then concerning how to replace it, the fact remains that if you are not technically sound, it is strongly advised that you call in a technician to fix it in other not to further damage it..
    Take care
We have a kenmore over range microwave that on the right hand side of th einterior seems to spark or catch on fire? It is a 2005 model.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 14, 2011 | Kenmore Microwave Ovens
WERE IS MODEL NUMBER ON KEMNORE RANGE?
The model numbers on most Kenmore ranges will be located on a nameplate along the oven door, or lower drawer opening. Some models may have this information on the back of the operator console.
If this question is in reference to a microwave oven, the model number will be located along the oven door opening, or inside the oven cavity along the upper portion on either the left or right hand side.
If you need further assistance, please let me know. I hope this helps you.
Oct 06, 2010 | Kenmore Microwave Ovens
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Jan 05, 2010 | Kenmore Microwave Ovens
I have a Kenmore Elite Speedcook microwave model 63792-The display light beeps every few minutes and stays on rather than dimming after use. I unplugged and a message "call Service F2" came up-I used the...
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 13, 2009 | Kenmore 63792 Microwave Oven
Kenmore microwave oven power fluctuations
The magnatron, HV capacitor or the transformer. Dangerous place to work in the High Voltage section. Cap can hold a charge so short to ground after unplugging when working around it. Unplug one at a time starting with the mag and see which one is causing the draw.
eric
Jul 01, 2009 | Microwave Ovens
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Distance betweeen range top and microwave 60654
This is always covered in the owner's manual or installation manual. If you don't have yours, you can find one here.
In some cases, you can get it free if you see a "Manage My Home " link on the right side of the page after entering your model number.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
We're happy to help and we appreciate your thoughtful rating of our answer.
May 28, 2008 | Kenmore 60654 Microwave Oven
Kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 13, 2007 | Kenmore 62622 Microwave Oven
Sharp R 1610 Microwave Lights
For your reference, we repair this control panel assembly problem for customers nationwide for $32.50.
Oct 15, 2006 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
