Sorry dont no if you received my reply its JVC MODEL NO;HD-70ZR7J DARK SCREEN after changing bulb and setting TV to brightist setting
  • patkielydeve May 02, 2010
    have changed to your settings and know darker
  • 12,061 Answers
Http://www.scribd.com/doc/22235534/Hitachi-Training-Manual-Projection-Television-DLP-1
http://www.scribd.com/doc/7581354/Philips-DPTV400-TV-Projection-Training-Manual
http://www.user-manuals.com/advanced_search_result.php?keywords=user+manual+JVC++HD-70ZR7J&forward=plist
Above are a couple of training manuals so you can understand whats going on, the last link, is for your exact make model, service and user manuals, pay for unfortunately, i couldn't find any free links.
Below is a training manual for JVC. For your chassis TV. http://www.eserviceinfo.com/index.php?what=search2&searchstring=HV-53PRO
You need to check and see if the voltages from the Power Supply, are correct, if they are NOT nothing else can be..You see it may have a fault, that's caused the lamp, and low brightness in the first place, your set obviously has a fault. Now if you feel that it you do not want to do it. It is my professional advice is to get you set looked at by a JVC Authorised Service Centre, and ask for free "Quote", this way, you will be able to make an informed judgment, as to repair or replace. As these days seemingly insignificant SYMPTOMS, often cost as much to repair as it may cost to buy.
Posted on May 03, 2010
  • 2,335 Answers
Thank you, thankfully today is a busy day.
After reviewing the troubleshooting guide for your set, there are four settings I recommend you review:
PICTURE MODE: Bright
DIGITAL VNR: Min
Super DigiPure: Max
PICTURE MANAGEMENT: On
I trust the LAMP indicator is not blinking at all since bulb replacement?
I hope that helps.
_________________________________________
JVC HD-70ZR7J Manual Download
Posted on May 02, 2010
Why is my tv jvc hd70zr7j showing a blank black screen when i connect the hdmi signal cable? the ps3 used to work fine before but since i moved into a new place it just shows the black screen
you have a HDMI port Failure that's not uncommon many people fail to turn the units off before switching cables around it only takes a momentary short on the 5 volt line to one of the other lines and it can short it . or it may just be a normal failure . but you would have to change the .with the AV and HDMI ports on it to restore operation . your set probably has more then one port ? have you tried the others . by process of elimination you have ruled out its the game and cables so it points back to the tv
Jan 07, 2015 | JVC HD-70ZR7J OEM TV Lamp
Tip
JVC HD-56ZR7J Manual Download
Download JVC HD-56ZR7J Projection TV Manual
Models: JVC HD-70ZR7J / JVC HD-56ZR7J
Have you misplaced your JVC HD-56ZR7J Projection TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC HD-56ZR7J Projection TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC HD-56ZR7J Projection TV manual.
I hope that helps.
_____________________________________________
on May 02, 2010 | Televison & Video
Tip
Download JVC HD-70ZR7J Projection TV Manual
Have you misplaced your JVC HD-70ZR7J Projection TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC HD-70ZR7J Projection TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC HD-70ZR7J Projection TV manual.
I hope that helps.
My jvc model #hd-61z456 is working at too dark of a picture. I have replaced the light bulb twice and have reset the picture setting to factory setting and I don't know what else to do can you help me....
Both times bulbs was replaced it lasted 1 1/2 or 2 years right?Use tv on like 4 or 5 hours a day?That the avervage life span of a projection bulb.Try to buy an original JVC pojection bulb last little longer.
Sep 12, 2010 | JVC HD-61Z456 Television
Hi I have a jvc dlp hdtv that uses a Bulb jvc CL110u11AA. I understand that if the Tv is going dark that I should replace the Bulb. My Tv is also going Green most images are greener that normal. Is this...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
Dark Picture
Sorry Don
Smoking absolutely destroys these TVs. Just like Teeth, the smoke gets inside and permenantly yellows the Light Prism. Since the Light Prism is responsible for passing light in these units, the yellowing dims and yellows the picture. There is NO fix for this.
Cleaning these is dangerous since all the parts have either a UV or Polarizing coating on them.
Again, I am sorry but this is the truth. On the other hand, try pressing the "Video" Button to see if one of these settings is any improvement
Jan 25, 2009 | JVC HD-56G787 Television
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
