Question about Garden
16'' chain Saw wont fire
16'' craftsman chain saw, What is the gap from flywheel to ignition coil?
    President:
  • 2,220 Answers
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
Testimonial: "thats what I thought. thanks"
    Brigadier General:
  • 4,088 Answers
Use a thin business card to set the gap, and have the flywheel magnets under the module while setting it. Normally, you will have to turn the flywheel somewhat to extract the card. Hope this helps!
No spark or fire
i would suspect coil to flywheel distance too great
Mar 07, 2014 | Craftsman sears 18" Chain Saw Chain (...
Clearance for stihl ms 250 ignition coil
Rotate the flywheel until the magnets are under the module, insert a thin business card into the pole gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the pole gaps don't close further. Hope this helps!
Dec 28, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Installed 2 new starting coils, but still won't fire. Get only little spark. Has new spark plug. What else could be wrong?
Use a thin business card for a module gap gauge. Rotate the flywheel magnets under the ignition module, insert the card into the gap, loosen the module screws and allow it to contact the magnets. Tighten the screws again, and rotate the flywheel to remove the card. Make sure the plug has 0.020" gap. You should have plenty of fire. If not, the flywheel magnets may have gotten weak, or the ignition switch is partially grounded out. Hope this helps!
Jun 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Craftsman chain saw. Won't restart after running for long time.
First check is for spark at the plug when it won't fire--it should be blue and snappy with a fresh plug set for 0.020" gap. If not, then remove the flywheel side cover, turn the flywheel magnets to underneath the ignition module. Use a thin business card for a gap gauge and insert it into the space between the magnets and the module poles--loosen the screws holding the module to allow the module to stick to the magnets, then re-tighten the screws. Recheck for spark. If now ok, try to start the engine. If this made no difference, then replace the ignition module and use the same install as before. If you originally got good spark, place little fuel mix in the plug hole and retry start--it should at least pop several times. If so, check the fuel filter, air filter and muffler for plugging. Check the condition of all fuel lines. Make sure the carburetor fasteners are all tight. Finally, the carburetor lower diaphragm may be hard or cracked. Make sure the saw body is not getting overly hot-- it may need cleaning with compressed air to recover proper cooling. Hope some of this helps!
Jun 22, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
ZR10926 16 Chain Saw: chain saw not working...
Remove the spark plug, lay the base on engine metal, and test for spark which should be blue and snappy. If nothing, try a new plug and retest. If still nothing, remove the left engine cover to expose the flywheel and ignition module. Check the module pole gap by using a thin business card for a gauge--turn the flywheel magnets under the module while holding the gauge in place, loosen the module screws and allow the module to snap to the magnets. Tighten the screws again and rotate the flywheel while turning the card to get it free. Turn the flywheel one turn to check that the gap doesn't get closer at any time. Recheck for spark. If still nothing, remove the grounding wire that goes to the ignition switch from the module and retry again. If still nothing, replace the ignition module. If you got spark in the first test, squirt some fuel into the plug hole and attempt start--if you get a few pops, concentrate on the fuel system. Check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines and primer button (if equipped). Make sure the carburetor is tight to the engine and all fasteners are tight. Hope this helps!
May 17, 2010 | Homelite ZR10926 16 Chain Saw
Flywheel to mag. clearance
Ignition module gap
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 21, 2010 | Homelite ZR10926 16" Chain Saw
What is the gap for the ignition module on a poulan wild thing chain saw?
Ignition module gap
Lou
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Jan 07, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
202 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
