Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Leaky gas tank
My 42"craftman riding mower ( model no. 917.271843) has a moderate leaky gas tank, if only it is filled over a half tank.
Please tell me in detail;
1) How difficult to remove it from under the seat?
2) Is there an easy way to locate the leak without taking out from the chaise?
2) Once found the laeking site, can I fix it possby with epoxy compound ?
  • 2,100 Answers
There is not much that will stick to a plastic tank. you could get a plastic tank from a bone yard, and be in the same shape you are now, or a boat place where they have all sizes tanks, or sears. Taking it out is fairly easy, Of course you have to take the entire thing apart to get to it. You might be able to sneak it out through the back with just a panel or 2 out of the way. I have tried just about every adhesive made on gas leaks, aside from silly putty and POR, on metal only, there isn't one. A bar of soap will stop it but only temp. Hope this helps.
Posted on May 02, 2010
Gas keeps getting in with oil what is wrong what do I do
Normally this caused by a leaky float needle valve in the carburetor; although, if you have a vacuum operated fuel pump it internal may ruptured.
Apr 16, 2015 | Troy Bilt 175HP Manual 42" Riding Mower
Leaky gas tank ford tractor
I have a tank for a GT 85 if u are still interested
May 01, 2012 | Ford Garden
Craftman riding mower quit, ran one side of deck into a dirt bank. No power, the fuse is behind dash, my gas tank is there. Do i remove it?
I unhooked my wiring harness from frame so you can get to the fuse. The gas tank shouldn't be that to remove. 4 bolts and the gas line.
Jul 02, 2011 | Craftsman 21 Hp 42" Lawn Tractor Riding...
How to remove gas tank from craftman LT1000 lawn tractor it is located under the seat
Hello, removing this tank is easier then it may initially seem. Here are the basic steps:
tilt the seat forward
remove the springs that support the rear of the seat
remove the knob on the transmission shift lever
remove the fuel cap
loosen the bolts under the foot rests (that is all part of the fender assembly)
gently lift the fender assembly to expose the fuel tank(I have used an engine crane type lift to do this)
remove the bracket over the tank
remove the tank
reassemble in reverse order.
If this helps please vote yes, Thank You!
May 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Should the fuel filter have gas in it while running - Craftman lawn tractor - 917.271024
Yes, fuel system is gravity fed. If there is fuel in the tank, there should be fuel in the filter.
Aug 29, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
After about 15 minutes of operation my mower just cuts off as though it ran our of gas but has not. I have replaced the ignition coil, spark plug, air filter, fuel filter. I have a 17.5 hp Craftsman riding...
I have same problem only thing ive found is gas tank may not be venting properly. Fill tank about half full and leave cap off, if still stalls then probably engine problem
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
306 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
