Question about Kenmore 15762 Dishwasher
My dishwasher takes 2.5 hours to run, what's wrong with it?
  • 901 Answers
Check user guide. Check the program you have switched. Two hours or little more is OK. But check your inlet water flow to the machine. If it is slow then also you will get this delay.
Posted on May 03, 2010
Dishwasher takes 3 hours to run through programme
3 hours isn't "extremely" long. If you run a normal cycle, it should run about 2-2:30 hours normally with the drying cycle. Now if it's over 3 hours, that would be a problem. Make sure that when you open the door that there is a lot of steam coming out, because that is the only thing that can extend the cycle is if the dishwasher isn't heating the water. Unfortunately this is a very common issue and it means that your control board inside the door has failed. There is a relay on the board that shorts out. This relay sends power to the heater, so when it fails the dishwasher doesn't wash well and it will run forever trying to heat the water which will never happen.
Sep 10, 2013 | Bosch Dishwashers
Frigidaire FDB520RHB Dishwashers : We bought this dishwasher about 3 months ago. Today I ran the washer before I left to do errands and when I returned, I believe the washer had finished its cycle. But...
Try to run the dishwasher on a short cycle like rinse and see if it finishes the cycle.
It is likely the heater or hot water temperature is not reaching the desired level and this could cause the extended wash cycle. Feel water temperature inside dishwasher after some time. If cold then it is the heater not working. Perhaps try without Heat Dry Cycle. That will also extend the cycle if heater is not working well.
see cycle diagrams in the page 2 of this sheet. Gives you and idea how Heater Delay affects cycle times.
Apr 21, 2013 | Dishwashers
Gu1200 runs for two hours
Is the water going into dishwasher at 120 degrees or close to it. Are you using rinse aid. If you use options like dry heat it will take 2 hours. 2 hours is normal.
Dec 26, 2011 | Whirlpool GU1200XTLS Stainless Steel...
Is it true that it takes about 2 1/2 hours to go through a normal cycle? If not, how long does it take, approximately? I am asking about the 18 inch built-in.
I cannot find any mention of times for this particular machines run, I have found the Users Manual HERE. I don't think it should take 2 1/2 hours to run this unit through a cycle, perhaps 30 minutes to one hour.
I hope this answers your query.
Joe
Sep 20, 2011 | Danby DDW1899BLS Builtin Dishwasher
I have a whirlpool du1100xtpsa built in dishwasher that won't stop running. It take 6 hours to do the full cycle. What do you think is wrong?
i know that there are some eco settings that take longer and thus use less energy ensure you are not in one of these settings altough 6 hours seems very long.
I would get an engineer to look at it as it could be one of several issues.
I hope this was useful
Jan 23, 2011 | Dishwashers
Our dishwasher takes about 3-4 hours to run a cycle. My brother has the same model and it takes about an hour. Is there an adjustment that we can make to correct this? Thanks, Karla
make sure that your filter in the bottom is clean and if you are using the automatic wash cycle, it will wash until the water is clean. Sometimes it will take an hour, sometimes it will take close to 2 depending upon the level of dirty dishes in the dishwasher. And don't rinse! They work better on dirty dishes.
Jan 05, 2011 | Bosch 24 in. SHX46A05UC Built-In...
The dishwasher runs for 2 hours. How can I fix
Check your water inflow to the machine. If it is not filling the machine it may take time. Check the wash programme setting- like light, heavy, soiled etc.( depends on the m/c design)
Apr 06, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
My Whirlpool dishwasher takes two hours to wash, not including the dry cycle. what is wrong with it?
there is nothing wrong with the unit if it is a electroniclly control unit they are programmed to run for up to 2hours or a little longer.
Mar 14, 2010 | Dishwashers
My dishwasher takes 2 1/2 hours to run. Is this normal?
Smart wash: 2 hours Anti-bacterial wash: 2.5 hours Normal wash: 2 hours China/Gentle: 1.5 hours Quick Rinse: 10 minutes
Note: If water temperature is low the times shown above will be extended to allow for water heating time.
This information is from page 14 of the manual.
Jan 16, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
2 hour run time
one needs to take into concideration how long it takes for the water to enter the unit and how long it takes for the water to heat up.these factors will influence the running time. defective heater very common.
Sep 10, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Kenmore 15762 Dishwasher Logo
112 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
