Question about Solis Maestro Electric Burr Grinder
I am having problems putting the hopper back in the burr grinder
  • Solis Master
  • 43,501 Answers
Sometimes my wife or I pull the hopper out before the grinder is totally stopped and then some coffe gets behind the hopper. Thre are a couple of small slots that hold the coffe and the hopper will not slide back all the way again...we then need to take a knife and clean everything out good before it will work again...
heatman101
Posted on May 02, 2010
Testimonial: "thank you !! I also just put some rice in to grind.....that helped the clogging too ! I have searched the net for the manuel to download and struck "
What do you do when the grinding blade will not come off for cleaning?
Hi
With the bean hopper on, turn the grinder upside down. Rotate the bean hopper to loosen any grounds that might be holding the burr holder. Now remove the bean hopper and try again to remove the holder. Only the outer burr comes off, this way.
Jul 19, 2010 | Solis Maestro G385 Electric Burr Grinder
Tip
Saeco Italia automatic espresso coffee machine Grinder Cleaning Instructions
Saeco Italia Grinder Cleaning Instructions
Removal
Step-1: Remove beans that are in the bean hopper without spilling them inside. (Use Vacuum).
Step-2: Remove the beans container by removing 3 phillips head screws. Remove the rubber gasket from below the hopper. At this stage the upper burr will be visible.
Step-3: Rotate counter-clockwise the outer ring of the grinder assembly (the ring has gears half way around), until the red mark is at the 9 o’clock position, looking at it from the front of the machine.
Step-4: Lift the upper burr by using the fins that are on top. Press lightly on the doser adjustment gear, to clear it from the dose adjustment gear.
Cleaning-
At this stage, the grinding chamber will be exposed. Clean out any crushed coffee in the grinder chamber and the burrs. Use Vacuum and cleaning brush.
To Re-Assemble
Step-1: With the red mark on the outer ring still at the 9 o’clock position, replace the upper burr back into the grinder. Make sure that the red line (on the upper burr) is at the 3 o’clock position. This position will align the other tabs as well. During re-installation, press slightly on the doser adjustment gear so the upper burr will clear it as it is placed back in.
Step-2: With the Upper burr in place, rotate the outer ring clockwise until it stops. The two red marks should be aligned at the 3 o’clock position underneath the doser adjustment gear.
Step-3: Replace the soft rubber gasket back on the upper burr. Use the fins to align it properly.
Step-4: Slide the doser adjustment gear toward the front of the machine until it stops.
Step-5: Before replacing the bean hopper, rotate the grinder adjustment wheel to Zero (0), and the doser adjustment wheel to Minus symbol (-). Place the bean hopper into position on the machine, slightly adjusting each adjustment wheel as you are placing it down in the machine. Once in place, fasten the bean container with the 3 screws. Test each adjustment wheel through the full range of motion. The grinder knob rotates from 0 to 18 and back, and doser knob from Minus (-) to Plus (+) and back.
Now position the grinder adjustment knob at Eight (8) and the doser adjustment knob to the halfway point between the Plus (+) and the Minus (-) marks. This will put the machine back to the factory setting.
When using for the first time after adjusting the grinder, it may take more than one grinding cycles to make the first cup of coffee.
on Aug 12, 2010 | Coffee Makers & Espresso Machines
Burrs spin but no grinding
Try this, remove the bean hopper, and vac out the burr chamber, then put 1 tablespoon white rice in the burr chamber and cover with hand and turn grinder on, if the rice grinds, then your grind might have been set too fine. Turn the grinder towards fine until you can barely turn the burr nut, you will feel them touching, then turn course about 16 notches (do not use numbers, use the small notches around the rim), that should give you a great starting point for your grind.
May 20, 2010 | Mazzer Mini Burr Coffee Grinder
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
Cleaned grinder now can't get it set correctly. where do i line up red dots.
Hi
When you put in the outer burr, the redo should be to the front. The outer red dot has to be at the back. Rotate the outer red dot clockwise till it lines up with the inner red dot. Try lifting the burr out to see if it locked in. If it didn't, reverse the process and make sure that you push down on the burr before rotating the outer ring. Move the big knob in the bean hopper to 0 (zero). Put the gasket on the grinder and replace the bean hopper. Once the bean hopper is secure, move the big knob to 8 and you set.
Jan 05, 2010 | Saeco Vienna Espresso Machine
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
I can't remember the simple key to disassembling the Solis Maestro for more thorough cleaning. I need to get beyond the top burr removal stage.
Hi
Rotate the bean hopper counter clockwise until it stops. Lift the bean hopper out. Remove the outer burr with the wing-lets. Can go back in either way. Clean with air or vacuum out grounds. Use small brush to help clean grounds. Reinstall burr. Line up notches of the bean hopper with shell ( large tab in large slot, and small tab in small slot). Rotate bean hopper clockwise a small amount and test.
Nov 10, 2009 | Solis Maestro Electric Burr Grinder
Replacing hopper after cleaning
The hopper has two slots in the bottom that aligns with two black tabs in the base. Rotate the tab ring in the base counterclockwise and then install the hopper.
Sep 30, 2008 | Solis Maestro Electric Burr Grinder
Osyer burr mill 6389
Apparently, you unplug the unit, dump any beans out of the supply hopper, then rotate the burr intake module in the bottom of the supply hopper counterclockwise. You can then pull it out, and brush it out. You also brush out the other half of the burr unit; don't put water or anything in it, you'll kill your grinder. You can, in theory, wash the removable module, but if you do, be sure it's ABSOLUTELY dry before you put it back together.
Jun 15, 2008 | Oster Coffee Burr Mill - 6389 Grinder
Cleaning La Pavoni Burr Coffee Grinder
You'll need to remove the hopper and grind out all the beans. Then, with the lock tab depressed (if it has one), unscrew the grind adjusting collar out of the body. Once it's out, there are three screws (sometimes only two) holding each burr. Remove screws and separate the burrs. Clean away!
Be very careful putting it back together so that you don't cross-thread the collar into the body. Clean threads can help this.
Jan 02, 2008 | La Pavoni Burr Coffee Grinder - Black
Solis Maestro Electric Burr Grinder Logo
377 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
