Question about GE 29869GE2 Digital Answering Machine
My unit works perfectly with one exception. Over time, recording a greeting has resulted with increasing background hum. The greeting is being recorded properly about 6" from the microphone in a quiet room. The hum is therefore picked-up within the machine. I would appreciate any suggestions. The hum is only on the greetings as the incoming calls are clear. Operator error during programming is non-existent.
  • 5 more comments
  • rmarti100 May 02, 2010
    I already thought of using different outlets and even changing polarity with no luck.
    The hum that is picked up during outgoing message recordings does not affect any other unit recordings such as incoming messages.
    FYI I disconnected the unit and removed the back-up battery for 5 minutes with no luck. I also tried different outlets and even an isolation transforner.
    I tried locations in the garage, bedroom, yet the hum is still the same. It appears that the cable within the machine that goes from the microphone to the pc-board must be picking something up.
    I still expect the problem to come from within the unit. Possibly the microphone cable shield is compromised. Sure would like to get my hands on a diagram. Any suggestions?
    I'm an electronics engineer. Will try to move the microphone outside the unit so the microphone cable is not criscrossing over the uper and lower cicuit boards. Maybe an electrolytic cap isw causing the interference.
    Thanks for the help. Will click on the accept botton.
    Still have a way to go to get find the source of the hum. Will also lock for nearby transformers in the unit.
    I will try to more work on it later today.
    Need to visit my parents i the next couple of hours!
  • 2,335 Answers
Often a hum is caused by RF or EM interference. That the machine is recording calls clearly is consistent with this. The interference may be getting into the system through the power or telephone signal cable being near many other cables, or because the unit is situated next to a strong source of RF or EM field.
I recommend changing the location of your answering machine, away from such noisy sources (microwave, cordless phone, router, DC charging adapters, etc). Try the machine in an outlet that has nothing else on the circuit, if possible.
I hope that helps.
Posted on May 02, 2010
  • GE Master
  • 3,866 Answers
Oh this humm is from the mic inside the unit. You might want to try a different power source or outlet then any other unit like tv's fish tanks or anything that is leaving noise in the line. Now if that does not help you might have a transformer inside the unit that is not working right.
But at this point I would instruct you to try different A/c outlets in the house.
Thanks please do click the accept button for my efforts.
  • 3 more comments
  • Grand Canyon Tech
    Grand Canyon Tech May 02, 2010
    like i said look at the mrcorphone inside if that seems to be ok then its the transofrmer inside admitting the noise
    let me know
  • Grand Canyon Tech
    If your good you do not need a diagram locate the mic and look at its solder lead if its cracked you might want to do some touch up work!!
    if the cable is freayed you can wire this easy no diagram needed here.
    let me know
  • Grand Canyon Tech
    Your so welcome and if you will do that for me to close the case that would be great,
    thanks for mentioning the capacitor as well. It could be it but then the machien would show other signs of intermantance. Good luck
  • Grand Canyon Tech
    please do not forget to click the accept button to close out the case or we have to wait 7 days for it to close automatically. Thanks
  • Grand Canyon Tech
    OK no issue so you want to leave it open until its fixed no biggie
Background noise
no problem with..record some part of the start with no voice just a 5-10 seconds remain quite...just kept running the recording...then start and record your voice after which install AudaCITY Software and drag your audio file in it and then select the first 5-19 seconds recording which was just the background kept recording selecting the part go to Effects -> Noise Removal then press Get Profile,
after which again select all the track by: Control + A key on PC and then go to Effects Noise Removal move the bar to the left side...and press ok/continue key....now your track is very much clean by the noise...and
for sound loudness select all the track and go to Effects -> Normalize then again Effects -> Amplify put the slider value to -0.1 of what the value is shown.
Jan 19, 2012 | Vizio VSB210WS Soundbar
It tells me that I cannot re record greeting - it says unable to fix now
what this simply is that your panasonic phone has been over power by power supply what you are to do first of all put off the phone for some time then put it on again after it most has relax it self then apply the below instruction to reprogram the greeting message on your panasonic phone again
Several Panasonic telephones come with a built-in answering machines. You can leave the telephone as is and let your callers hear a message pre-recorded on the device by Panasonic, or you can personalize your phone with your own greeting.
Instructions below.
  1. Press "Getting Rec" on the base unit.
  2. Press "Getting Rec" again within 10 seconds after you hear the pre-recorded message, "To record greeting, press record again."
  3. Lean in so you are within eight inches of the microphone on the unit, and wait for the long beep.
  4. Record a personal greeting lasting up to two minutes after you hear the beep.
  5. Press "Rec Greeting" or "Stop" after you have finished recording your greeting.
  6. Record your greeting again if the base unit displays an "E" and beeps six times in a row.
  7. Press "Greeting Check" to hear the greeting you recorded.
Hope this help?
Thank you and thanks for using fixya.
Nov 23, 2010 | Toshiba DKT-2010 Corded Phone
I own 3 of these. Two of them have been hooked up for over 3 years and worked perfectly until yesterday. All of a sudden, the remote wouldn't work and I couldn't turn the unit off with the power button. ...
If you are using these DVRs over the air only, with 1.2.06 installed you have to run the G* Test in the 9012 menu, to get the digital data going, after removing power. That is why your clocks are --:--. I highly recommend that you update the firmware in both of these units to 1.2.21, to avoid having to mess with the G* Test.
Aug 17, 2010 | Sony DHG-HDD500 400-Hours Video Recorder
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
Change recorded message
Please follow the steps:
1. Press MENU
2. To select "ANSWERING SYSTEM MENU?", press SELECT
3. Scroll to "GREETINGS?" and press SELECT
4. Scroll to type of desired message and press SELECT
5. Scroll to "RECORD GREETING?", and press SELECT
6. Record a message or greeting through the base speakerphone or base station handset. 7. Press SELECT to play back greeting/ message.
NOTE: To avoid background noise, record message through the corded handset.
Sep 12, 2009 | Siemens Gigaset 8825 Cordless Phone
Noise / Hum in recordings
hi, i once had the same problem with a kenwood cassette deck. it would play pre-recorded tapes perfectly but when it came to recording from another source i would get an annoying hum when playing back the recording, the fault turned out to be a faulty earth connection on the phono connectors on the rear, they were dry jointed and once resoldered the unit worked and the recordings were perfect. maybe you have the same problem? hope this helps?
Feb 14, 2009 | HHB CDR850 CD Recorder
How to record greeting message
Page 21 of the manual: http://service.us.panasonic.com/OPERMANPDF/KXTG5100M.PDF
1 Press and hold [GREETING] until
“Record greeting after the beep” is
heard.
2 After the long beep, talk clearly,
about 20 cm (8 inches) away from
the MIC (microphone).
• The elapsed recording time is
displayed.
• If you record for over 2 minutes, the
unit will stop recording.
3 When finished, press
[GREETING] or [STOP].
• The unit will play back the recorded
greeting.
• To change the greeting, start again
from step 1.
Aug 26, 2008 | Panasonic KX-TG5100 Cordless Phone
Need to set date and time
For similar model
Hold down the GREETING button. The unit announces “Record your greeting after the tone,” and displays GREETING RECORD. After the tone, you have 30 seconds to record your greeting.
3. Release GREETING when you finish.
Aug 19, 2008 | GE 29888GE1 Digital Answering Machine
Philips CDR775
Bad earth / failed capacitor on the PSU board. I sell replacements via ebay or can email a service manual for you to get fixed locally. Fluffcat1
Oct 24, 2007 | Teac CD-RW880 CD Player / Recorder
User manual of GE 29878GE1 Digital Answering Machine
From the Manual: RECORDING THE GREETING Before using your new answerer, you should record a greeting (the announcement callers hear when your answering system answers a call). If you don't record a greeting, callers hear a default greeting which says, "Record message after tone." When recording the greeting you should be about 6 inches from the unit. Eliminate as much background noise as possible. 1. Prepare your greeting. Sample Greeting: Hi, this is (use your name here). I can?t answer the phone right now, so please leave your name, number, and a brief message after the tone, and I?ll get back to you. Thanks. 2.Hold down the GREETING button. After the tone, you have 30 seconds to record your greeting. 3.Release the GREETING button when you finish. The greeting will playback automatically. NOTE: Your recording time should not be less than 2 seconds. Otherwise the unit will return to the default greeting.
Jun 05, 2007 | GE 29878GE1 Digital Answering Machine
GE 29869GE2 Digital Answering Machine Logo
71 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
