Question about Delta 467-SD Palo Single Handle Kitchen Pull Out Faucet with Soap Dispenser...
I have delta palo model kitchen faucet that has a
I have delta palo model kitchen faucet that has a drip coming from under the handle how do I fix this?
    President:
  • 512 Answers
Delta faucets have a lifetime warranty. Call them and tell them, they will send you a rebuild kit. You can rebuild the whole faucet, it will work like new again.
Posted on May 03, 2010
Testimonial: "thank you!"
Delta faucet #467-DST. The last couple of weeks my kitchen faucet doesn.t want to turn back and forth easily. I thought it might be a kink in the sprayer hose. Help
There are two rubber o rings under the spout, one at the top and one on the bottom, Remove the handle then the nut that you will see that is in contact with the spout. Rock the spout left to right and pull up at the same time. You then can replace the O rings and make sure you put some food grade lub on the O rings. Replace all that you took off and you are god to go.
best of luck Rich
Sep 05, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
Delta 467sssd hard to turn
there may be under the handle is a crown nut + a plastic collar which holds down the inards there is a tool that works this. it can be gotten at hardware store.. handle usely comes off w/ 1/8 allen wrench...
Mar 31, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
I have a Delta kitchen faucet model #467-SSSD-DST. The cold water flow and/or pressure is not adequate. The flow and pressure from the hot water side is fine. What may I do to fix my cold water problem?
Take the handle off (set screw underneath)
Then turn the top off under the handle....make sure water is off...
then you will find a ball with the handle stem on it....note the position of it and pull it out...
under there are two wets of springs and rubber seats...
pull the right side out and check the hole for a blockage...(dirt or rust)
if none is visible, you may have to unhook the cold water supply hose
and then blow compressed air back through the hole to remove the blockage...
then reassemble...
heatman101
Mar 20, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
The parts page on this link will give you a break down and hope this will help.
http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
Dec 30, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
I have a two-handle Delta faucet that drips.  With both handles turned completely to off, the faucet drips at a about 1 drip every 15 seconds
sounds like you need to replace the valve seats. if you shut the water off and remove the handles you will see the valves. you have to remove them and under that you should see these little black things. they come out but have springs under them so be careful. the black things are the valve seats. i would start by replacing them
Dec 15, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
Apr 06, 2009 | Delta Model 172: Waterfall Single Handle...
Delta Faucet Kitchen Single Pull
Yes, It can be fixed but it isn't a washer. There is a replacement stem for the faucet . They are readily available at most big box stores and possibly the local hardware store. Bring your faucet model number with you.
Phil
Oct 17, 2008 | Delta 2402 Classic Single Handle Kitchen...
Delta 467-SD Palo Single Handle Kitchen Pull Out Faucet with Soap Dispenser... Logo
358 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
