Question about Sony Cyber-shot DSC-H5 Digital Camera
Half press focus not working
Haw can i fix the problem ( haw can i replace it with the new one)????
    Brigadier General:
  • 11,967 Answers
Occasionally, the half-press won't function if the camera is in certain settings. ie, manual focus, self-timer, lens aperture on setting other than "A", etc. Check your settings to see if this could be causing your problem.
Posted on May 02, 2010
Sometimes shutter release button is very slow, other times it is fine. Just began happening. Do you have any idea what the problem may be
On page 28 of the advanced features manual from your camera, it explains how AF works. Focusing should happen while you press the shutter realise button half way down. Depending of the light, contrast and subject this can take from half a second to sometimes twice or three times as long. When in focus, you hear a beep and see a green light on the display. Then you can make the composition (or fine tune the outline of your picture) and then you press the button fully. The compact camera does work different from a DSLR. If you are user to a DSLR, you have to learn the compact, because it needs more time to focus, because the focus system is completely different.
Mar 22, 2014 | Panasonic Lumix DMC ZS19K 141 Megapixel...
Tip
Blurry Photos
Good day,
I have heard a lot of complaints about people taking Blurry Photos.
There are a few possibilities for it and a few easy fixes.
The first possibility I would identify is a dirty lens. To fix this simply take a clean microfiber cloth and gently clean the lens until there are no smudges visible.
The other possibility I would identify is that the pictures are out of focus.
This problem can be caused by a dirty lens or because the object or person was not focused on. To ensure focus on your photos, line up your shot and wait for the camera to focus by pressing the shutter button half way down. When focused press the shutter button in all the way and hold the camera still until the photo appears on the screen. By doing this you will eliminate any motion that might mess up your shot.
Please let me know if these tips work for you!
Regards
on Nov 29, 2010 | Cameras
The manual focus ring on my camera doesn't work. The ring turns but does not seem to adjust the focus. Automated focusing still works. How to fix it?
Two methods:-
1. Use the slider switch on the left of the camera to set it to MF (manual focus). The focus ring is an electronic one rather than a physical control like the zoom ring, so the response can seem slow.
2 Go into the camera menu and enable DMF (Direct Manual Focus). This allows you to override the autofocus simply by adjusting the focus control, but it does not work if the slider switch is set to the AF C setting (continuous autofocus), it only work in the AF-S (AF only activates once when the shutter is half pressed).
Jan 31, 2011 | Konica Minolta DiMAGE A2 Digital Camera
Olympys fe-270 takes blurry pictures
Try this. Aim the camera at the person/object you want to take a picture of. Press the shutter button "HALF WAY DOWN" wait 2 seconds then complete by pressing all the way down to take the picture. The auto focus works on the "half way down" stroke. Some cameras have a light that goes from red to green to let you know the focus was completed. Or, just wait the 2 or so seconds.
Dec 22, 2009 | Olympus FE-270 Digital Camera
Ford Focus Quickclear windscrean is only partly
the heater elements in the screen may be damaged and unfortunatly the only way to fix it is to have a new screen fitted
Dec 16, 2009 | 2005 Ford Focus
Fixing a 2003 ford focus front wheel bearings
remove the hub and spinle ,tie rod end ,axle nut.ball joint,and seperate from strut and then have new bearing pressed in...or rent a bearing press that works with an impact wrench,but they are a little hard to work with...good luck...lee
Sep 07, 2009 | 2003 Ford Focus
Focus error
if you use camera digital, before you shoot that object, you must remember, press that shutterkey a half press for twice or third pressing (for fix that object and the lense, of course FOCUS), and you can press full down shutterkey.
Aug 07, 2009 | Fuji FinePix A205 Digital Camera
Focus Problem
I have the C740, which I believe works very similarly if not identically. Unless you have the camera in full time auto focus, I don't believe it actually focuses on the subject until you've pressed the shutter button half way. Until then, the subject may look in focus in the viewfinder, but is not. When you fully depress the shutter in one motion (rather than pressing half way first), the camera will attempt to focus before it takes the shot. If you are not careful about camera movement, you may inadvertently be focusing on something other than what you intended. My camera (and it seems all digicams) has trouble focusing in low light, so you definitely want to use the half press in such situations. Even then, I don't always get the focus correct. Thank the digital Gods for instant feedback! Personally, I almost always use the half press method. To get the 740 in manual focus, you hold the "OK" button down until you see the viewfinder display a focusing scale. It takes a second or so. You should also see "MF" and "AF" designations in the lower left corner of the viewfinder when the scale displays. Use the left and right arrows to select the focus mode you want (i.e. MF or AF), then use the up and down arrows to adjust the focus distance. You'll notice that the area you are focusing on is enlarged when you use the up and down arrows.
Sep 13, 2005 | Olympus Camedia C-750 Ultra Zoom Digital...
Sony Cyber-shot DSC-H5 Digital Camera Logo
95 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
