I HAVE A MAYTAG LAT2600AAE WASHER 8 YRS OLD. IT IS LEAKING WATER OUT THE BOTTOM OF THE TRANSMISSION AND THEN THE BELTS UNDERNETH IS SLINGING THE WATER ALL OVER. ANY IDEA WHAT I NEED TO DO?
Are you using a liquid fabric softener ? If so , try using dryer sheets instead . Maytag is known for making liquid softener look like grease on clothes . After switching for a while , and still grease looking stains , then it is possible for the water to be getting into the transmission and pushing the grease up into the tub . Rare , but happens . Time for another machine if that happens .
You must be referring to the water inlet valve (part#22002360 -
Anti-Siphon Water Valve) and it is not designed to be torn apart for service or cleaning other than removing the screens where your hot and cold water hoses connect to it. $20-30 at your appliance parts store.. Have fun, and best of luck, Chuck
Either the program switch or the transmission has failed.
The transmission is probably a lousy Whirlpool part and have had them fail in only a few years of light service.
To eliminate the program switch, use a different cycle setting to see if it can complete any of those available.
If not, then it's probably the transmission.
Look toward the bottom end of the agitator. There should be a small indentation where a 10mm screw is. This screw holds the agitator the the transmission shaft. Sometimes the screw works loose and needs to be tightened.
It will need a seal and transmission. Expect one and a half to two hours labor. Best bet. Bite the bullet and get another washer as this will probably happen again.
