Question about Bose Lifestyle 38 DVD Home Entertainment System System
Have a dvd stuck in the unit. door will not open.
Have a dvd stuck in the unit. door will not open. was watching the dvd-screen went blue-message appeared "unable to read disc"- now it will not play,rewind, forward or eject. Thanks!
  • 3,866 Answers
Your going to need to open this u if the door will not open and manually take the dis out by hand, now if you feel you cannot do that then your going to need a tech shop locally do it for you. But its easy you just pop off the screws the cover should slide oven you localte and take the disk out. now once your in there you can see if there was any damage 9 times out of 10 the disc got miss feed.
Good luck if you have any additional questions let me know otherwise please leave your positive feedbakc and ratings.
Posted on May 02, 2010
Dvd player hangs up while playing
Sir I dont think its the dvd that is not working I thisnk its the screen that is starting to fail, it can be that the dvd is not sending the video signal to the screen when you open it and thatt is why you only get the blue screen and nothing else, because if the dvd was not working let it be the laser or a motor the most common message that you get in the screen is no disc, but that is not your case so I would have the screen check on that portable dvd.
Jul 23, 2010 | Rosen CV8081D Portable DVD Player
Cyberhome 300 not stuck on main blue Cyberhome screen
It may not be able to read the DVD because the laser is dirty. First try to reset the system ( with no disc inserted, open then close the disc tray and hold the stop switch on the UNIT NOT THE REMOTE for six seconds). Then with the disc tray open using a can of "AIR DUSTER" - dry air in an aerosol can, insert the can nozzle into the disc tray cavity and spray away. That may blow off any dust on your laser eye. Try it again and if it still wont work,unplug the unit and remove the six small Philips screws that hold the cover on( it pivots up and off from under a lip in the front panel), plug it back in and open the disc tray exposing the laser and clean the lenses with Isopropyl alcohol and a q-tip. Do this GENTLY you don;t want to disturb the laser alignment. Dry with another Q-tip or the Airduster and re-assemble. Note well the unit will be POWERED with the cover off so BE CAREFUL. Just did this with mine and it now works like a charm again.
Dec 05, 2009 | Cyberhome CH-DVD 300 DVD Player
No video on our tv
I found in the manual on page 13 bottom, that if you PRESS STOP buttom for 5 seconds of your remote controller then you can see the picture on the interlaced mode again on your TV.
Otherwise you have to connect you DVD to a unit that has progresiv scan, such as an HDTV, some computers if they have an input or to a projector .
I connected my DVD to a projector thru the VIDEO output and put eveything back to normal, and it is working fine now.
System Reset
Open CD disk tray. Press stop key and hold for 15 seconds, screen will appear.
Apr 01, 2009 | Akai DVPS760 DVD Player
DVD drive will no longer open
I went to look at getting it fixed and wit was going to cost as much as a new device, so I pulled it to bits and found that the rubber band in the DVD player was frail. This meant it didn't have enough strenght to load the disk completely.
I went to a stationary shop and brought a new one the same size and it is perfect.
Cost. 10c.
You will need to be careful and confident pulling it to bits and some of the screws are no standard. good luck.
Alternatively there is a slot under the unit that you can force the DVD mechanism open or closed. A hassle though.
Nov 22, 2008 | Philips DVDR3455H/37B
Jensen dvd not showing
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
Feb 17, 2008 | Jensen VM9510 Car DVD Player
Door won't open and turntable does not turn
unfortunately you may have to reset the unit. This will cause you to lose everything saved in memory so make sure its not just a DVD stuck in the mechanism. To reset to factory default turn unit off then press and hold Stop and press Standby/On
Dec 08, 2007 | Pioneer DV-F07 DVD Player
DVD Stuck
Although, this particular model does not have a pinhole in the faceplate or anywhere else for that matter, we solved that problem simply by unplugging the whole machine, waiting one minute, and plugging it back in. This is Dysney's quoted response for "rebooting" and troubleshooting such a problem and it worked for us when the same thing happenned.
Nov 26, 2006 | Sony SLV-D350P DVD Player/VCR
DVD stuck in DVR5000
Some CD/DVD units have a manual opening mechanism, it looks like a small hole on the front of the unit, try using a needle or a metal rod that fits by inserting it into the hole and pushing it should open the unit in case it got stuck somehow. If afterwards it continues to work then all's good else you'll have to bring it to a workshop.
Nov 19, 2005 | Rio DVR5000 DVD Player
Bose Lifestyle 38 DVD Home Entertainment System System Logo
199 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
