Question about Kenmore 22422 Top Load Washer
Agitater the agitater does not work
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. Will it fill with water???? Can you hear the motor??? Have you tried a different cycle??? If you move the timer to the spin cycle, will it spin???? Can you hear any unusual noise??? Can you smell anything unusual??>?
    Guru:
  • 351 Answers
If the washer will spin but not agitate , then the transmission needs replacement. You should probably get an estimate from an appliance tech to see if it is more economical to replace the part or the machine.
Posted on May 04, 2010
How to clean the screen under the agitater
Pull the fabric softener dispenser off the agitator, reach down and pull off the white cover (has 2 ears on it), then remove the bolt holding the agitator to the shaft. It then lifts off.
Jan 28, 2010 | Whirlpool LSR7333 Top Load Washer
Top of agitator does not agitate with lower agitator.(dual agitation) whirlpool model LA3860XW00
You will need to replace the Dogs. Take cap off of the center of the agitater, take bolt out of center and pull agitater up and off. Pull two pieces apart. There are four dogs that catch on gear teeth inside your agitater. The four dogs come in a hit, sometimes with a couple other pieces. Has to do with which model you have) replace these four and any other pieces that come in the kit you order. This will fix your problem.
Please rate solution
Aug 31, 2009 | Whirlpool Washing Machines
I need to remove the agitater from a 90 series kenmore washing ma
remove the top of the agitator by pulling hard at a 45 degree angle toward yourself, grab the plastic piece you see inside with a pliers and pull it straight out, use a 1/2 inch socket with extension remove the 1/2 inch bolt and lift entire assy straight out.
Apr 07, 2009 | Kenmore Washing Machines
Kenmore 90 series washer 110.28902790
if you remove the agitater cap and the inside cap,you will see what they call dogs(4 of them)they wear out and the agitater will not wotk,if you remove the 7/16 bolt and pull the agitater off you can replace them and all will be fine,you can get them at your local appliance part store,please leave me a fixya-mike
Mar 12, 2009 | Kenmore 15864/15862 Top Load Washer
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Grandma's nylons wrapped around the bottom of the agitater
now you need to pull upward firmly but hard.  there are small splines holding the agitator in position. carefull if the agitator has two parts to it as there are usually plastic (dogs)inside which could spring loose if you are not careful.
Oct 24, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
73 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
