Computers & Internet Logo
Posted on Mar 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer when i first tried to set up the system i entered the wrong password for internet axis. now it will not let me reset that and cannot get any wireless connction to the internet.
Anonymous
Level 2:
  • Expert 55 Answers
  • Posted on Mar 25, 2008
Anonymous
Expert
Level 2:
Answers
55
Questions
0
Helped
132280
Points
150
Go to start--> settings--> network connections. right click on your wireless connection and go tp properties. Go to the wireless networks tab and you can change the password from there.
My MECER xpression notebook laptop is showing a bios password and it doesn't allow me to press
It sounds like your MECER xpression notebook laptop is displaying a BIOS password prompt and you are unable to enter anything after entering the wrong password three times. You can try the following steps to resolve the issue:
  1. Try to remember the password you previously set for the BIOS. If you are unable to remember it, you may need to reset the BIOS password.
  2. To reset the BIOS password, you can try removing the CMOS battery from your laptop's motherboard for a few minutes and then reinserting it. This will reset the BIOS settings to their default values and remove any passwords.
  3. If removing the CMOS battery does not work, you can try using a BIOS password reset tool or contacting the manufacturer for assistance.
It's important to note that resetting the BIOS password may cause your laptop to lose some custom settings or configurations, so you may need to set them up again after resetting the password.
I forgot my authentication password system for dell latitude e5500 no service tag ,computer system #DFDNXG1-2A7B need to reset Thanks
1. u have express service code from that u will get service tag
2. enter wrong passwords 3 times there u will get one number
3. go to https://bios-pw.org/ and enter that number
u will get one code
4. code u should enter in password column
I am unable to reset my I tunes password and I am locked out from purchasing
Yes its because maybe you entered the wrong password many times.It will take a day or so and then what you do is without trying to enter old password just go to reset it.
Blackberry id password forgot
It is wise to set a password on your BlackBerry, just as you would on a laptop or PC.
After all, BlackBerry devices are similar to small personal computers.
They contain loads of information including files, phone numbers, dates and emails. But when you forget your password you are presented with a tough situation the device will have to be completely reset to allow you to create a new one.
Come to terms with the fact that in order to reset your forgotten BlackBerry password you will lose all of the data on your phone.
A password reset wipes the device clean as a way to protect your information in case the phone is stolen it is a tight security measure that is built into BlackBerry phones.
Type in the incorrect password. The BlackBerry will tell you how many more tries you have to enter the wrong password before it resets (you usually have between three and ten tries total.)
Continue entering the wrong password.
You may be prompted to enter the word "blackberry" a few times to continue this is to make sure that you (or a child ) aren't accidentally and unknowingly typing in the wrong password.
Allow the device to reset itself and shut down.
Try to restart the BlackBerry.
If nothing loads, the application software was removed as well and you should proceed to the next step.
If you see your normal screen, proceed to the last step below.
Connect the device to your computer via your USB cord (this comes with your phone) and load the Blackberry Desktop Manager software (if you don't have it download it at na.blackberry.com/eng/services/desktop).
Click "Application Loader" then "Add/Remove Applications."
Select "BlackBerry System Software" (along with any other applications you want to download to your phone) and then "Next."
Verify the list of applications you want to download on the next screen and click "Finish."
Allow the Blackberry software to reinstall.
Enter a new password under "Options" then "Password" (or the similar choice) on your BlackBerry.
http://docs.blackberry.com/en/smartphone_users/deliverables/27236/amc1343243247856.jsp
http://www.bbhub.com/2006/10/27/heres-how-to-reset-your-blackberry-password/
I forgot my password, where do I go for assistance so they can email me my password
Resetting the System Password
If you forget your password and still cannot remember it after seeing your hint, click the I still can't remember the password link.
The Reset System Password page opens.
To obtain access to your system:
1. In the System Key field enter the 10-digit system key located on the bottom of your gateway.
2. In the Enter New Password field, enter a new system password. In the Confirm New Password field, reenter the system password.
3. In the Enter Your Hint field, enter an appropriate hint as described under "Setting a System Password" .
4. Click Submit.
Setting a system password protects your gateway settings from being modified or changed by someone who has not been given permission to do so. After setting a system password, you will be required to enter it whenever you attempt to access a gateway configuration page - for example, if you try to change the gateway's broadband connection settings or upgrade the gateway software. If a password has not been set,
a reminder notice is displayed when you attempt to access pages where settings can be changed.
To set your system password:
• Open a Web browser and access the gateway user interface by entering
http://gateway.2wire.net.
• Click the System tab.
• Click the System Password link in the System area of the Network at a Glance panel to open the Edit
System Password page.
1. In the Settings panel, click the Enable checkbox.
2. In the Enter New Password field, enter your password.
3. In the Confirm New Password field, re-enter your password.
4. Optional: In the Enter Your Hint field, enter a hint.
A hint is a word, phrase, or question that reminds you what the password is. There is an I forgot the password link on the password entry page. When you click this link, it shows you your hint and allows you to enter your password.
5. Click SAVE.
Forgotten log in password
Which system do you use?
On windows xp, try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
If that doesn't or you use windows 7 or vista, try this:
1. Enter a computer that can link to Internet. Download Windows Password Recovery Tool 3.0 and install the software on that computer.
2. Run the software and create windows password reset disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to reset your password.
5. Now login Windows and set a new password.
Resource: http://www.windowspasswordsrecovery.com
I am using Acer travelmate 4052 model for past 6 years. I used password for booting system. Today I tried to remove my BIOS password using BIOS setting. System asked me current password. So I entered the...
Try "1" or "/" or "A" or some messy combination of keys because it seems like you probably had a typo during setting the new password. Try "Spacebar" try "]" or "[" etc for a password, if you can figure it out you can reset it to nothing again just be careful. Otherwise research acer travelmate bios password removal. Also that computer is kind of old, so if there's nothing on it of importance, I'd replace it. If you need data try your friendly computer shop.
1helpful
2answers
Its says enter the password am entering the password but it says wrong there is so many pics in side it plzz help me
I am glad to HELP YOU!
There are two things that you can do now...
1. Reset password from another user account with administrator credentials
If you can't log on to Windows by using a particular user account, but you can log on to another account that has administrative privileges do like this -
# log on to Windows by using an administrator account that has a password by starting XP in SAFE MODE
# START > RUN and type "control userpasswords2? then OK
# click the user account that you forgot the password for, and then click Reset Password. Type a new password in both the New password and the Confirm new password boxes, and then click OK.
2. Using a third party recovery tool
# use another computer that has access to Internet
# download Windows Password Unlocker and decompress it on that PC [it is a *.ISO file so you have to burn it to a CD/DVD]
# insert the created CD/DVD into the locked computer
# reboot the locked computer and then follow the instructions.
# set-up a new password; go to CONTROL PANEL > USER ACCOUNT > select the account you wanna to set a new password > click CHANGING ACCOUNT and SET UP PASSWORD and fill up the form > CREATE PASSWORD > done!
GOOD LUCK!
Wireless-g
Hello, You can reset the router to default. On the back of router push in the reset button/hole for 10-15 seconds. The defaults will be: IP address 192.168.1.1 User name admin. You shouldn't need a password. From there you can change username, password, SSID and enable WEP or WPA security. Hope this helps.
Grand Canyon Tech
Grand Canyon Tech
