Question about Hotpoint HSS25GFP Side by Side Refrigerator
Fish smell in the refrigerator
I have had a hotpoint fridge/freezer for over two years, and recentley i've noticed this horrible fishsmell inside the fridge. I took all the shelves out and cleaned it top to bottom, but i couldn't get read of the fish smell. Please help me and let me know how i can get read of the smell in my fridge. Rgards Pari
  • 1 more comment
  • parivash Mar 26, 2008
    P.S I would like to point out that i don't even like fish, incase, if you think i had a row fish put in my refrigerator to cause the smell. It had happened once befor and i just cleaned it out with sponge and soapy water and it was fine, so i don't understand why it didn't work this time.
  • Anonymous Jun 08, 2008
    yes I have a bad fish oder too. but my fridge is brand new! 3 weeks old. should I call Sears and let them know? I cant keep anything in there because the smell travel to all the fruits and veggis.. HELP!!
  • Joandoor Jun 09, 2008
    I have the same problem everything smells like fish freezer and fridge I have washed everything and the bottles and it still is there.
GRAB YOUR CHILDREN AND RUN FOR YOUR LIFE!!! THERE'S NO STOPPING IT!!!
Posted on Jan 31, 2010
  • 828 Answers
Check the lower door gasket and clean if necessary. Check the drain pan under the refrigerator on left side bottom behind the toe plate below the door. Clean if necessary.
Posted on May 23, 2008
Bad smell from fridge (not mouldy food)?
There is no danger if there is a leak, but the refrigerator will quit cooling. I suspect perhaps you have a dead something underneath or behind the refrigerator. I hope this helps... but I also suspect you have cleared the problem by now.
Mar 25, 2014 | Freezers
I have a Kenmore Elite refrigerator model number 59673503201 and there is a terrible fish smell coming from the bottom portion of the appliance where the freezer is. It is not coming from trash, or food...
Please note when you keep fish in freezer once, the smell will be longer even you remove it. O.K. Now solution for your problem- Please unplug power.Keep fridge door open. Take wet cloth dipped in soap water and clean all compartment including freezer . Keep freezer door also opened.Then clean with dry cloth. Spray room spray in your room not into the fridge. And allow 5 hrs to circulate fresh air to pass thr' your fridge and then close fridge and freezer doors. Plug fridge and run for one hour on empty. After one hour store items in fridge and/or freezer.
Keep all food items in closed style which will avoid odor spreading and also be a hygienic. Thanks.
Jan 30, 2011 | Refrigerators
My refrigerator smells horrible! And there isn't anything dieing inside. Please help, it makes all the food taste and smell bad. What do I do?
switch it off.manually defrost whole unit,clean all vents/drain holes, wash interior out with bicarb and dry well.leave door open for 12/24hrs to dry out then switch unit back on and leave (empty) to settle down to operating temp 32/36f is normal for a fridge.then load up as usual.smell like wet cardboard/felt ? is "grow your own penicillin".
Feb 23, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fish odor in freezer and fridge
Unplug first. You will need to clean the inside of the refrigerator and the freezer with a good cleaner and warm water. After this you need to remove the rear panel in the back of the freezer and spray water with Clorox on the evaporator coil and pour some of the solution down the defrost condensate drain to disinfect and remove the odors that drain down that hole to be evaporated and returned to the air in your home. That should take care of the fish smell, Please rate my solution, Thanks, Sea Breeze
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigerator smells on the outside!
Mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section . Too much bleach and the smell of bleach would be circulated by the fan to the room , so be sure to add water .
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
Apr 01, 2009 | Refrigerators
Freezer has bad smell, cleaned entire fridge and freezer out, no help. working fine but smells ?? side by side model about 5 years old, maytag
For odors in the refrigerator/freezer try baking soda or, for tougher odors, try Fridge Aid deodorizer, also available in the accessories section of our website. on  www.repairclinic.com
Mar 31, 2009 | Hotpoint HSS25GFP Side by Side...
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
2,276 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
