Question about Polaris 800 Twin Sportsman Ride on Toy
Battery dies after a few minutes - Polaris 800 Twin Sportsman Ride on Toy
    Genius:
  • Polaris Master
  • 1,508 Answers
Charge the battery to a full charge then check the output with a multimeter and make sure that it is showing over 24 volts
Posted on Mar 30, 2012
  • 8,404 Answers
Is this a toy? Is this equipped with deep cell batteries? Checked the water? Check the voltage of each battery in the pack ... should be 6 volts each ... charger putting out? Check while charging ... should be 25+ volts (make sure you measure DC.
If you have a battery that is particularly low ... it will have to be charged independently ... If this is the case, with a 6 volt charger - charge that battery. If you have two batteries that measure low ... you can charge with a 12 volt battery. You will not have to disconnect anaything to do this ... just watch what you are doing ... do not use the unit charger AND the 6 or 12 volt charger at the same time.
Posted on May 02, 2010
2 Suggested Answers
adamfjeld
  • 1508 Answers
SOURCE: Polaris 800 Twin Sportsman 2 Seater 24 Volt Ride on Toy by: battery dies after a few minutes...
IS it the battery dying or the thermal switch kicking out
Posted on May 23, 2012
2004 Nissan Altima 3.5L BATTERY LIGHT went on during 15 minute drive. Next day car "died" while idling after a 20 minute drive. BRAKE WARNING LIGHT & BATTERY LIGHT on prior to full electrical failure.
Start with checking the alternator voltage with a multimeter. With the car off check the voltage in the battery which should be holding 12v charged less if flat of course then start the car and test the battery again. If the alternator is good you should be getting a reading of 14 to 14.5 v if it's the alternator it'll A) not put any charge into the battery or B) be a very low voltage being anything under 13.5 v
Sep 30, 2016 | 2004 Nissan Altima
My 1989 cadillac deville was running yesterday got in it this mourning it starts right up after 10min of running it dies i jumped it off it started back up then died again now when jumping justclicks
Sounds like you have a faulty alternator, sir. Your car seems to be running off battery power. Once the battery power is exhausted, the engine dies. It will start and run again if you charge the battery, but only for a few minutes until the battery dies again.
Nov 02, 2015 | Cadillac Cars & Trucks
F250 diesel cold start problems
2004 f250 6.0 diesel trapped in extreme cold temps -30 plugged truck in put anti gel in added 10 more gallons of fuel. Truck will start run a few minutes and die. will not restart immediately but if wait 20 or 30 minutes it will start run few minutes and die again. Tried repeating process many times same result. Batteries now dead charging now. Can you help need truck to help others with groceries and medical needs.
Nov 21, 2013 | Ford Cars & Trucks
I just replaced battery and alternater but the battery died hile driving and once i jump the car it ill run for thirty seconds then die.
you've had the misfortune of getting a bad rebuilt alternator-sorry-they should give you another one -I hope its not hard to replace-Denny
Nov 05, 2013 | 2004 Chevrolet Impala
Car dies when i turn on headlights
Have a load test done on the battery as it sounds like the battery is failing and the extra load from the lights is taking the power from the ignition system and so the coils fall below operating voltage and so no spark. Also alternators need some voltage from the battery to start charging and if there is insufficient voltage from the battery it won't work
Feb 27, 2013 | 1990 Toyota Camry
Norelco 8894XL will not take a charge
Sounds like you're getting to the end of your natural battery life. As for replacing the batteries, it's not an easy job. You need to have a special Torx screwdriver to undo the screws.
The batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant)
It may be worth speaking to your local Philips Service Center (refer to www.philips.com)
Not being at work, I can't check whether your shaver is a mains/rechargeable, but if you plug it in and it works full power immediately you've got a workaround. I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Apr 15, 2009 | Norelco 8894 XL Electric Shaver
Aspire 3610
Your Batterys Dying/Dead/Surrendered/Knackered/ et,c.
Use your Laptop On A/C Mains power. buy a new battery.
*******FIXYA********
Thanks mike @ compurepair.
Feb 28, 2008 | Acer Aspire 3610 Notebook
Polaris 800 Twin Sportsman Ride on Toy Logo
324 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
