Question about Weber Genesis Silver A Grill
Middle burner is low flame on left and no flame on right
  • 8,404 Answers
Clean the burners and the valve(s) ... you probably have spiders. Spiders love the smell of the gas
Posted on May 02, 2010
Low flame on left front burners high flame onright front burnners
That is food/grease buildup. Clean the holes. TURN OFF GAS to stove, then just clean the holes in the burners with a soft wire brush. Then turn gas back on and immediately relight pilot lights. If that sounds scary, call your gas company, they might come out and help.
Dec 09, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Only left side of burners working
If you have the Cal Flame burners that are straight, cast brass burners, there is a slot under neath the burners on the back end of the burners. This slot allows the flame to move from the left side of the burners to the right side of the burners. This slot in the burner will corrode shut and not allow the flame to move from the left to the right side. Sometimes you can scrape out the corrosion, and sometimes you can not. If you can't get the slot open, then you have to replace the burners. Cal Flame burners also have a reputation for warping.
Mar 04, 2012 | Cal Flame 4-Burner Drop-In Grill
Adjusting front (most powerful) burner on kitchenaid (Left front)
There is an air port near the adjustment knob. Open for a more blue flame and close for a yellow flame. If these haven't been moved before, you probably have a clogged jet at the burner. Just clean it out with a pin.
Feb 04, 2012 | KitchenAid Blenders
Left burner produces a normal blue flame, but the right burner produces a big yellow flame - how can I fix this?
Hi inomura...
Look at the left burner, pipe,air hole adjustment,etc because it is operating good.
You will see a difference to it compared to the on the right.
The right pipe, air hole, or the length the pipe that are iserted in the gas control valve is different from the left.
The yellow flame indicates that not enough air is getting to the flame getting to the right flame ignition point.
The left flame is nice and blue...normal, the right is yellow indicating that not enough air is getting to the flame ignition point...look to see if the air hole adjustment is different than the one on the left...there is something open more or less, improperly adjusted.
Once you have it adjusted properly the right flame will burn bright blue just as it does on the left.
Please take time to rate me
Sep 04, 2011 | Coleman Roadtrip Grill LXE 9949-750
I just bought a brand new kenmore elite grill (for $199). I am new to grilling. The burners seem low - the one on the far left in the back has a flame but all other flame levels are low. Also, I cannot...
If the burners are set to the high setting and the flames are still very low, you may have a bad propane tank. The valves on the tanks go bad sometimes. Take the tank back to where you bought it and tell them you think the valve is bad. They should exchange it for free assuming it still feels full. This has happened to me before, i thought there was something wrong with the grill and it was just a bad tank.
Jun 06, 2011 | Kenmore Grilling
Good Afternoon..On my Tuscany grill only 1 of the 3 burners work. looking from left to right, the left one does not work at all and the middle burner barely. No smell of gas on the 1st and very little in...
Sounds like the offending burners need to be removed, checked thoroughly for clogs and particularly the venturi valve on each burner. And while you have them out, remove the burner orifice of each burner and look for clogs.
Hope this helps you to further troubleshoot and solve the problem. Happy Grilling!!
Apr 19, 2011 | Altima Technologies AGR48PF Grill
Light flashes seven times indacading low flame
There is a sensor located on either the far right or far left of the burner tray. It will be in the path of the flame on the last burner that ignites. Take a scrub pad and clean the rod. Check all wire connections for good connections.
Mar 21, 2010 | Goodman Heating & Cooling
Flame going low on range cook-top
Check your gas supply is not running too low and then check for leaks, Let me know if this helps.
Jan 02, 2010 | Tappan TGF320 Gas Kitchen Range
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Low flame signal
There is a small probe that is located inside the firebox and the flame from the burners will touch it. Typically it is located to either the far left or far right of the fire box if it is a vertical furnace. if the flame is not touching it or if it is taking the flame too long to travel across the burners (right to left or left to right) you will get this error code. Find the sensor and clean it with a small wire brush. Make sure what you think is the flame sensor is the flame sensor because the ignitor is very brittle and has two wires going to it. The flame sensor will have only one wire going to it. Also since you have the burner compartment open, inspect the flame spreader tray for blockage not allowing the flame to spread quickly. A can of air and the small wire brush will aide you in this cleaning.
Good luck to you!
Dec 05, 2008 | Goodman GMS90703BXA Heater
Weber Genesis Silver A Grill Logo
172 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
