Question about Hitachi Televison & Video
We have a six month old 32 inch Hitachi TV. I accidentally pressed the PC button and now the picture and sound have gone
  • 4 more comments
  • c_db May 02, 2010
    All I get is a blue screen and a message "No Signal" and a countdown for about 4 mins and then the TV switches off
  • c_db May 02, 2010
    When I press the Input Source button I get a list of possible sources with "TV" at the top. I go through the list until the arrow points at "TV" again. This highlights in yellow. The countdown starts again and the TV switches off. When I turn it on again I get the same "No signal" message
  • c_db May 02, 2010
    The model is 32LD30U A
  • c_db May 02, 2010
    TV is connected direct to external aerial, nothing else is connected to it.
  • c_db May 02, 2010
    Oh thank you!!! This area has only just gone 100% digital and I didn't know that I had to choose the second choice on that list instead of the first one. I feel stupid now. My excuse is I'm not as young as I used to be. Thanks a million for your help, and goodnight.
  • c_db May 02, 2010
    Thanks so much for prompt and courteous messages. Your help greatly appreciated. TV working properly again. Now the only thing is to find some decent programmes.
  • Hitachi Master
  • 19,396 Answers
Hi.
Try pressing the Input Source button several times.
If that does not work, try turning TV off and disconnecting the TV power cord for ten minutes.
If still no luck there may be an additional problem. In that case check cables and connections, ensure that menus are coming up on screen, and eventually give me the model number. Also tell me if you can see on screen menu.
Posted on May 02, 2010
  • 2 more comments
  • Ginko
    Ginko May 02, 2010
    Hi.
    You may get No Signal because the TV is tuned on the wrong channel. Locate the Input\Source button and press it untill you select TV. If there is a TV button , please press it.
    Try turning TV off and disconnecting power for a couple of minutes.
    If still no luck, please tell me TV model.
    Regards.
  • Ginko
    Ginko May 02, 2010
    Hi.
    There is digital TV and analog TV tuner installed on most new TVs.
    Please ensure you have tried both.
    Also have a look at the antenna cable at the back. Turn TV off first.
    Let me know if TV is connected to a receiver box.
    Also please tell me the model, that would make things easier over here.
    Thanks.
  • Ginko
    Ginko May 02, 2010
    Hi.
    You need to select the source DTV for digital TV.
  • Ginko
    Ginko May 02, 2010
    Hi.
    You are welcome.
    Have a good night as well.
    Ginko.
No Picture or Sound from ASTAR 32 inch LCD Television
There is Part Store having Astar LTV-27BG boards in stock. Please check out might help you to power up back your TV.
Regards,
Aug 28, 2008 | Astar LTV-3201 32 in. LCD Television
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Apr 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Feb 07, 2008 | Hitachi P50H401 50 in. Plasma HDTV
STANDBY BUTTON
call 1-800-256-2487 they will help (maybe)
Dec 10, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Sound, but no picture
Had the same thing today. Iwas playing with the auto demonstration of on screen displays. Press and hold the power button (5 seconds) on the TV. The auto display will play. Press the power button again (TV will go off). Turn power on again. you should now have the picture back
Nov 14, 2007 | Hitachi 53FDX01B 53" Rear Projection...
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 32 No Picture or sound
if you are hearing a click and electrical statics when you try to turn it ON, the flyback of the tv is busted there are alot of reasons for that problem lighting is one so dont leave the cable screwed in if ever youre going out for a long time. you can have it replaced by a technician ( flyback). but it would cost you. and im not sure if you can find an orginal flyback considering its 10years old. there are replacement flybacks but quality would not be as good as the original one.
Oct 06, 2007 | Hitachi 32UX51B 32" TV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
