Question about Black & Decker PS145 18V Battery
18v battery lasts 10-15 minutes after the charge. How long should I charge it for to get full usage?
  • marksbfg May 08, 2010
    How old are the batteries you're talking about. Mine are less than a year old
    President:
  • 512 Answers
Black and decker older batteries don't keep a charge. Very poor quality. You can't get them to work any better than they do. You need to replace will the new ones they sell, made better. But cheaper to buy new tool with batteries included.
Posted on May 03, 2010
  • Frank Meola May 08, 2010
    If yours are less than a year old, they are still under warranty. Call Black and Decker and tell them. They should replace them being under a year old. My batteries where around 1-2 years old. A battery will charge on the charger till it thinks it is charged. The charger light will change color. You can leave on the charger all the time, when a battery is charged and you remove it, it starts to loose power even when not using it. Try leaving one on the charger, see if this helps, when you remove to use put the other one on charge.
How long to recharge a 18v dewalt drill battery
A fully working 18v Dewalt Battery will only take 90 minutes to just over an hour to fully charge from going flat. This fully charged battery should last about 4 hours of use (depending on the load). So the answer is 1 hour.
Aug 11, 2013 | Drills
My makita batteries nolonger charge
Lithium batteries do have a life span determined by how many times the battery is discharged and recharged and how hard it is worked on the tool. Batteries get hot while charging and discharging and heat is what ages batteries. Lithium batteries, depending on usage, will last from one to three years. I've seen some last five years but that's rare. They also have numerous cells and a circuit board that can go bad and kill the battery. Chargers are designed to check the battery's condition and won't charge a battery if it detects something wrong. If your battery is under one year old, it's covered by the warranty. If it's over, you'll have to buy a new battery.
Mar 03, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Revive drill driver battery packs
Rechargeable batteries do have a lifespan, they won't recharge forever. If you have fully discharged the batteries then fully recharged them and they still don't have full power or they only last a couple minutes then they are done. If they won't charge or the charger shows them as defective, the only fix is to replace them.
Jan 29, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on...
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
May 05, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Battery will "fully" charge and then only run for 20 - 30 minutes of use then be discharged. Have fully discharged and re-charged to no avail. My other battery will run for 2-3 hours of use.
Hi Fred,
I have several 18v tool sets and for the most part I'm quite satisfied with their performance. I currently use Bosch and Ryobi.
When used with the drill, a battery can last me the whole day. On the other hand, the sawzall will eat them up pretty quick.
The thing I've found common to all brands is that it is absolutely crucial to make sure the batteries are fully charged before they get used for the first time. That first full charge seems to set the bar for subsequent charges for the rest of the batteries life.
I too, have tried the discharge/recharge thing. No help. I can only suggest a new battery and letting get all it can take from the charger the first time out of the box.
Since I've been doing that, I rarely even think to bring my charger to job sites, there's that much of a difference in performance.
Hope this helps you out.
Best regards,
Mike
Mar 31, 2010 | Bosch 18V Brute Tough Drill with Blue Core...
Battery doesn't charge
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced. This can happen if the power chair has not been charged in a while or has been stored. Having the chair on or off while charging will not affect the charging process, but you ususally want it to be OFF.
Mar 11, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Both green and yellow light stay on and batteries will not charge 18v
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
Oct 19, 2009 | Ryobi Multi-Volt Battery Charger
Grass hog 18v nst2018 trimmer
Sounds like faulty batteries , take it back to the store where you bought it.
Aug 26, 2009 | Black & Decker String Trimmer Cordless 12"...
Battery charge problems Ryobi 18v
Solution is two fold. Will try the freeze and re charge approach today and do this a few times. The long term soluiton is to purchase two Lithium batteries and a duel chemical charger. Expensive solution but seems it will work.
Jan 16, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Black & Decker PS145 18V  Battery Logo
267 people viewed this question
Top Black & Decker Measuring Tools & Sensors Experts
Vuk B
Dennis
frankrome
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
