Question about KitchenAid Architect II KHTU705S Stainless Steel Kitchen Hood
Hi, I bought the hood fan and the problem is it has 4 threaded nuts fixed on the top sections for fixing the hood. It is difficult to make correct judgement to make a hole to fix screws from the top of the cabinet. Since the blower weight is heavy, it is not easy to hold correctly to take measurement. Could anybody advise me to get this solved easily.
  • 8,197 Answers
May I get the make and model # to help you more so I know what hood you have.
Posted on May 05, 2010
Are the squirrel cage rotors fastened with a conventional thread direction or are they reversed threads?
I bought an older unit Viking Ultra line range - Fixya
www.fixya.com/support/t2535668-bought_older_unit_viking_ultra_line
Jul 7, 2009 - Question about Viking Range Hoods ... There is a set screw holding thesquirrel cage fan in place which I unscrewed .... Are the squirrel cage rotors fastenedwith a conventional thread direction or are they reversed threads?
Apr 27, 2015 | Viking Kitchen Ranges
How to change radiator fan blade on 1998 Toyota Tacoma
You must never have opened the hood &
even looked or ever worked on a vehicle
Appears all the motor options have 4 studs & 4 nuts
holding the fan clutch assy on & 4 bolts holding the
fan blade to the clutch
Nov 20, 2014 | 1998 Toyota Tacoma
Noisy loose fan.Found a nut in the fan and trying to get it to stay on fan shaft but keeps falling off. Will this fix problem if can get it on?
Take the nut to a hardware store and ask for a self-locking nut. That type nut shouldn't spin off again. That MIGHT solve the noise problem, if the fan blades are wobbling, or the shaft is spinning within the fan's center.
Mar 05, 2014 | Broan-NuTone PK22 Kitchen Hood
Draft from Cooker Hood
Grease build up could be causing the shutters to stick, There is no way around the issue of inspection. Just make sure the power is off.
Dec 23, 2013 | Kitchen Ranges
Bolt thread size for 1967 Jag hood 340 Mk II ?...looks like 1/4" x 3/4" very fine thread but Metric & SAE doesen't fit... nuts welded in hood...Dr. Muehlig
Metric Bolts-- the smaller ones-- come in 3 thread
pitches,so you need to find the correct one
Take out one on the other side as your sample
Aug 09, 2013 | Jaguar S-Type Cars & Trucks
The bobbin thread is loops on top of the fabric even when the top thread is loosened to 2
if you've taking the machine in 4 times to be fixed,,sounds like you need a different sewing machine repair shop.
have you tried changing needles?
have you tried rethread the top & bobbin thread
is it possible the bobbin thread in not correctly inserted in the bobbin case?
try a top thread tension of 5 & see what happens?
Jan 20, 2012 | Brother Sewing Machines
Which direction do i have to turn the nut to unscrew my mahindra bolero fan?
Hi I have seen several scrap fan motors because one did not ask which way but just tried! You are clever by checking first
There are two ways I determine the correct way!
1) See whether there is a piece of the thread sticking out past tghe nut. See whether you can make our the threads/. The threads are slanted!
Turn the nut in the direction that will slide it along the threads in the direction that you want ot to exit!
2)
Remember that the fan nut & direction was designed as a self tightening mechanism.
If you look at the shape of the blades, ou can figure out which way the motor have to turn to propell the wind in the correct direction. now imagine, you are holding the fan, and the bmotor is trying to turn the fan. See what way you have to oppose the motor's push. That way is tight! So turn the nut in the opposite direction.
Andy
Sep 04, 2011 | Mahindra Scorpio Cars & Trucks
Lost the nut off the central post (holds on fan), apparently it is a strange thread, no one can match it that i've found
Hello ky_moonprinc:
You should be Able to Purchase this Nut from Sears Direct.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 06, 2009 | Craftsman 4 Cycle Blower/Vac
How do you get the water pump and fan disconnected from each other on a 1997 Dodge Pickup truck 318 motor?
you need a special tool , a fan nut tool , it's like a 1-1/2 " ,actualy a little smaller , i use a 1-1/2" wrench and smack it with a rubber mallet , but there is a tool for it , i think checkers auto has a loan -a-tool program , but to buy it is expensive , it is normal threaded - counter clockwise is off . a special tool holds the 4 bolts on the pulley and the other part of the tool fits on the big nut . sorry i can't fix ya , cuz who has a 1-1/2" wrench or the special wrench in there home arsinal .
J5
Jan 22, 2009 | 1999 Dodge Ram
REMOVAL OF FAN
Ha - I found the solution myself. You need to remove the 3 screws securing the fan motor. Once you've done this, you can wiggle the fan a few mm, far enough to be able to remove the top element screw.
Jul 09, 2008 | Neff U1721 Double circotherm Electric Oven
KitchenAid Architect II KHTU705S Stainless Steel Kitchen Hood Logo
100 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
