Question about Panasonic PT-50LC13 50" Rear Projection HDTV
The tv will not turn on. I need to change the bulb in the tv
How do I change the bulb? I have a new bulb but Im not sure where it is in the tv
    Sergeant:
  • 418 Answers
Snap-off lower front panel ( about 4" tall x width of TV.) Door behind there with philips screw. Philips screw for lamp itself.
Posted on May 02, 2010
I need a new bulb for my tv model no. PT-52LCXX66-K and Im not sure how to look for one or where to find it...
Tries websites like partstore.com,Ebay.com to buy one.U know how to replaced the bulb?U can what a tutoring video on You Tube,just type ur tv model and make it will have it or it close to ur models.
Apr 14, 2010 | Panasonic PT-52LCX65 44" HDTV
Tip
How to Replace the Bulb in a Projection TV
Instructions Things You'll Need:
  • Rubber gloves
  • Replacement bulb
  1. Step 1 Turn off the TV, and unplug it. Make sure to disconnect it from the outlet completely.
  2. Step 2 Locate the bulb door of the TV. This is often on the back, near the power cord. Slide the door open and reveal the bulb.
  3. Step 3 Unscrew the screws. Some screws are thumbscrews, while others may require a screwdriver.
  4. Step 4 Gently remove the bulb. Pull the bulb out of the compartment, usually by grasping a handle and then pulling out and slightly down.
  5. Step 5 Install the new bulb. Line up the groove on top of the new bulb's housing with the groove pocket on the inside of the television. Slide the new one into place.
  6. Step 6 Tighten the screws. Do not over tighten them; they should be finger-tight only.
  7. Step 7 Close the door. Make sure it is closed completely or the TV will not operate.
on Mar 24, 2010 | Televison & Video
What bulb to get for my m50wh72s
Check this website to find a replacement lamp for your TV. You will need to use the housing from the defective lamp.
Dec 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung dlp tv: was indicating need a new bulb change. changed bulb and now will not work.
u sure it pluged in all way unplug tv take bulb out look at bulb not broken in side is it re set it in then reset lamp life on tv
Oct 06, 2008 | Televison & Video
RT 52SZ30
I have a 52" LG Prjection TV model number RU52SZ30 and it turns off after 45 seconds, also the blinking lights flickers on the lamp. What should I do first replace the lamp or reset the tv and how can I reset my TV. If a lamp problem where can I purchase one and how much and if I buy a lamp and I still have the same problem what do I do now.
Thanks.
Sep 03, 2008 | LG RU-52SZ30 52" Rear Projection...
Only have a green colour for all tv and dvd pictures on Samsung Tantus Rear Projector TV (Model # SP-43J8PF). Is this the globes or is it stuffed?
ok hi there now inside a rear projection tv is 3 globes i big mirrior
and all the wires are under now it sounds like you do need to replace the globes but to be sure the others are ruined you can pull it apart take the screen off
so now u can see inside u will see three bulbs full of liquid
make sure none is leaking as they can
then turn on your tv (its all safe) put on a channel and look at the bulbs to see if one or any aint workin
if there are working turn tv off and get a lint free cloth or tissue and wipe the top of the bulbs do not turn them adjust them at all
need any more help im chris07551
Jul 18, 2008 | Televison & Video
JVC HD-52G786 shuts off
Do you have your TV plugged directly into the wall? You cannot plug into a power strip, it needs its own direct power source. Also, I have heard that there can be electrical problems inside. I have this same model, I love it, picture and sound. I just replaced the bulb for the first time last night. It was a little premature to replace it now but I know what caused it. I bought a new bulb and it works like a gem. If you ever need to change the bulb do it yourself. It takes maybe 2 minutes. The bulb looks like the Flux Copassitor and all you do is remove the door in the back on the side. Unscrew the the 2 screws that hold the bulb in and just pull out. When you put the new one in make sure you do NOT touch the glass on the new lamp. Just slid it in and screw the 2 screws back in and make sure the door is closed and tight. My uncle had a service guy do his and he got raked for 5-$600, The bulb costs about $200. Should last about 5-6 years at a rate of 5-6 hours of TV on time. Hope this helped. If not, sorry, but at least you know how to change the bulb. Good Luck!!!
Apr 07, 2008 | JVC HD-52G786 52" Rear Projection HDTV
915P043010 have the bulb
Pull the panel off where the speakers are the entire plastic lover comes off. Next, make sure the tv is unplugged and has been off for at least 15 min, preferably longer. See the box with 4 screws take those out... it should have a set of instructions or some sign saying it contains the bulb. Anyway.. after that door comes off, peer inside and you'll see the bulb about 6-8" back and has set screws which must be unscrewed completely before it can come out. Be careful, don't yank the bulb out. Then place the new bulb in, reverse the process I told you, plug the tv in and reset the bulb when it askes if you changed the bulb.
It is really easy on mitsubishi tv's to change them... post back if I can be of further assistance.
bob
Mar 10, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Power on?
im looking for this solution also
Feb 27, 2008 | Toshiba 44NHM84 44" TV
Shuts off after 30 seconds of Play
is the set still under warranty,if so call for service if not when you turn it on try to listen near the side of the unit for a fan noise or high voltage arc sound and do you see light on the screen or in the rear of set.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
184 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
