Question about Casio FX-9750GPlus Calculator
Can i store text on a Casio CFX 9850 GC Plus calculator
Will i be able to store txt files or text in any other format in the Casio CFX 9850 GC Plus calculator. If yes how do i go about it
3 Suggested Answers
  • 8068 Answers
SOURCE: how to calculate the coefficient of linear
Although the coefficient of correlation is well defined for a few regression models, you do not calculate it directly because your calculator does that for you.
I could just tell you that it is displayed along with the statistical results (equation of best fitting curve, ) but if you do not know how to do that you will just shoot my post. If you know how to do a linear regression, stop right here and ignore what follows.
For those interested: How to do a regression on the calculator
I am sorry but I will have to assume that you know how to enter the data through the [MENU][STAT].
  1. After you finish entering all the data
  2. Press [F1:Graph], select Gph1, Gph2, or Gph3.
  3. Once the graph of the experimental data is drawn, you will have access to the diverse regression models.
  4. Your choices are
  5. [X:Linear]
  6. [Med-Med],
  7. [Quadratic :X^2]
  8. [Cubic;X^3]
  9. [Quartic: X^4].
  10. Press [F6] to scroll right to access the others
  11. [Logarithmic:LOG],
  12. [Exponential :EXP],
  13. [Power :Pwr] and
  14. [Sinusoidal: Sin]
After you select a model and press [EXE], the screen displays the equation and its various coefficients, a correlation coefficient if it has meaning, etc.
On that same screen, you have a menu option [F6:Draw]. If you select it, the regression curve will be drawn on the same screen as your statistical graph. This allows you to judge if the fit is good. If it is not, you have the option to choose another model.
The other option [F5:Copy] allows you to save the regression equation in the Y1, Y2, etc. variables.
Posted on Jan 03, 2010
  • 8068 Answers
SOURCE: How do i use this calculator (casio CFX 9850)to find the variance
Part A shows you how to enter your data and calculate some statistical values. Keep in mind that the variance is the square of the standard deviation.
You can safely ignore the PART about REGRESSIONs until that time you need the information.
PART A
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the satistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Exemple: Enter the following values in List 1
1st line enter 90 [EXE]
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
When finished you press [F2:Calc], then [F1:1Var] and the statistical results appear on screen.
Title of screen : 1-Variable
x bar =74.7142857
Capital Sigma x= 523
Capita Sigma X squared = 39851
x lower case sigma n = 10.5249945
x lower case sigma n-1= 11.3682934
n = 7
Scroll down with Down arrow to access other data
minX =56
Q1=68
Med =75
Q3=85
Xbar -x lower case sigma n =64.1892911
x bar + x lower case sigma n = 85.2392802
maxX=90
Mod=90
All you have to do now, is to look at the theory you learned and interpret what these values mean.
PART B
  1. Once you enter your data [MENU][STAT],
  2. press [F1:Graph],
  3. select Gph1, Gph2, or Gph3.
  4. Once the graph of the experimental data is drawn, you will have access to the diverse regression models.
  5. Your choices are
  • [X:Linear]
  • [Med-Med],
  • [Quadratic :X^2]
  • [Cubic;X^3]
  • [Quartic: X^2].
  • Press [F6] to scroll right to access the others:
  • [Logarithmic:LOG],
  • [Exponential :EXP],
  • [Power :Pwr] and
  • [Sinusoidal:Sin]
  1. After you select a model and press [EXE], the screen displays the equation and its various coefficients.
  2. On that same screen, you have a menu option [F6:Draw].
  3. If you select it, the regression curve will be drawn on the same screen as your statistical graph.
  4. This allows you to judge if the fit is good. If it is not, you have the option to choose another model.
  5. The other option [F5:Copy] allows you to save the regression equation in the Y1, Y2, etc. variables.
Posted on Jul 25, 2010
Why are function buttons (as f1 f2 f3 f4 f5 and f6) on my casio cfx-9850 not working?
Their use depends on the application you are using. You press a function key to activate the TAB that is above it (at the bottom of the screen.)
May 25, 2014 | Casio Office Equipment & Supplies
The F buttons on my Casio 9850 aren't working!
You can use the hardware resetting procedure. There is a button on the back of calculator that you can press using a straightened paper clip.
May 18, 2010 | Casio CFX-9850G Plus Calculator
Casio cfx-9850gb plus calculators's graph messed up
Press the RESET button on the back of the calculator. Use a starightened paper clip.
May 05, 2010 | Casio CFX 9850GB Plus Calculator
I need a manual for a Casio calculator
http://support.casio.com/manualfile.php?rgn=1&cid=004002005
May 03, 2010 | Casio CFX-9850G Plus Calculator
Connecting casio to texas instr
I compared two cables and noticed that they are identical. One insulating part on the TI cable is longer than the corresponding part on the Casio cable. But no matter, let us assume that the calculators share the same 2.5 mm connection.
You can verify the hardware compatibility as follows
  1. Use the Casio I/O cable to connect two TI calculators. The Casio cable wakes up the TI84PLus
  2. Use the TI I/O cable to connect to Casio calculators. The TI cable wakes up the Casio FX9550GII but not the CFX-9750GPlus nor the Graph 35. But that may not mean too much.
  3. Create a Matrix ( a 3X3 ) on one TI8xPLUS and transfer it to another TI8xPLUS using the Casio Cable.
  4. Create a small (3x3) matrix on one Casio C/FX-9750G/PLUS and transfer it to another C/FX-9750G/Plus.
  5. If you have been successful in any of the above you may try to transfer an object from a TI to a casio or from a Casio to a TI and the cable that worked above.
My feeling is that you cannot. I tried it
When I tried to transfer from a TI to a Casio, the Casio kept displaying RECEIVING , AC to cancel. The TI returned an Xmit ERROR
When I tried to transfer from a Casio to TI, the Casio quickly returned a Transmit Error, while the TI kept waiting for a transmission.
There may be other issues of memory organization, naming conventions, systems commands and program commands so on.
For each problem you want to have your students solve try to supply the procedures for both types of calculators. This, in my opinion, is the reasonable way to go. A benefit to you is that you learn the expert use of both types of calculators.
If you care to specify what kind of programs you intend to transfer from one to the other, one may be able to point you to some resources available on the web.
Apr 09, 2010 | Casio CFX-9850G Plus Calculator
Where to get free owners manual for casio cfx-9850g
Here is the link to all chapters in the book. You may want to use a pdf creator to lump them all in the same book.
Hope it helps.
May 27, 2009 | Casio CFX-9850G Plus Calculator
The calculator casio CFX 9850GA was not turning on..
first:you must clean battery compatrment in direction of contact point with good contact cleaner from any electronic store near you or from radio shack.
second:clean power switch with contact cleaner.
Dec 21, 2007 | Casio CFX 9850GA Plus Calculator
Casio 9850
Definitely not by asking in a forum. You could get a walkthrough, but that's not solving the problem.
This one is down to reading the calculator manual and your textbook a bit, then satisfying yourself that your answer and the definitions for those types of average are in accord. Mode is clearly an oddball which would make more sense with more context, but for now just pick the most common number, which is a set: (7, 10, 11).
That sounded better than 'toss-up between 7, 10 and 11,' did it not?
Dec 03, 2007 | Casio CFX 9850GA Plus Calculator
Casio FX-9750GPlus Calculator Logo
572 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
