Question about Finis Swi MP3 Player
I used to be able to get my swimp3 to work fine from my itunes, now even with the same songs as before it says there isn't enough space even though on screen the file is reading as empty? Does anyone know how to solve this have had similar problems?
    Problem Solver:
  • 10 Answers
Hi elspethje,
If you are using a MAC, you will need to empty out your trash to clear up the space you made from deleting songs. You can then reload your new songs for it to work properly.
Let me know if you have any further problems
-FINIS Tech
Posted on May 04, 2010
    Problem Solver:
  • 14 Answers
I haven't seen a similar problem, however, my first suggestion would be to try the RESET function.
Second would be to make sure you didn't load the songs into folders on the device - they will only work in the root directory.
Last, I would look for any NON-music files or folders. If you have accidentally transferred other files that could keep it from playing
Remember though, the Swimp3 Players are compatible with iTunes, however, they can't play any AAC / encrypted songs.
Good Luck
Michelle
Authorized Swimp3 Dealer
Posted on May 03, 2010
The music player of my Nokia 7210 Supernova isn't working because when I try to open it, it always say that "Not Enough Memory" even though I have so much of free space in memory card
Not Enough Memory error suggests that you dont have enough space to load the program into the Memory. Check Phone's Memory (It is about 30 MB total) if there is stuff in Phone's Memory then shift it over to Memory Card and cleanup the space in Phone's Memory.
It will definitely resolve this issue.
If even after wiping stuff from Phone's Memory doesn't work, reset the phone.
May 29, 2011 | Nokia 7210
SwiMP3 (128 MB) MP3 Player: I have the original first version of the Swimp3 pl...
This could actually be an easy fix. If you have any files on the player that are not WMA or MP3 files, or that you've stored your music in folders - either way it could simply stop the drive from playing.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
I hope you find this helpful.
Michelle
Swimp3 Troubleshooting Video
May 18, 2010 | Finis Swi MP3 Player
Songs from CDs won't play
Nick,
This is an easy fix. Most Mp3 players, the Aqua Mp3 player included, need to have the files in an mp3 format - not the CD format.
Simply convert your CD to Mp3 files on your computer using a software like Media Monkey http://www.mediamonkey.com/ (which has a free version). Once they are converted, then you can simply drag and drop them on to your Aqua Waterproof Mp3 player.
If you're using a Mac, then you can use iTunes to import the CD and then convert the files to mp3 within iTunes.
I hope this helps you get in the water and swimming to music soon.
Michelle
WaterproofMusic.com
Check out the Xtreamp3 waterproof mp3 player - great on land or inthe pool
May 09, 2010 | Finis Swi MP3 Player
How do I load songs from itunes onto the 1gb go
Ensure the sum of the file you want to copy is less than 996 Mb and the go gear has nothing else on it. Ensure it is not write protected.
Apr 12, 2010 | Philips Sport Personal CD/MP3 Player
My swimp3 holds up to 50 songs but at the moment i only have 29 on it. i want to put more songs into the player but every time i try and put a song in it, it tells me that there isn't enough free space. i...
this might be due to the large size of your files, if you have avg song length of 4 mins andsize around 5MB it will accomodate around 25 songs...
Oct 30, 2009 | Finis Swi MP3 Player
I have free space that i can't use on my SanDisk micro SD card.
Make sure its formated FAT 32 or above such as NTFS this will shore up this memory issue problem with your memory stick.
Good luck and God bless
Jul 18, 2009 | SanDisk 2GB microSD Memory Card
When I download songs one day the next day download songs it removes some songs I already had on the mp3 even though I have plenty of space for the songs.
It seems to me that you are using windows xp and thus facing this problem.I will suggest you to use windows vista and format the mp3 in fat32 partition and then copy paste the songs..It will be working fine......................
Sep 24, 2008 | Apple iPod touch
Music Transfer
Go to every folder in the my stuff and multimedia and see if you need to delete stuff to make more space...you may not have saved to the memory card but rather the internal memory. Worked for me.
Jan 24, 2008 | LG Shine KE970 Cellular Phone
My sansa is messed up
It is referring to the "database", or the menus on the device. (i.e. - songs titles, music, artists) It needs at least 6MB of free space on the device to create this. If you freed up what you think is 6MB, it may not be enough. Even though you have a 2GB player, there is only 1.85 of usable space on it. So try deleting some more tracks. If not, format the device and start over. Right click on the device in My Computer and select format. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e250 MP3 Player
Playing
I had the same problem and it took me while to figure it out, but I did. Thanks to a website telling me how to re-format the whole thing. I went to "my computer" and right clicked on "removeable device" and clicked on format. It should read "fat" not "fat32" then I clicked "start" and then when I loaded stuff on it worked. Good luck!
Feb 18, 2007 | Finis Swi MP3 Player
Finis Swi MP3 Player Logo
112 people viewed this question
Top Finis Audio Players & Recorders Experts
Terry Hair
Are you a Finis Audio Player and Recorder Expert? Answer questions, earn points and help others
